How can we unsplit edges
Very often i would like unsplit edges of a ligne: for example to find by inference the middle of a divided ligne, or else,in the purpose of use offset tool or follow me tool vith complexe curved line, it need to be undivided. And etc..
In another way, i am searching the inverse process of "intersection with selection"Any idea ? Thanks
one way to connect to parts of a line:
make a line from the connecting point to any direction, then delete this line
now there is just one line leftbernhard
Work great;; Thanks bernhard
Well! I would like to know if exist a menu item working with the powerful selection tool to reverse Intersect With Model or Intersect With Selection .:.
I have found a script on Ruby Library Depot/EDITING Section called repair_broken_lines.rb It do exactly what it says.
But for a cercle or an arc exploded, as far i can see, no way to go back with a single entitie... Strange, cause we often need it.
You must reform a broken arc or circle by drawing over it by hand. There is 'no (easy) way' of doing it automatically...
You can always use the weld.rb plugin although it will only weld the broken arc/circle into a polyline not an arc or circle entity.
Dear Gaieus and Tig,
This pack is beginning to make a good toolkit. It seems that Weld.rb by Rick Wilson is responsible for a large number of developments: Chamfer_Along_Path.rb , PipeAlongPath.rb , ExtrudeAlongPath.rb , TubeAlongPath.rb etc,,, where it appears that mister Tig is not for nothing...
simonlebon
