    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
      remus
      Daniel, you could also try running that CAD cleanup script that was recently released (sorry i cant remeber exactly what its called or who its by πŸ˜› )
      EDIT: this is the one i meant.
        dylan
        Missed this one while I was away, but a nice present upon my return - Thanks! πŸ‘
        http://dmdarchitecture.co.uk/
          Daniel S
          Thank you, but it dosenΒ΄t work with this lines. I have another old script that removes unused Edges but donΒ΄t delete this ones.
          ItΒ΄s not a big problem, but when you use soften edges this lines affect the model.
          Daniel S
          • david_hD
            david_h
            😎 very cool! 😎
            Merci. Spasibo. Gracias. Danke. Tanks a lot!
              Julius
              too bad i don't visit the ruby forum...i found a link to this topic in the Kerkythea forum. 😳
              anyway, thanks a lot for this plugin!
              • B
                bellwells
                Chris, this is incredibly useful script. What a stud you are. Thank you very much. In case anybody was wondering, this works in SU5 as well as SU6.
                Ron
                  Jon
                  I have a little problem with Bevel and components...
                  http://i168.photobucket.com/albums/u173/Jon_Westwood/clip0083.gif
                  that aside, this script is incredible!!! 😍 😍 )
                  Jon
                  KT Team member
                    Ah yes, the old "delete the related components" trick. It's a feature. πŸ˜‰
                    Actually I see the same thing. It appears that the plugin doesn't appreciate components.
                    Still, thank you very much for this.
                    • C
                      CPhillips
                      So the problem is that you cant bevel geometry inside a component?
                      Ill try to fix that next version.
                        That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
                        Thanks again for this plugin. πŸ‘
                        Dave
                        • C
                          CPhillips
                          Dave
                          Oh, That. Yeah Ill fix.
                          • utilerU
                            utiler
                            @watkins said:
                            Dear Majid,
                            Remember, the input is in inches. Try using a fraction like 0.01 inches.
                            Regards,
                            Bob
                            Have been following this thread for a while, great ruby!!
                            Is there a chance of the plug-in being converted to metric for those of us on the other side?
                            cheers,
                            Just Curious...
                              Jon
                              Thanks a lot 😍 😍
                              Jon
                              KT Team member
                              • C
                                CPhillips
                                May 11 update.
                                -Fixed hang bug if input box canceled.
                                -Beveling now works inside of groups and components.
                                -Bevel amount should now be in the set unit format (meters, cm, feet, etc)
                                -Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
                                404 Not Found
                                (www.sketchucation.com)
                                  remus
                                  Cheers chris, good to see cotinued development πŸ˜„
                                  • utilerU
                                    utiler
                                    champion, Chris!!!
                                    Just Curious...
                                    • erikBE
                                      erikB
                                      Thanks very much for the input in metric. !!
                                      erikB
                                        mike d
                                        thanks chris
                                        The grass is always GREENER on the roof.
                                        • CadFatherC
                                          CadFather
                                          fantastic, i used to get some persistent error message at times - end task being the only way out - i'll report if any.. Thank You
                                          now i bevel just about anything.. πŸ€“
                                          • B
                                            bubbalove
                                            This may be a dumb question but when I try to download the file I keep getting it in text format... do I just the delete the .txt from the end of it or just put it in the script folder and it knows what to do? Ohh.. and I am using Safari as my internet browser.
                                            "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                            • 4 / 8
