    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 28.0k Views 49 Watching
      Macs
      Here 2 images of what I'm tring
      first one select plane tool and tring to draw a verical line, before mouse click
      second one is what i get after the mouse click
      • fredo6F Offline
        fredo6
        Macs,
        I understand. This is due to a problem in Sketchup when you create a curve made of edges on an existing edge (you can check this is the case when you generate in a group and then explode). I'll try to fix it.
        By default, the script generates curves for each line drawn. If you deactivate this option (key F9), it works correctly.
        • soloS Offline
          solo
          Absolutely fred.
          http://www.solos-art.com
            mateo soletic
            Fred, Thanks a lot, great tool.👍
            [Concept Illustrations](http://concept-illustrations.com/)
            • MarianM Offline
              Marian
              😍 REALLY COOOL TOOL
              • boofredlayB Offline
                boofredlay
                Dang, I am having a hard time keeping up with all the new toys.
                Coolness 🤓
                • G Offline
                  glenn
                  Thank you!!!!!
                  Glenn
                    Daniel S
                    Hi fredo...
                    About the offset on surface the external offset deletes the original surface... is there a way to keep the original surface like in the previous version? In the image I put in "1" the external offset, in "2" the actual result and in "3" what i´m trying to get.
                    About the icons and cursors i tried to make them.. but i can´t do the ones with Cline. The ones i can don´t look very good... but i post them here.
                    Daniel S
                    Icons tools on surface.zip
                    • majidM Offline
                      majid
                      a new crazy world of su is reachinG!!!!
                      ThAnKs Fredo!!!!!!!!!! and wwwwwwwwwwooooooooowwwwwwjust for FuNnN
                        bubbalove
                        It says the attachment doesn't exist anymore!?!
                        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                        • fredo6F Offline
                          fredo6
                          @daniel s said:
                          Hi fredo...
                          Daniel S
                          Daniel (and all)
                          Sorry for this. I fixed the bug and reloaded on the first message of this thread.
                          (Bubbalove: try again, as you wanted to download when I was replacing the file. Sorry)
                            dylan
                            Thanks once again fredo. Another fantastic addition to SU 👍
                            http://dmdarchitecture.co.uk/
                              Julius
                              great! this is very useful on not-curved-surfaces because you don't have to worry about intersecting with other lines!
                              • soloS Offline
                                solo
                                This tool also is much better at making .png cut-outs than the regular SU tool.
                                  remus
                                  In what ways that solo?
                                  • soloS Offline
                                    solo
                                    Have you ever tried to draw around a complex shape and the line occasionally changes axis thus not closing?, well this hugs the surface and those issues are a thing of the past.
                                      remus
                                      Fair enough, i'll admit i havent done a lot of cutting out with .pngs, but when i did do it i didnt find the freehand tool to bad. Obviously need to do more 2d components 👍
                                      • CadFatherC Offline
                                        CadFather
                                        Fredo, here's some icons - see if you like them...
                                        i noticed that the draw line cursor is the same as the draw line icon on the toolbar.
                                        this is not good because the sizes differ (toolbars are 24x24 - cursors 32x32)
                                        so i created a cursor called 'ofs_draw_Dline.png' - you just need to tweak the script to fit this update and then the tip of the pencil will fall right on the line as you draw.
                                        cheers
                                        OFS_Dir.zip
                                        • chippwaltersC Offline
                                          chippwalters
                                          Wonderful! I don't even know how I could create the model below in other 3D modelers! Much appreciated 😄
                                          Currently working with Cross-Reality technologies
                                            Jon
                                            Chip, I was attempting to do my own version of your model and came up with this:
                                            http://i168.photobucket.com/albums/u173/Jon_Westwood/thingrendsmall.png
                                            Tell someone "that was made in sketchup" a year ago. 🤓
                                            Jon
                                            KT Team member
                                            • 2 / 5
