    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 23.9k Views 36 Watching
    • mariochaM Offline
      mariocha
      And another example of work with it.
      head
      %(#008000)[Mario C.
      • W Offline
        Whaat
        impressive stuff, mariocha! Hope you are enjoying the plugin!
        • mariochaM Offline
          mariocha
          I sure am.
          And anybody who wants that model will have to pay you and CPhilips (FDD). ! 😉 😉
          %(#008000)[Mario C.
            Julius
            as i wrote, i have to get this plugin sooner or later.
            in the meantime, may i ask why in the billing information page the adress and the phone are required? i mean, isn't this just a file to download ❓
              johnsenior1973
              Is this the first time you've used PayPal? It will be PayPal wanting your address and phone number, not Smustard. PayPal will just be trying to verify that it is a legitimate use of card and not someone trying to use a stolen one.
                Julius
                yes, first time. thank you for the explanation.
                  Julius
                  just got it! and made a quick snoopy: 😉
                  http://img61.imageshack.us/img61/4350/snoopyia3.jpg
                  he looks quite bad, isn'it? i suppose he just fell from the top of his "house".
                  anyway, thanks whaat!
                  • simon le bonS Offline
                    simon le bon
                    Dear Mario,
                    Do you really draw this rose with S&S ? If so, would you be kind enough to share the process?
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Fleur.png
                    :-)simon
                    • mariochaM Offline
                      mariocha
                      Yes I did.
                      It is not very hard actually.
                      1- Draw a petal, (I did only one) with S&S. Start with a simple shape. The crease tool is usefull at certain points and edges. Once satisfied, leave S&S and fine tune the resulting component (subsurf) by editing some vertex, if needed. Image 1.png
                      2- Once you like it, copy the component around and use Flip along Axes and Scale to vary the look.
                      3- The stem was shaped with FDD, after S&S.
                      4- Same for the leaves, S&S then FDD. I did two basic components, copied and modified. (They are more like tulip leaves though)
                      The thorns kind of happened by accident while doing some FDD.
                      That's part of the fun. Et voilà.
                      %(#008000)[Mario C.
                        simon le bon
                        A tulip of course. A Beautiful tulip with thorns. Thx dear Mario for sharing this nice exemple. i'm going to exercise myself with it tomorrow!! ;-)simon
                          cruelcomedy
                          I did these just to test it out and making organic shapes is so much easier with this thing. thank you!
                          I used podium to render these.
                          http://www.richarddoble.com/sup2.jpg
                          http://www.richarddoble.com/32.jpg
                            remus
                            Indeed it is a very nice tool, sweet renders btw 👍
                            • marleusM Offline
                              marleus
                              Finally got it 😄 😄 😄
                              Thanks, its a great helper.....
                              Markus Sillander
                              Vantaa, Finland
                              I'm on FormFonts now
                              http://www.formfonts.com
                                Jorgensen
                                I often use the knife tool - but it crashes SU 7 very often. Is this a known issue ?
                                Jorgensen
                                sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                                  remus
                                  Yes, i think the knife tool is known to be quite buggy.
                                  You might want to try out whaats zorro2 script instead, does the same thing but has a number of improvements.
                                  • G Offline
                                    Grant Hall
                                    Hello,
                                    I found this forum after experiencing a problem with the Subdivide & Smooth ruby.
                                    The icons will not display in the toolbar. The toolbar is there but it only shows blank squares. If I hover over the blank squares, I get the proper description and the script preforms properly.
                                    Attached is a screenshot of my plugin folder. (Mac OS X 10.5.6 - Sketchup Pro 7.0.8656)
                                    Thank you,
                                    Grant
                                    (I should add that it works fine on my laptop - Mac OS X 10.4.11 - Sketchup Pro 6.4.120)
                                    • O Offline
                                      otb designworks
                                      This is a known, and solved issue.
                                      Check out this thread
                                      Cheers, Chuck
                                      OTB Designworks is on Youtube
                                      • G Offline
                                        Grant Hall
                                        Thank you kannonbal! That fixed it.
                                        • O Offline
                                          otb designworks
                                          perfect!
                                          Cheers, Chuck
                                            cruelcomedy
                                            I love this plug in!
                                            http://richarddoble.com/robot_experiment_organic.jpg
                                            the other thread where I posted some stuff: http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=16894&st=0&sk=t&sd=a
                                            • 6
                                            • 5 / 6
