    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 79.7k Views 32 Watching
    • JVT_LTDJ Offline
      JVT_LTD
      Many thanks to this... Its truly functional...
      • U Offline
        unal
        teşekkürler:)
        • V Offline
          vaaron21
          @tig said:
          @sijeljaaf said:
          Thank you so much but it doesn't work with my sketchup pro 8
          You have to explain how it doesn't work...
          Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
          Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
          It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
            If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
              jorgesalros
              Works fine, well done
              • F Offline
                function
                I'm not seeing the context menu in 2014... this plugin is great!
                • bazB Offline
                  baz
                  Me too
                  • BoxB Offline
                    Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
                    Tig explains how here.
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=12354%26amp;start=60#p513679
                      Didier has agreed that I might update some of his Plugins available from the PluginStore...
                      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr It is compatible with v2014 and v2015.
                      • E Offline
                        Emersonvip
                        thanks! very good. 5 stars.
                          m93a
                          Automatic face reverser? Wonder how it works on a mobius strip...
                          • boofredlayB Offline
                            boofredlay
                            It would generate perpetual energy like the cat and toast in this video.
                            • HornOxxH Offline
                              HornOxx
                              Thanks for this Plugin 👍
                              Great video - i love this physics fun 😄 😄
                              never trust a skinny cook
                                Sidharth ravva
                                This does not work. I use skp pro 2018. Please include a video on how to use it.
                                • P Offline
                                  proem Newcomers
                                  Hi!
                                  Can someone update this plugin or recommend one with the same effect. I found Fredo tools but I don't want to install all the stuffs that I don't use.
                                  Thanks.
                                  • 2 / 2
