    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 27.1k Views 36 Watching
    • simon le bonS Offline
      simon le bon
      Dear Whaat,
      Coming at the end. Havn't followed the exciting story of Subdivide's development..Regrets.
      It is Solo Curtains which decided me to download your ruby script from Smustard because there is here some kind of shape i have recently deeply fight to obtain with SU.
      Good stuff indeed!!
      But! -- it's a complex set of tools, and even if i have watched carefully the videos tuts
      Subdivide and Smooth Tutorial Part1
      Subdivide and Smooth Tutorial Part2
      And also:
      SCREENCAST.COM SubD2_Chair
      SCREENCAST.COM Pilow
      (english is not ma native language and is not so easy for me to understand)i feel a bit lost. I really need, perhaps not a complete UserGuide but at least a reference QuickCard would be very welcome.
      Regards, simonlebon
        cheffey
        Dale,
        Can you make the plugin so that the proxy object is created on a "proxy" layer so i can easily hide/unhide?
        or will that destroy the functionality of it?
        BROS RŌMAN BRÄUN
        • W Offline
          Whaat
          Hi simon,
          I am sorry I do not have a complete User Guide. I will try to find time to write a Quick Reference guide. In hindsight, I should have provided this in addition to the video tutorials as a minimum.
          Your best source for learning how to use the plugin is to simply ask questions on this forum. You will probably get an answer quicker than looking it up in a manual!
          Dale
          • W Offline
            Whaat
            @cheffey said:
            Dale,
            This question is discussed here:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=253&t=9233
            I may add a feature in the future to automaticaly put the proxy object on a separate layer. This seems to be a common problem.
            Thanks cheffey!
            • mariochaM Offline
              mariocha
              Whell ... not exactly a problem, but indeed a slow-downer. I have do it manually for now, every time.
              So I second the motion.
              Oh and it also helps to put the transparent "boxes" on their own layer.
              Many, many thanks.
              %(#008000)[Mario C.
              • mariochaM Offline
                mariocha
                And another example of work with it.
                head
                %(#008000)[Mario C.
                • W Offline
                  Whaat
                  impressive stuff, mariocha! Hope you are enjoying the plugin!
                  • mariochaM Offline
                    mariocha
                    I sure am.
                    And anybody who wants that model will have to pay you and CPhilips (FDD). ! 😉 😉
                    %(#008000)[Mario C.
                      Julius
                      as i wrote, i have to get this plugin sooner or later.
                      in the meantime, may i ask why in the billing information page the adress and the phone are required? i mean, isn't this just a file to download ❓
                        johnsenior1973
                        Is this the first time you've used PayPal? It will be PayPal wanting your address and phone number, not Smustard. PayPal will just be trying to verify that it is a legitimate use of card and not someone trying to use a stolen one.
                          Julius
                          yes, first time. thank you for the explanation.
                            Julius
                            just got it! and made a quick snoopy: 😉
                            http://img61.imageshack.us/img61/4350/snoopyia3.jpg
                            he looks quite bad, isn'it? i suppose he just fell from the top of his "house".
                            anyway, thanks whaat!
                              simon le bon
                              Dear Mario,
                              Do you really draw this rose with S&S ? If so, would you be kind enough to share the process?
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Fleur.png
                              :-)simon
                              • mariochaM Offline
                                mariocha
                                Yes I did.
                                It is not very hard actually.
                                1- Draw a petal, (I did only one) with S&S. Start with a simple shape. The crease tool is usefull at certain points and edges. Once satisfied, leave S&S and fine tune the resulting component (subsurf) by editing some vertex, if needed. Image 1.png
                                2- Once you like it, copy the component around and use Flip along Axes and Scale to vary the look.
                                3- The stem was shaped with FDD, after S&S.
                                4- Same for the leaves, S&S then FDD. I did two basic components, copied and modified. (They are more like tulip leaves though)
                                The thorns kind of happened by accident while doing some FDD.
                                That's part of the fun. Et voilà.
                                %(#008000)[Mario C.
                                  simon le bon
                                  A tulip of course. A Beautiful tulip with thorns. Thx dear Mario for sharing this nice exemple. i'm going to exercise myself with it tomorrow!! ;-)simon
                                    cruelcomedy
                                    I did these just to test it out and making organic shapes is so much easier with this thing. thank you!
                                    I used podium to render these.
                                    http://www.richarddoble.com/sup2.jpg
                                    http://www.richarddoble.com/32.jpg
                                      remus
                                      Indeed it is a very nice tool, sweet renders btw 👍
                                      • marleusM Offline
                                        marleus
                                        Finally got it 😄 😄 😄
                                        Thanks, its a great helper.....
                                        Markus Sillander
                                        Vantaa, Finland
                                        I'm on FormFonts now
                                        http://www.formfonts.com
                                          Jorgensen
                                          I often use the knife tool - but it crashes SU 7 very often. Is this a known issue ?
                                          Jorgensen
                                            remus
                                            Yes, i think the knife tool is known to be quite buggy.
                                            You might want to try out whaats zorro2 script instead, does the same thing but has a number of improvements.
                                            • 5 / 6
