    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 35.8k Views 49 Watching
    • MALAISEM
      MALAISE
      😍 Ausgezeichnet, excellent, great what y've done.
      MALAISE
      • fredo6F
        @solo said:
        Just gave me another toy, I mean tool. 👍
        3 minutes to make.
        Solo,
        very nice illustration of what you can do by combining JPP and the Tools on Surface.
        Would you mind if I take the picture and put it in the documentation?
          Macs
          Here 2 images of what I'm tring
          first one select plane tool and tring to draw a verical line, before mouse click
          second one is what i get after the mouse click
          • fredo6F
            Macs,
            I understand. This is due to a problem in Sketchup when you create a curve made of edges on an existing edge (you can check this is the case when you generate in a group and then explode). I'll try to fix it.
            By default, the script generates curves for each line drawn. If you deactivate this option (key F9), it works correctly.
            • soloS
              Absolutely fred.
                mateo soletic
                Fred, Thanks a lot, great tool.👍
                Concept Illustrations
                • MarianM
                  Marian
                  😍 REALLY COOOL TOOL
                  • boofredlayB
                    boofredlay
                    Dang, I am having a hard time keeping up with all the new toys.
                    Coolness 🤓
                    • G
                      glenn
                      Thank you!!!!!
                      Glenn
                        Daniel S
                        Hi fredo...
                        About the offset on surface the external offset deletes the original surface... is there a way to keep the original surface like in the previous version? In the image I put in "1" the external offset, in "2" the actual result and in "3" what i´m trying to get.
                        About the icons and cursors i tried to make them.. but i can´t do the ones with Cline. The ones i can don´t look very good... but i post them here.
                        Daniel S
                        Icons tools on surface.zip
                        • majidM
                          majid
                          a new crazy world of su is reachinG!!!!
                          ThAnKs Fredo!!!!!!!!!! and wwwwwwwwwwooooooooowwwwwwjust for FuNnN
                          • B
                            bubbalove
                            It says the attachment doesn't exist anymore!?!
                            "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                            • fredo6F
                              @daniel s said:
                              Hi fredo...
                              Daniel S
                              Daniel (and all)
                              Sorry for this. I fixed the bug and reloaded on the first message of this thread.
                              (Bubbalove: try again, as you wanted to download when I was replacing the file. Sorry)
                                dylan
                                Thanks once again fredo. Another fantastic addition to SU 👍
                                http://dmdarchitecture.co.uk/
                                  Julius
                                  great! this is very useful on not-curved-surfaces because you don't have to worry about intersecting with other lines!
                                  • soloS
                                    This tool also is much better at making .png cut-outs than the regular SU tool.
                                      remus
                                      In what ways that solo?
                                      • soloS
                                        Have you ever tried to draw around a complex shape and the line occasionally changes axis thus not closing?, well this hugs the surface and those issues are a thing of the past.
                                          remus
                                          Fair enough, i'll admit i havent done a lot of cutting out with .pngs, but when i did do it i didnt find the freehand tool to bad. Obviously need to do more 2d components 👍
                                          • CadFatherC
                                            CadFather
                                            Fredo, here's some icons - see if you like them...
                                            i noticed that the draw line cursor is the same as the draw line icon on the toolbar.
                                            this is not good because the sizes differ (toolbars are 24x24 - cursors 32x32)
                                            so i created a cursor called 'ofs_draw_Dline.png' - you just need to tweak the script to fit this update and then the tip of the pencil will fall right on the line as you draw.
                                            cheers
                                            OFS_Dir.zip
                                            • 2 / 5
