    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
      @jon said:
      I have a little problem with Bevel and components...
      http://i168.photobucket.com/albums/u173/Jon_Westwood/clip0083.gif
      that aside, this script is incredible!!! 😍 😍 )
      Ah yes, the old "delete the related components" trick. It's a feature. πŸ˜‰
      Actually I see the same thing. It appears that the plugin doesn't appreciate components.
      Still, thank you very much for this.
      • C
        CPhillips
        So the problem is that you cant bevel geometry inside a component?
        Ill try to fix that next version.
          That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
          Thanks again for this plugin. πŸ‘
          Dave
          • C
            CPhillips
            Dave
            Oh, That. Yeah Ill fix.
            • utilerU
              utiler
              @watkins said:
              Dear Majid,
              Remember, the input is in inches. Try using a fraction like 0.01 inches.
              Regards,
              Bob
              Have been following this thread for a while, great ruby!!
              Is there a chance of the plug-in being converted to metric for those of us on the other side?
              cheers,
              Just Curious...
                Jon
                Thanks a lot 😍 😍
                Jon
                KT Team member
                • C
                  CPhillips
                  May 11 update.
                  -Fixed hang bug if input box canceled.
                  -Beveling now works inside of groups and components.
                  -Bevel amount should now be in the set unit format (meters, cm, feet, etc)
                  -Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
                  404 Not Found
                  (www.sketchucation.com)
                    remus
                    Cheers chris, good to see cotinued development πŸ˜„
                    • utilerU
                      utiler
                      champion, Chris!!!
                      Just Curious...
                      • erikBE
                        erikB
                        Thanks very much for the input in metric. !!
                        erikB
                          mike d
                          thanks chris
                          The grass is always GREENER on the roof.
                          • CadFatherC
                            CadFather
                            fantastic, i used to get some persistent error message at times - end task being the only way out - i'll report if any.. Thank You
                            now i bevel just about anything.. πŸ€“
                            • B
                              bubbalove
                              This may be a dumb question but when I try to download the file I keep getting it in text format... do I just the delete the .txt from the end of it or just put it in the script folder and it knows what to do? Ohh.. and I am using Safari as my internet browser.
                              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                remus
                                You'll need to change the file extension to .rb for it to work. Not sure why its downloading it as a .txt though πŸ˜‰ perhaps some of the more apple savy have an answer?
                                • B
                                  bubbalove
                                  Figured it out... for some reason Safari downloads it as a txt file for some reason. Worked like a charm in IE even though I don't like using IE. Thanks Remus!
                                  • soloS
                                    I use safari on my Mac and .rb's save normally, must be a setting.
                                    • B
                                      bubbalove
                                      I looked at my preferences... everything is the way it is supposed to be. Maybe it is because I'm using Safari on Windows or something. Do they automatically save to your desktop or does it give you an option on where you want to save it?
                                      • soloS
                                        Yup to the desktop unfortunately, I hardly use the Mac so it's no big deal really. every now and again I have to clean it all up as I run out of space on desktop.
                                          REGIS
                                          with safari 2 it saves on the desktop but with safari 3 and 10.5 it saves where you want and you can check this in safari's preferences
                                          Never tried safari 3 with 10.4
                                            rzadwg
                                            woah, awesome, cheers for this one. its gunna save me a lot of time!
                                            • 4 / 8
