    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 35.8k Views 49 Watching
      Macs
      Hi Fredo! Your tools are fantastic! 👍
      I think i found a problem while I was playing with the line tool:
      I've attcached this simple model
      draw a plane line with your tool from the lower vertex of the segment
      up in vertical. The result line will be connected to the upper circle
      and not to the starting vertex.
      The same does not happen with the costruction line.
      cylinder.skp
      • I
        ilay7k
        Wonderful magic of tools, thank you!!!
        • fredo6F
          I am not totally clear on what happened to you.
          What is sure is that when the surfaces contains planes which are perpendicular, the interpretation of a path on the surface is always ambiguous.
          • MALAISEM
            MALAISE
            😍 Ausgezeichnet, excellent, great what y've done.
            MALAISE
            • fredo6F
              @solo said:
              Just gave me another toy, I mean tool. 👍
              3 minutes to make.
              Solo,
              very nice illustration of what you can do by combining JPP and the Tools on Surface.
              Would you mind if I take the picture and put it in the documentation?
                Macs
                Here 2 images of what I'm tring
                first one select plane tool and tring to draw a verical line, before mouse click
                second one is what i get after the mouse click
                • fredo6F
                  Macs,
                  I understand. This is due to a problem in Sketchup when you create a curve made of edges on an existing edge (you can check this is the case when you generate in a group and then explode). I'll try to fix it.
                  By default, the script generates curves for each line drawn. If you deactivate this option (key F9), it works correctly.
                  • soloS
                    Absolutely fred.
                      mateo soletic
                      Fred, Thanks a lot, great tool.👍
                      Concept Illustrations
                      • MarianM
                        Marian
                        😍 REALLY COOOL TOOL
                        • boofredlayB
                          boofredlay
                          Dang, I am having a hard time keeping up with all the new toys.
                          Coolness 🤓
                          • G
                            glenn
                            Thank you!!!!!
                            Glenn
                              Daniel S
                              Hi fredo...
                              About the offset on surface the external offset deletes the original surface... is there a way to keep the original surface like in the previous version? In the image I put in "1" the external offset, in "2" the actual result and in "3" what i´m trying to get.
                              About the icons and cursors i tried to make them.. but i can´t do the ones with Cline. The ones i can don´t look very good... but i post them here.
                              Daniel S
                              Icons tools on surface.zip
                              • majidM
                                majid
                                a new crazy world of su is reachinG!!!!
                                ThAnKs Fredo!!!!!!!!!! and wwwwwwwwwwooooooooowwwwwwjust for FuNnN
                                • B
                                  bubbalove
                                  It says the attachment doesn't exist anymore!?!
                                  "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                  • fredo6F
                                    @daniel s said:
                                    Hi fredo...
                                    Daniel S
                                    Daniel (and all)
                                    Sorry for this. I fixed the bug and reloaded on the first message of this thread.
                                    (Bubbalove: try again, as you wanted to download when I was replacing the file. Sorry)
                                      dylan
                                      Thanks once again fredo. Another fantastic addition to SU 👍
                                      http://dmdarchitecture.co.uk/
                                        Julius
                                        great! this is very useful on not-curved-surfaces because you don't have to worry about intersecting with other lines!
                                        • soloS
                                          This tool also is much better at making .png cut-outs than the regular SU tool.
                                            remus
                                            In what ways that solo?
                                            • 2 / 5
