    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 134.2k Views 85 Watching
      CPhillips
      @daniel s said:
      Thank you Chris!!! Extra line is the solution β˜€ β˜€
      Daniel S
      PS. Not very important but when you apply the sketchybevel tool 2 times.. the plugin create a lot of extra lines that are not used and not create faces... is there a way to easily eliminate this lines?
      Only thing you can do is turn off "cap holes" after 1st bevel and then fill them in by hand. Hopefully I can figure out how to eliminate the extra faces in future version.
      • W Offline
        witjazz
          remus
          Daniel, you could also try running that CAD cleanup script that was recently released (sorry i cant remeber exactly what its called or who its by πŸ˜› )
          EDIT: this is the one i meant.
            dylan
            Missed this one while I was away, but a nice present upon my return - Thanks! πŸ‘
            http://dmdarchitecture.co.uk/
              Daniel S
              Thank you, but it dosenΒ΄t work with this lines. I have another old script that removes unused Edges but donΒ΄t delete this ones.
              ItΒ΄s not a big problem, but when you use soften edges this lines affect the model.
              Daniel S
              • david_hD Offline
                david_h
                😎 very cool! 😎
                Merci. Spasibo. Gracias. Danke. Tanks a lot!
                  Julius
                  too bad i don't visit the ruby forum...i found a link to this topic in the Kerkythea forum. 😳
                  anyway, thanks a lot for this plugin!
                    bellwells
                    Chris, this is incredibly useful script. What a stud you are. Thank you very much. In case anybody was wondering, this works in SU5 as well as SU6.
                    Ron
                      Jon
                      I have a little problem with Bevel and components...
                      http://i168.photobucket.com/albums/u173/Jon_Westwood/clip0083.gif
                      that aside, this script is incredible!!! 😍 😍 )
                      Jon
                      KT Team member
                        Ah yes, the old "delete the related components" trick. It's a feature. πŸ˜‰
                        Actually I see the same thing. It appears that the plugin doesn't appreciate components.
                        Still, thank you very much for this.
                          CPhillips
                          So the problem is that you cant bevel geometry inside a component?
                          Ill try to fix that next version.
                            That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
                            Thanks again for this plugin. πŸ‘
                            Dave
                              CPhillips
                              Dave
                              Oh, That. Yeah Ill fix.
                              • utilerU Offline
                                utiler
                                @watkins said:
                                Dear Majid,
                                Remember, the input is in inches. Try using a fraction like 0.01 inches.
                                Regards,
                                Bob
                                Have been following this thread for a while, great ruby!!
                                Is there a chance of the plug-in being converted to metric for those of us on the other side?
                                cheers,
                                Just Curious...
                                  Jon
                                  Thanks a lot 😍 😍
                                  Jon
                                  KT Team member
                                    CPhillips
                                    May 11 update.
                                    -Fixed hang bug if input box canceled.
                                    -Beveling now works inside of groups and components.
                                    -Bevel amount should now be in the set unit format (meters, cm, feet, etc)
                                    -Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
                                    301 Moved Permanently
                                    (www.sketchucation.com)
                                      remus
                                      Cheers chris, good to see cotinued development πŸ˜„
                                      • utilerU Offline
                                        utiler
                                        champion, Chris!!!
                                        Just Curious...
                                        • erikBE Offline
                                          erikB
                                          Thanks very much for the input in metric. !!
                                          erikB
                                            mike d
                                            thanks chris
                                            The grass is always GREENER on the roof.
                                            • 6
                                            • 7
                                            • 8
                                            • 4 / 8
