    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
      AlainBo
      Hi Scott,
      Some of us, and me, experienced such kind of problems but it was due to a "small" scale which causes the plugin to not be able to correctly compute the extruded faces.
      We don't know how big your model is and its size and its edges size but your experience is interesting and could give us something else to think about in case of problems.
      Thx,
      Alain
      • jgbJ Offline
        jgb
        Tig
        A suggestion if I may. ๐ŸŽ‰
        Sometimes JPP can take "forever" to complete, even seem like it's hung. Other times it zips along in a sprightly fashion. Seems no connection to complexity, I've had a 30 face push take about 3 minutes and a 150 face push take about 40 seconds.
        However on more than one long push a very few seconds into the push I realized I was in feet and not inches, so the result would have been scrapped in any event. I normally push/pull the pre-surface well beyond the dimension I want and key in the actual dimension, then hit enter twice, so I don't get a visual clue to my error. Other times I just don't want to wait what will be a very long wait.
        JPP needs a cancel or quit button. ๐Ÿ’ญ
        jgb
          @jgb said:
          Tig
          Are you suggesting this should be done by TIG?
            JPP is not mine...
            Also quitting a script once it starts is difficult.
            The tool's author [Fredo] does have some tricks to quit a running tool [ESC?] - but this is at the expense of splitting it into sub-packets of processing, so at each changeover a key-press can be spotted, which slows down the overall processing time noticeable...
            There's no such thing as a free-lunch... ๐Ÿ˜•
            • fredo6F Offline
              fredo6
              I plan to refresh the JPP script and address the problem of generation of the geometry. JPP is quite old now and since then, I have been able to understand better how SU works for performance and reliability.
              Fredo
              • dereiD Offline
                derei
                Fredo
                ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
                DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
                • jgbJ Offline
                  jgb
                  @dave r said:
                  @jgb said:
                  Tig
                  Sorry, No slight intended. ๐Ÿ˜ณ
                  I sometimes get confused which Ruby Magician did what.
                  Also; In my experience (dated for sure) Key Down Polling inside an outer or mid loop should not really affect performance, unless you are forced to use a nested call.
                  jgb
                    Problem is that you cannot poll keys within the SU API.
                    • jgbJ Offline
                      jgb
                      OK, I stand corrected. ๐Ÿ˜Ž
                      Key polling is a fundamental function. Can't believe those who designed the API left that one out. ๐Ÿ˜ฎ
                      jgb
                        There is much to be desired in the API...
                          liuwuran
                          Thanks a lot ,very useful ๐Ÿ˜
                            Takashi_Komuro
                            What advantages and functions of the Joint Push Pull ?
                              Read the guidance notes on the first page of this thread, there is even a help-pdf file you can download...
                              There are also examples throughout the thread...
                              Put simply, by using JPP you can 'extrude' preselected facets that form a surface so they have a 'thickness', in ways that are not possible using the native PushPull tools...
                                The only automatic easy way to make thickness! ๐Ÿ˜„
                                • jgbJ Offline
                                  jgb
                                  The major advantage of JPP over SU native Push/Pull is that where SU PP only works on individual flat faces, JPP works on combined curved surfaces made up from many flat faces.
                                  There are 3 versions of JPP, where the thickening occurs perpendicular to the selected surface, or you can set an angle to the direction of thickening. The third is a variation of SU's PP, which I never use so no comment on its functionality.
                                  A few tips to consider before using JPP.
                                  1. Make sure you do an "Orient Faces" before using the tool.
                                    IMHO that should be a default function within JPP.
                                  2. Turn ON hidden lines only if you want to do a selection of faces on a surface.
                                    Turn OFF hidden lines if you want to do the total surface.
                                    Alternatively, turn ON hidden lines and make the perimeter of the selected faces soft/smooth lines SOFT. That will define a surface in one selection when Hidden Lines are OFF.
                                  3. When JPP does its thing, check the corners. Most of the lines JPP creates along the thickness are soft/smooth, and the sharp corners may not be hard, if desired. Just <Shift-CTRL-Delete> those lines to make them hard.
                                  4. Attempting to JPP to a thickness in relation to some object in the drawing may not give you the desired thickness when done.
                                    The better way is to JPP beyond the desired thickness, INSPECT the shape for integrity (purple lines), then type to the VCB the exact thickness dimension desired, BEFORE you double click (or <Enter> twice).
                                  jgb
                                    Mra
                                    This tool crashes heaps with 2013.
                                    Repro steps:
                                    Create square.
                                    Group it
                                    Go into group
                                    Extrude it
                                    Exit group = crash.
                                      Do you have plugins installed? Tried disabling them temporarily to see if it might be one of them causing it?
                                        Sounds like some other script like Vray-beta or one of the half-baked new BIM tools is loading... and that is crashing SketchUp when this JPP does a legitimate operation.
                                        It's usually from messing with native class/methods or having poorly constructed EntitiesObservers etc that kick in during other tools legit operations and cause the crash.
                                        If you do find the culprit script then please let us know AND tell that scripts author about it too, so that they might then try to fix it...
                                          Mra
                                          You're a sharp man. Yes, I am apart of the V-Ray beta. Pretty sure you're right about it too.
                                            Mra
                                            Confirmed: It is V-Ray, I'll let them know.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
