    Lock toolbars
    97 Posts 52 Posters 189.1k Views 52 Watching
    • N Offline
      numerobis
      sorry... but every time i read this topic title i have to laugh... it's really a big joke that this annoying little problem is still not fixed after such a long time!
      If this is such a hard thing to do, the developers of nearly all other softwares i know must be real geniuses since they found a solution for this "unsolvable" problem... 😒
      • ToboboT Offline
        Tobobo
        the save tool bars have gone along way to solve it. Though saying that it hasn't happened in a while. touch wood
        Toby
        Philippians 4:13
        • K Offline
          kwistenbiebel
          Yes, annoying bug still around.. 😄
          • F Offline
            findthong
            @jim said:
            I have taken to not using Toolbars, or having a very minimal number open. I wrote a custom WebDialog (or 2) to replace Toolbars. One dialog is a general toolbar replacement, the other toggles the normal Toolbars visible/not visible. The dialogs are pretty rough around the edges since I am the only one who uses them; but they do show what can be done and how the WebDialogs can (and will) be an effective alternative to the built-in Toolbars.
            There are a few other, similar plugins that are using webdialogs as toolbar alternatives.
            My dialogs: the short texts are buttons, too.
            http://i.min.us/iQWzW.png
            (moved post from another topic)
            This is quite nice. Everyone here having some problem with Toolbar, but my problem is Web Dialogs LOL.
            I'm using Dual monitor set up. Sometime I work with SketchUp on my 1st monitor when SketchUp is being my top priority and many time I've to move it to 2nd monitor. And web dialogs not going to move with SketchUp. That's quite annoying and I need to do a lot workaround and get familier with it.
            And I've just counted I've 112 shortcut combinations to get aroud these UI problem as much as possible! And I can remember 80 percent of them, but not much icons!. It need a lot brain power, when you want to have less moving around as possible while using a lot of scripts to prevent tedious tasks as much as possible. I can't imagine I can even work in SketchUp without my cheat sheet or on other computer 😄.
            We definitely need some UI love for extensive users, because there're so many advanced SketchUp user around!
              shawnkelly
              Sounds like some of the users in this post need to move to another software. This is called Sketch-Up for a reason. I was most likely developed by someone that was tired of the limitations of pencil and paper. It is meant for sketching out ideas quickly without the fuss of all that you people bring to it. I despise the other programs because of their complexity. I use them (Rhino and Modo) of course because they are unnecessary but not at the beginning of a project that has no initial parameters. Do not try to make it so hard on yourselves, it steals all the fun out of it.
              BTW, has anyone tried View>Toolbar>Save Toolbar Location/Restore Toolbar Location. I crash (Bug-Splat) Sketch-Up all the time and I have yet to manually move all my toolbars back to their positions after restoring them.
                No splat here on Restore Toolbars
                Sent from my iPad
                • pbacotP Offline
                  We don't have this problem on Macs.
                  The toolbars are never in a good place, never where you put them, same with windows so they can't be messed up. You get the Mac "customize toolbar" which also sucks.
                  • MichaelNeysesM Offline
                    MichaelNeyses
                    I just cant fathom, what you guys are doing with your toolbars, I closely watched the progress of this discussion. I almost feel guilty by not having this genuine problem at all.
                    If the bars are disturbed, which very rarely occurs, I hit the ALT/F9 Button that I have set on the 'Restore Toolbars' command and all the boys are back in place.
                    I dont have any explanation for this good behavoir other then maybe that I am using a 30" screen which gives me planty of room not to mess in the vicinity of the bars.
                    I rely very much on SU during my workday and produce at least 50 projekts a year. I would have never stuck with this software, if there were such instances as the need of rearranging the landscape of toolbars 5 times a day! Maybe choose the plugins I am using a bit carefully but I have learned long ago that being a gearhead and jumping on any train is the least splendid of all forthcoming methods.
                    nothing beats the joy of accomplishing a design that meets previous vision
                      Note that this discussion started in 2008 (see first post) when there was no such function as "Save toolbar position" or "Restore toolbar position".
                      People keep re-discovering this topic time-to-time...
                      • panixiaP Offline
                        panixia
                        of course not, the width of the monitor doesn't matter. the pixel count does.
                        if you got a 17" 1920x1280px and a 40"1920x1280 px you got the same "pixel space" to use with your toolbar buttons (wich have a fixed pixel dimension).
                        the only difference is that you see bigger pixel, so that you can actually visualize bigger buttons, but you can dock the same amount of buttons than the smaller monitor does.
                        i find that in order to visualize more toolbars/dialogs and other UI elements it's a more effective solution to use 2 smaller monitor rather than 1 bigger montitor.
                        (or maybe 2 bigger montor if you got the cash for it of course)
                          rogadude
                          This is one of three reasons I'm still using SU8... I've got no way to lock my toolbars in position or reset them if they get messed with... very important to me because I need to keep my scenes the same across many jobs and open up a job later and know it will have the same export size as it did when I created it (I use the toolbars to create an 8 1/2 x 11 jpeg export ratio). The other reason is because SU14 gives me no control over the shape of the toolbar once it is in the toolbar dock... always a vertical stack of tools if it is on the left or right... making the export ratio I'm using very hard to achieve, and I also prefer horizontal toolbars. Third reason is the round corner plugin doesn't work.
                          • halroachH Offline
                            halroach
                            I agree.
                            Sketchup 8 is still more comfortable than 2014 with regard to customizing shapes of toolbars and locking them in place. I find that in 2014 when you try to move a toolbar it is way too sensitive and things start flying around... And really, not much new in 2014 to justify the switchover.
                            BUT, I seriously think you can forget about all that trouble by installing thom thom's super duper [anchor= goto=http://sketchucation.com/forums/viewtopic.php?t=15491:39dvbm3b]vray tools plugin[/anchor:39dvbm3b]. I imagine you don't even need vray for it to work. You can see, and export any size picture you want without the need to adjust toolbars or screens.
                            Good Luck
                            FlexTools - Super Quick Windows, Doors, Slats...
                              smuncky
                              Interesting enough, I had the scattering of toolbars in 2013 recently. The file I was working on froze so I had to force close it. Open it up again and all the toolbars are unlocked from their positions. Seems to happen randomly but only when it freezes.
                              Anyone else getting this in 2013?
                              • xennonX Offline
                                xennon
                                I can't believe that they STILL have not included the option to lock the toolbars - even in the very latest v2015 32 or 64 bit versions. They brag about all the "new features" but neglect to include the simplest and probably most convenient feature that ANY app can have - the ability to lock those damn toolbars!! WTF!?
                                • K Offline
                                  karllarsen
                                  How is it even possible for any software company to be this clueless...
                                  Less is more.
                                    Karl, are you still using SketchUp 8 like your profile indicates?
                                    Funny. I've been using SketchUp for a little over 14 years. I've never once wished for an option to lock toolbars. It just isn't a problem for me. They always stay where I put them
                                    • I Offline
                                      iamraj
                                      i am old to Autocad & Photoshop but new to SU. Learning SU is easier but using it much tough and frustrating. Many of its feature have complete dependency on Plug ins and many yet to introduce. One of them is
                                      1. Unlocked Toolbar- Here you cant create User Interface profile too.
                                      and another is
                                      2) Unable to create your own Hotkeys. Unlike AutoCad where you can create your own Hotkeys as per your use and convenience like i do have Hot Keys, R for rectangle, RR for rotate, RRR for render but here in SU you can use only one letter not more than that thus requires two fingers or two hands to use ALt or CTRL with letter. in AutoCAd i have clean screen but in SU screen is full of toolbars
                                      SU 2017. V-Ray 3.4.
                                      Windows 10 64 bit OS.
                                      System Intel i3,
                                      4GB RAM, 1TB HDD.
                                      Redone Graphic Card.
                                      (No data plan on Desktop).
                                      • 5 / 5
