    How can we unsplit edges
    7 Posts 4 Posters 1.3k Views 4 Watching
    • simon le bonS
      simon le bon
      Very often i would like unsplit edges of a ligne: for example to find by inference the middle of a divided ligne, or else,in the purpose of use offset tool or follow me tool vith complexe curved line, it need to be undivided. And etc..
      In another way, i am searching the inverse process of "intersection with selection"
      Any idea ? Thanks
      • T
        taulajoe
        one way to connect to parts of a line:
        make a line from the connecting point to any direction, then delete this line
        now there is just one line left 😄
        bernhard
        • simon le bonS
          simon le bon
          Work great;; Thanks bernhard
          Well! I would like to know if exist a menu item working with the powerful selection tool to reverse Intersect With Model or Intersect With Selection .:.
          • simon le bonS
            simon le bon
            I have found a script on Ruby Library Depot/EDITING Section called repair_broken_lines.rb It do exactly what it says.
            But for a cercle or an arc exploded, as far i can see, no way to go back with a single entitie... Strange, cause we often need it.
            • TIGT
              You must reform a broken arc or circle by drawing over it by hand. There is 'no (easy) way' of doing it automatically...
              • GaieusG
                You can always use the weld.rb plugin although it will only weld the broken arc/circle into a polyline not an arc or circle entity.
                • simon le bonS
                  simon le bon
                  Dear Gaieus and Tig,
                  This pack is beginning to make a good toolkit. It seems that Weld.rb by Rick Wilson is responsible for a large number of developments: Chamfer_Along_Path.rb , PipeAlongPath.rb , ExtrudeAlongPath.rb , TubeAlongPath.rb etc,,, where it appears that mister Tig is not for nothing...
                  simonlebon
