    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
      JPP is not mine...
      Also quitting a script once it starts is difficult.
      The tool's author [Fredo] does have some tricks to quit a running tool [ESC?] - but this is at the expense of splitting it into sub-packets of processing, so at each changeover a key-press can be spotted, which slows down the overall processing time noticeable...
      There's no such thing as a free-lunch... ๐Ÿ˜•
      • fredo6F
        I plan to refresh the JPP script and address the problem of generation of the geometry. JPP is quite old now and since then, I have been able to understand better how SU works for performance and reliability.
        • dereiD
          derei
          ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
          DESIGNER AND ARTIST DEREI.UK
          • jgbJ
            jgb
            @dave r said:
            @jgb said:
            Tig
            A suggestion if I may. ๐ŸŽ‰
            JPP needs a cancel or quit button. ๐Ÿ’ญ
            Are you suggesting this should be done by TIG?
            Sorry, No slight intended. ๐Ÿ˜ณ
            I sometimes get confused which Ruby Magician did what.
            Also; In my experience (dated for sure) Key Down Polling inside an outer or mid loop should not really affect performance, unless you are forced to use a nested call.
            jgb
              Problem is that you cannot poll keys within the SU API.
              • jgbJ
                jgb
                OK, I stand corrected. ๐Ÿ˜Ž
                Key polling is a fundamental function. Can't believe those who designed the API left that one out. ๐Ÿ˜ฎ
                jgb
                  There is much to be desired in the API...
                  • L
                    liuwuran
                    Thanks a lot ,very useful ๐Ÿ˜
                    • T
                      Takashi_Komuro
                      What advantages and functions of the Joint Push Pull ?
                        Read the guidance notes on the first page of this thread, there is even a help-pdf file you can download...
                        There are also examples throughout the thread...
                        Put simply, by using JPP you can 'extrude' preselected facets that form a surface so they have a 'thickness', in ways that are not possible using the native PushPull tools...
                          The only automatic easy way to make thickness! ๐Ÿ˜„
                          • jgbJ
                            jgb
                            The major advantage of JPP over SU native Push/Pull is that where SU PP only works on individual flat faces, JPP works on combined curved surfaces made up from many flat faces.
                            There are 3 versions of JPP, where the thickening occurs perpendicular to the selected surface, or you can set an angle to the direction of thickening. The third is a variation of SU's PP, which I never use so no comment on its functionality.
                            A few tips to consider before using JPP.
                            1. Make sure you do an "Orient Faces" before using the tool.
                              IMHO that should be a default function within JPP.
                            2. Turn ON hidden lines only if you want to do a selection of faces on a surface.
                              Turn OFF hidden lines if you want to do the total surface.
                              Alternatively, turn ON hidden lines and make the perimeter of the selected faces soft/smooth lines SOFT. That will define a surface in one selection when Hidden Lines are OFF.
                            3. When JPP does its thing, check the corners. Most of the lines JPP creates along the thickness are soft/smooth, and the sharp corners may not be hard, if desired. Just <Shift-CTRL-Delete> those lines to make them hard.
                            4. Attempting to JPP to a thickness in relation to some object in the drawing may not give you the desired thickness when done.
                              The better way is to JPP beyond the desired thickness, INSPECT the shape for integrity (purple lines), then type to the VCB the exact thickness dimension desired, BEFORE you double click (or <Enter> twice).
                            jgb
                              Mra
                              This tool crashes heaps with 2013.
                              Repro steps:
                              Create square.
                              Group it
                              Go into group
                              Extrude it
                              Exit group = crash.
                                Do you have plugins installed? Tried disabling them temporarily to see if it might be one of them causing it?
                                  Sounds like some other script like Vray-beta or one of the half-baked new BIM tools is loading... and that is crashing SketchUp when this JPP does a legitimate operation.
                                  It's usually from messing with native class/methods or having poorly constructed EntitiesObservers etc that kick in during other tools legit operations and cause the crash.
                                  If you do find the culprit script then please let us know AND tell that scripts author about it too, so that they might then try to fix it...
                                    Mra
                                    You're a sharp man. Yes, I am apart of the V-Ray beta. Pretty sure you're right about it too.
                                      Mra
                                      Confirmed: It is V-Ray, I'll let them know.
                                      • bulbaB
                                        bulba
                                        i've downloaded this plugin months ago and forgot to say thanks..
                                        THANKS A LOT Fredo ๐Ÿ˜„
                                        been using this regularly
                                          rempeyeks
                                          i've got error message here.
                                          is that joint push pull dont work in sketchup 2013?
                                            Have you properly installed ALL of the latest versions of Fredo's tools AND LibFredo...
                                            He upgraded his Lib and several of his tools to work with v2013...
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
