    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 143.2k Views 85 Watching
    • david_hD Offline
      david_h
      😎 very cool! 😎
      Merci. Spasibo. Gracias. Danke. Tanks a lot!
        Julius
        too bad i don't visit the ruby forum...i found a link to this topic in the Kerkythea forum. 😳
        anyway, thanks a lot for this plugin!
          bellwells
          Chris, this is incredibly useful script. What a stud you are. Thank you very much. In case anybody was wondering, this works in SU5 as well as SU6.
          Ron
            Jon
            I have a little problem with Bevel and components...
            http://i168.photobucket.com/albums/u173/Jon_Westwood/clip0083.gif
            that aside, this script is incredible!!! 😍 😍 )
            Jon
            KT Team member
              Ah yes, the old "delete the related components" trick. It's a feature. πŸ˜‰
              Actually I see the same thing. It appears that the plugin doesn't appreciate components.
              Still, thank you very much for this.
                CPhillips
                So the problem is that you cant bevel geometry inside a component?
                Ill try to fix that next version.
                  That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
                  Thanks again for this plugin. πŸ‘
                  Dave
                    CPhillips
                    Dave
                    Oh, That. Yeah Ill fix.
                    • utilerU Offline
                      utiler
                      @watkins said:
                      Dear Majid,
                      Remember, the input is in inches. Try using a fraction like 0.01 inches.
                      Regards,
                      Bob
                      Have been following this thread for a while, great ruby!!
                      Is there a chance of the plug-in being converted to metric for those of us on the other side?
                      cheers,
                      Just Curious...
                        Jon
                        Thanks a lot 😍 😍
                        Jon
                        KT Team member
                          CPhillips
                          May 11 update.
                          -Fixed hang bug if input box canceled.
                          -Beveling now works inside of groups and components.
                          -Bevel amount should now be in the set unit format (meters, cm, feet, etc)
                          -Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
                          404 Not Found
                          (www.sketchucation.com)
                            remus
                            Cheers chris, good to see cotinued development πŸ˜„
                            • utilerU Offline
                              utiler
                              champion, Chris!!!
                              Just Curious...
                              • erikBE Offline
                                erikB
                                Thanks very much for the input in metric. !!
                                erikB
                                  mike d
                                  thanks chris
                                  The grass is always GREENER on the roof.
                                  • CadFatherC Offline
                                    CadFather
                                    fantastic, i used to get some persistent error message at times - end task being the only way out - i'll report if any.. Thank You
                                    now i bevel just about anything.. πŸ€“
                                      bubbalove
                                      This may be a dumb question but when I try to download the file I keep getting it in text format... do I just the delete the .txt from the end of it or just put it in the script folder and it knows what to do? Ohh.. and I am using Safari as my internet browser.
                                      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                        remus
                                        You'll need to change the file extension to .rb for it to work. Not sure why its downloading it as a .txt though πŸ˜‰ perhaps some of the more apple savy have an answer?
                                          bubbalove
                                          Figured it out... for some reason Safari downloads it as a txt file for some reason. Worked like a charm in IE even though I don't like using IE. Thanks Remus!
                                          • soloS Offline
                                            I use safari on my Mac and .rb's save normally, must be a setting.
                                            • 4 / 8
