    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 35.4k Views 36 Watching
    • C
      cruelcomedy
      I did these just to test it out and making organic shapes is so much easier with this thing. thank you!
      I used podium to render these.
      http://www.richarddoble.com/sup2.jpg
      http://www.richarddoble.com/32.jpg
        remus
        Indeed it is a very nice tool, sweet renders btw ๐Ÿ‘
        • marleusM
          marleus
          Finally got it ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
          Thanks, its a great helper.....
          Markus Sillander
          Vantaa, Finland
          I'm on FormFonts now
          http://www.formfonts.com
            Jorgensen
            I often use the knife tool - but it crashes SU 7 very often. Is this a known issue ?
            Jorgensen
              remus
              Yes, i think the knife tool is known to be quite buggy.
              You might want to try out whaats zorro2 script instead, does the same thing but has a number of improvements.
              • G
                Grant Hall
                Hello,
                I found this forum after experiencing a problem with the Subdivide & Smooth ruby.
                The icons will not display in the toolbar. The toolbar is there but it only shows blank squares. If I hover over the blank squares, I get the proper description and the script preforms properly.
                Attached is a screenshot of my plugin folder. (Mac OS X 10.5.6 - Sketchup Pro 7.0.8656)
                Thank you,
                Grant
                (I should add that it works fine on my laptop - Mac OS X 10.4.11 - Sketchup Pro 6.4.120)
                • O
                  otb designworks
                  This is a known, and solved issue.
                  Check out this thread
                  Cheers, Chuck
                  OTB Designworks is on Youtube
                  • G
                    Grant Hall
                    Thank you kannonbal! That fixed it.
                    • O
                      otb designworks
                      perfect!
                      Cheers, Chuck
                      • C
                        cruelcomedy
                        I love this plug in!
                        http://richarddoble.com/robot_experiment_organic.jpg
                        the other thread where I posted some stuff: http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=16894&st=0&sk=t&sd=a
                        • W
                          Whaat
                          Hey cruel,
                          Your work is jawdropping! ๐Ÿ˜ฎ Thanks for sharing. Glad you like the plugin. Any ideas for future versions?
                          • L
                            liam887
                            Nice work! I cant wait for SDS2 I wont have to do my organics in other apps!!! ๐Ÿ˜„ ๐Ÿ˜„
                            Edit:
                            Yikes didnt mean to bump such an old thread I got linked through a post and commented without looking at the dates!
                            VISIT MY ONLINE GALLERY
                            • 5 / 6
