    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 34.2k Views 49 Watching
      Daniel S
      Awesome like always!!! 😍 😍 😍
      Thank You!!!
      Daniel S
        remus
        http://farm4.static.flickr.com/3151/2486502204_190c833716_o.jpg
        if you squint a lot it almost looks like the great wall fo china 👍
        Anywya, it was 5 mins and made entirely using ferd06 plugins.
        p.s. i reckon theres reasonable call for having a seperate menu in SU called fred06 😄
          remus
          Wheres the file macs?
            Macs
            ops, I've lost the attachment on previous post.. now it's there
              Macs
              Hi Fredo! Your tools are fantastic! 👍
              I think i found a problem while I was playing with the line tool:
              I've attcached this simple model
              draw a plane line with your tool from the lower vertex of the segment
              up in vertical. The result line will be connected to the upper circle
              and not to the starting vertex.
              The same does not happen with the costruction line.
              cylinder.skp
              • I Offline
                ilay7k
                Wonderful magic of tools, thank you!!!
                • fredo6F Offline
                  I am not totally clear on what happened to you.
                  What is sure is that when the surfaces contains planes which are perpendicular, the interpretation of a path on the surface is always ambiguous.
                  • MALAISEM Offline
                    MALAISE
                    😍 Ausgezeichnet, excellent, great what y've done.
                    MALAISE
                    • fredo6F Offline
                      @solo said:
                      Just gave me another toy, I mean tool. 👍
                      3 minutes to make.
                      Solo,
                      very nice illustration of what you can do by combining JPP and the Tools on Surface.
                      Would you mind if I take the picture and put it in the documentation?
                        Macs
                        Here 2 images of what I'm tring
                        first one select plane tool and tring to draw a verical line, before mouse click
                        second one is what i get after the mouse click
                        • fredo6F Offline
                          Macs,
                          I understand. This is due to a problem in Sketchup when you create a curve made of edges on an existing edge (you can check this is the case when you generate in a group and then explode). I'll try to fix it.
                          By default, the script generates curves for each line drawn. If you deactivate this option (key F9), it works correctly.
                          • soloS Offline
                            Absolutely fred.
                              mateo soletic
                              Fred, Thanks a lot, great tool.👍
                              Concept Illustrations
                              • MarianM Offline
                                Marian
                                😍 REALLY COOOL TOOL
                                • boofredlayB Offline
                                  boofredlay
                                  Dang, I am having a hard time keeping up with all the new toys.
                                  Coolness 🤓
                                    glenn
                                    Thank you!!!!!
                                    Glenn
                                      Daniel S
                                      Hi fredo...
                                      About the offset on surface the external offset deletes the original surface... is there a way to keep the original surface like in the previous version? In the image I put in "1" the external offset, in "2" the actual result and in "3" what i´m trying to get.
                                      About the icons and cursors i tried to make them.. but i can´t do the ones with Cline. The ones i can don´t look very good... but i post them here.
                                      Daniel S
                                      Icons tools on surface.zip
                                      • majidM Offline
                                        majid
                                        a new crazy world of su is reachinG!!!!
                                        ThAnKs Fredo!!!!!!!!!! and wwwwwwwwwwooooooooowwwwwwjust for FuNnN
                                          bubbalove
                                          It says the attachment doesn't exist anymore!?!
                                          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                          • fredo6F Offline
                                            @daniel s said:
                                            Hi fredo...
                                            Daniel S
                                            Daniel (and all)
                                            Sorry for this. I fixed the bug and reloaded on the first message of this thread.
                                            (Bubbalove: try again, as you wanted to download when I was replacing the file. Sorry)
                                            • 2 / 5
