    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 35.4k Views 36 Watching
    • W
      Whaat
      @simon le bon said:
      (english is not ma native language and is not so easy for me to understand)i feel a bit lost. I really need, perhaps not a complete UserGuide but at least a reference QuickCard would be very welcome.
      Hi simon,
      I am sorry I do not have a complete User Guide. I will try to find time to write a Quick Reference guide. In hindsight, I should have provided this in addition to the video tutorials as a minimum.
      Your best source for learning how to use the plugin is to simply ask questions on this forum. You will probably get an answer quicker than looking it up in a manual!
      Dale
      • W
        Whaat
        @cheffey said:
        Dale,
        Can you make the plugin so that the proxy object is created on a "proxy" layer so i can easily hide/unhide?
        or will that destroy the functionality of it?
        This question is discussed here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=253&t=9233
        I may add a feature in the future to automaticaly put the proxy object on a separate layer. This seems to be a common problem.
        Thanks cheffey!
        • mariochaM
          mariocha
          Whell ... not exactly a problem, but indeed a slow-downer. I have do it manually for now, every time.
          So I second the motion.
          Oh and it also helps to put the transparent "boxes" on their own layer.
          Many, many thanks.
          %(#008000)[Mario C.
          • mariochaM
            mariocha
            And another example of work with it.
            head
            %(#008000)[Mario C.
            • W
              Whaat
              impressive stuff, mariocha! Hope you are enjoying the plugin!
              • mariochaM
                mariocha
                I sure am.
                And anybody who wants that model will have to pay you and CPhilips (FDD). ! 😉 😉
                %(#008000)[Mario C.
                  Julius
                  as i wrote, i have to get this plugin sooner or later.
                  in the meantime, may i ask why in the billing information page the adress and the phone are required? i mean, isn't this just a file to download ❓
                    johnsenior1973
                    Is this the first time you've used PayPal? It will be PayPal wanting your address and phone number, not Smustard. PayPal will just be trying to verify that it is a legitimate use of card and not someone trying to use a stolen one.
                      Julius
                      yes, first time. thank you for the explanation.
                        Julius
                        just got it! and made a quick snoopy: 😉
                        http://img61.imageshack.us/img61/4350/snoopyia3.jpg
                        he looks quite bad, isn'it? i suppose he just fell from the top of his "house".
                        anyway, thanks whaat!
                        • simon le bonS
                          simon le bon
                          Dear Mario,
                          Do you really draw this rose with S&S ? If so, would you be kind enough to share the process?
                          http://i274.photobucket.com/albums/jj245/Spendauballet/Fleur.png
                          :-)simon
                          • mariochaM
                            mariocha
                            Yes I did.
                            It is not very hard actually.
                            1- Draw a petal, (I did only one) with S&S. Start with a simple shape. The crease tool is usefull at certain points and edges. Once satisfied, leave S&S and fine tune the resulting component (subsurf) by editing some vertex, if needed. Image 1.png
                            2- Once you like it, copy the component around and use Flip along Axes and Scale to vary the look.
                            3- The stem was shaped with FDD, after S&S.
                            4- Same for the leaves, S&S then FDD. I did two basic components, copied and modified. (They are more like tulip leaves though)
                            The thorns kind of happened by accident while doing some FDD.
                            That's part of the fun. Et voilà.
                            %(#008000)[Mario C.
                            • simon le bonS
                              simon le bon
                              A tulip of course. A Beautiful tulip with thorns. Thx dear Mario for sharing this nice exemple. i'm going to exercise myself with it tomorrow!! ;-)simon
                              • C
                                cruelcomedy
                                I did these just to test it out and making organic shapes is so much easier with this thing. thank you!
                                I used podium to render these.
                                http://www.richarddoble.com/sup2.jpg
                                http://www.richarddoble.com/32.jpg
                                  remus
                                  Indeed it is a very nice tool, sweet renders btw 👍
                                  • marleusM
                                    marleus
                                    Finally got it 😄 😄 😄
                                    Thanks, its a great helper.....
                                    Markus Sillander
                                    Vantaa, Finland
                                    I'm on FormFonts now
                                    http://www.formfonts.com
                                      Jorgensen
                                      I often use the knife tool - but it crashes SU 7 very often. Is this a known issue ?
                                      Jorgensen
                                        remus
                                        Yes, i think the knife tool is known to be quite buggy.
                                        You might want to try out whaats zorro2 script instead, does the same thing but has a number of improvements.
                                        • G
                                          Grant Hall
                                          Hello,
                                          I found this forum after experiencing a problem with the Subdivide & Smooth ruby.
                                          The icons will not display in the toolbar. The toolbar is there but it only shows blank squares. If I hover over the blank squares, I get the proper description and the script preforms properly.
                                          Attached is a screenshot of my plugin folder. (Mac OS X 10.5.6 - Sketchup Pro 7.0.8656)
                                          Thank you,
                                          Grant
                                          (I should add that it works fine on my laptop - Mac OS X 10.4.11 - Sketchup Pro 6.4.120)
                                          • O
                                            otb designworks
                                            This is a known, and solved issue.
                                            Check out this thread
                                            Cheers, Chuck
                                            OTB Designworks is on Youtube
                                            • 5 / 6
