    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      Here it is [v7]...
      For some reason it stalled at 5% and took 9 mins this time ๐Ÿ˜’
      No problem! I did have other things running this time...
      CurtainSU.skp
      • W Offline
        wtrouser
        TIG - many thanks again for the extra help! It's greatly appreciated.
          AlainBo
          You are right, I didn't tried to scale it up by 100. It was the trick.
          I got it in les than 2 mns.
            All Sketchup processes that create new edges/facets [pushpull, followme, intersect, scripted tools doing similar things], can fail if the resultant geometry is tiny.
            Sketchup/OpenGL cannot cope with things < ~0.1mm.
            There are tolerances built in to allow two points in space that are not exactly coincident to be regarded as 'equal', otherwise it'd be difficult to do many operations as calculations must always be somewhat approximated. This can mean that two very very close points might not form a line between them, as Sketchup expects two different points, the missing line then fails to split an existing face during an intersect or to complete a loop for a face, which is then missing...
            Using a tool like JPP on a very complex mesh with small resultant parts [like this thin curtain] might end up with some tiny bits of geometry/faces missing - it can even splat given the right errors...
            The trick of Scaling things up x10 or x100 etc, creating the facets etc, will avoid the tininess issues.
            Any Scaling of the tiny parts back down afterwards isn't an issue - very tiny things can exist, it's just their creation that causes issues.
            Incidentally, there can be similar issues with very very large objects too, because the enormous numerical values get ever approximated too... In that case scale down, process then scale up.
            Sketchup is really designed to model building and related objects.
            So doing complex modeling on the innards of a swiss-wristwatch [or an entire city] at 'real size' can/will cause issues at some point...
            • W Offline
              wtrouser
              That makes sense to me... thanks for the explanation. My issue is that I had already tried scaling the model up x100, and it still froze. Additionally, I've only had JPP work for me a small percentage of the time in the past, with models of varying sizes/complexities. It may simply be that I've got the wrong computer/SU version/plugin version combo. Until I'm willing to pony up the money for upgraded hardware/software, I really can't complain too much.
              [edit] This might help... after I hit 'go' on a JPP process, the computer will think for a bit, the plugin status bar at the bottom will progress left to right, and the faces I'm trying to pull will eventually appear. The cursor will change back to a pointer and all will seem well. After I then move the cursor, whether right after the process or even several hours later, the pointer will change into a spinning pinwheel and I'm frozen. It seems like my computer might be freezing after the process is done.
                AlainBo
                Hi wtrouser,
                I don't know if that could be caused by SU7, but on SU8, if we take care to be in requested conditions as TIG explained, it seems to work fine. Annyway, if we make the same job on the same model several times, we can see that we cannot trust the progress bar. Sometimes it freezes at different percentages. but as the process seems to ends correctly, that's not a problem.
                So, unfortunately, you may have to wait to upgrade to SU8 to get it working correctly. ๐Ÿ˜ž.
                Regards,
                Alain
                  srancsik
                  Totally agree, THE MOST USEFUL PLUGIN ALL OVER!!!
                  Thank you, thank you, thank you!!!
                    scottbattersby
                    Hi All
                    I had a problem with Joint Push Pull. I solved it as I was composing this post, and decided to post the solution in case anyone else is stuck.
                    I was trying to use Joint Push Pull to thicken a curved shell into a 3D object.
                    In the attached screenshot you can see I have selected all the faces in the shell and invoked the Joint Push Pull.
                    PROBLEM
                    Only some of the selected faces are being extruded. The rest are just being ignored.
                    Win XP Pro SP3, 32 bit machine 4.00GB RAM installed.
                    Sketchup 8.0.16846
                    JointPushPull v2.0b
                    SOLUTION
                    In plugins\JPP_Dir_20\jointpushpull_main.rb
                    Change MAX_VISUAL_FACES = 1000
                    to MAX_VISUAL_FACES = 10000 (or whatever is a reasonable number for your model)
                    Hope that helps someone ๐Ÿ˜„
                    Cheers
                    Scott
                      AlainBo
                      Hi Scott,
                      Some of us, and me, experienced such kind of problems but it was due to a "small" scale which causes the plugin to not be able to correctly compute the extruded faces.
                      We don't know how big your model is and its size and its edges size but your experience is interesting and could give us something else to think about in case of problems.
                      Thx,
                      Alain
                      • jgbJ Offline
                        jgb
                        Tig
                        A suggestion if I may. ๐ŸŽ‰
                        Sometimes JPP can take "forever" to complete, even seem like it's hung. Other times it zips along in a sprightly fashion. Seems no connection to complexity, I've had a 30 face push take about 3 minutes and a 150 face push take about 40 seconds.
                        However on more than one long push a very few seconds into the push I realized I was in feet and not inches, so the result would have been scrapped in any event. I normally push/pull the pre-surface well beyond the dimension I want and key in the actual dimension, then hit enter twice, so I don't get a visual clue to my error. Other times I just don't want to wait what will be a very long wait.
                        JPP needs a cancel or quit button. ๐Ÿ’ญ
                        jgb
                          @jgb said:
                          Tig
                          Are you suggesting this should be done by TIG?
                            JPP is not mine...
                            Also quitting a script once it starts is difficult.
                            The tool's author [Fredo] does have some tricks to quit a running tool [ESC?] - but this is at the expense of splitting it into sub-packets of processing, so at each changeover a key-press can be spotted, which slows down the overall processing time noticeable...
                            There's no such thing as a free-lunch... ๐Ÿ˜•
                            • fredo6F Offline
                              I plan to refresh the JPP script and address the problem of generation of the geometry. JPP is quite old now and since then, I have been able to understand better how SU works for performance and reliability.
                              • dereiD Offline
                                derei
                                ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
                                DESIGNER AND ARTIST DEREI.UK
                                • jgbJ Offline
                                  jgb
                                  @dave r said:
                                  @jgb said:
                                  Tig
                                  Sorry, No slight intended. ๐Ÿ˜ณ
                                  I sometimes get confused which Ruby Magician did what.
                                  Also; In my experience (dated for sure) Key Down Polling inside an outer or mid loop should not really affect performance, unless you are forced to use a nested call.
                                  jgb
                                    Problem is that you cannot poll keys within the SU API.
                                    • jgbJ Offline
                                      jgb
                                      OK, I stand corrected. ๐Ÿ˜Ž
                                      Key polling is a fundamental function. Can't believe those who designed the API left that one out. ๐Ÿ˜ฎ
                                      jgb
                                        There is much to be desired in the API...
                                          liuwuran
                                          Thanks a lot ,very useful ๐Ÿ˜
                                            Takashi_Komuro
                                            What advantages and functions of the Joint Push Pull ?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
