    [Obsolete] Joint Push Pull
    45 Posts 27 Posters 14.2k Views 27 Watching
      Daniel S
      I still can´t believe this! It works great with high poly models and makes brillants results. Incredible to make this inside SketchUp.
      1655 faces in 160 seconds 😄 😄
      Daniel S
        GreyHead
        Fantastic, enjoyed playing with it. Now I need to find a place to use it.
        Thanks, Bob
        PS Confirming bellwells image earlier, if you use Joint push-pull on non-contiguous faces of an polygon block then the side of the extrusions have a mix of angles, some are rectilinear (as from the Vector extrusion) some are aligned to the center of the block.
        • H Offline
          Howard leslie
          Fredo,
          Just been having a quick go with your Joint Push Pull Script.
          First impressions - Very impressive. Will be really useful.
          Joint Push Pull - Excellent
          Vector Push Pull - a really good idea to include this also - Excellent
          Manual / Tutorial PDF - Very Comprehensive / Well written and easy to understand.
          I'm not too sure about the "Reverse Green Axis (-Y)" - you've assumed that the Green axis will be orientated away from the observer.
          IMHO I wouldn't assume that.
          I think it would be best if it was "Green Axis (+Y)" - like the other axes.
          (Crops up in a couple of dialog boxes / dropdowns).
          For the Vector Push Pull Method, it might be useful to somehow include an option for "interactive" - so users can push pull on screen (eg along the red axis for example).
          (I'm not sure if this is possible).
          Fantastic Script.
          Belated Thanks for your BezierSpline Script - also excellent
          Used in this Tutorial:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=22&t=4208
          Regards
          Howard Leslie
          • EdsonE Offline
            Edson
            hi fredo,
            fantastic! what can i say that the others have not said? anyway, just want to thank you once more for a great script which will be of great usefulness to all of us.
            and congratulations on your generosity.
            regards,
            http://www.mahfuz.arq.br
              Gjenio
              Daniel S
              Hey Daniel how did you do that chair? With soap skin and bubble?
              • CadFatherC Offline
                CadFather
                Wo... (didn't even finish the word playing with Didier's component spray that something else comes up!) ...oW
                thanks Fredo
                (now i just need a dialog box to automate english weather control and embed that in SU)..
                • boofredlayB Offline
                  boofredlay
                  This is very generous, thank you.
                  • fredo6F Offline
                    Thanks, Bob
                    GreyHead
                    Thanks for appreciation.
                    Regarding the non contiguous faces, what you get is normal, because it depends on what you want to achieve. If you wish the borders to be perfectly normal, you must select NO in the option "Extent influence to non-selected neighbors", as explained in the Tutorial, in section 1.7, p.12. Otherwise, the macro compute the direction as if you would also extrude the neighbouring face. Unless I missed something....
                    • urgenU Offline
                      urgen
                      Very good script 👍 , but in SU5 unfortunately does not work ... 😢
                      --pupil forever...------
                      • fredo6F Offline
                        Can you try this version. It may be slower however!
                        Supposed to work in Sketchup 5 too
                          GreyHead
                          Fredo, I do think that there is something here that is not consistent with "as if you would also extrude the neighbouring face." See this diagram (plan view of an extruded dodecagon). Notice that the two end extrusions of the five contiguous faces are different. (I did these both on the same dodecagon for simplicity but I get the same result if I do them on separate objects so I don't think there is interference between them.)
                          Scratching my head here but I don't see an obvious pattern.
                          Bob
                          Contiguous and non-contiguous face extrusions
                          • ton baetenT Offline
                            ton baeten
                            Fredo,
                            I can just add to the rest: you have created a very nice and very usefull ruby. Thank you very much for sharing this with us. I am not an architect but a productdesigner and do a lot with double-curved shapes and surfaces in SU (6-pro), on a mac.
                            Today, after carefully reading your tutorial (which also is a nice piece of work), I have taken quite some time to play with your ruby and I have tested it with all kind of shapes and surfaces.
                            First: I am more impressed than I thought I would be. As long as you start with a clean surface, your ruby works without any problem at all. I really went to limits and over. Going over fysical limits creates impossible and unexpected shapes, but your ruby never stopped working.
                            Second: I can reassure you, your ruby performes without any hesitation on (my) mac.
                            Third: In your tutorial you mention your ruby might still be a bit slow. To my opinion, your ruby performs oke. Yes, if you start with curves, arcs, ellipses divided in 360 or more segments and create surfaces with 100,000's of edges,faces, instances your ruby needs time. But not more than others. As we all as pro-users know, such's details aren't necessary to create nice shapes in SU.
                            Fouth: as all tools, also your ruby has its own limits. But, in the 3D-world it is impossible to create a tool that thinks for us. Your ruby is a very usefull tool, makes quite some SU actions easier and much faster to perform. Together with existing SU functionalities (standard and rubies) it enhances the possibilities of my preferred piece of 3D software: SketchUp
                            By the way:
                            The number of powerfull and usefull ruby's is increasing rapidly and we have seen some promesing developments almost ready to become available to all of us. If they would all be packed together in nice way, we would already have a nice and powerfull new SU 7 pro. Looking at my SU screen, compaired to beginning 2007, I look at something quite different (and I feel happy about it).
                            Thanks to you all !!
                            I start thinking we are making life difficult for all those folks in Boulder, working on a really new SU 7.
                            What can we expect from them that will really surprice us. Of course, there are still more than enough wishes and expectations, but I am getting more and more curious.
                            Again, Fredo, also you have contributed to my new SU screen.
                            Many thanks to you and all other great ruby-artist to make this possible.
                            greetings,
                            Ton
                              CadFather
                              not sure what's happening but on my pc JPP seems to have clashed with beziers, either some icons disappear altogether, or the curves cannot be drawn. - i have noticed this before a couple of times while working on the rubymenus thus think the weakness might have more to do with beziers than jpp
                              EDIT: or it may be me of course!
                                bellwells
                                Fredo6,
                                Your new script works in SU5 Thank you, thank you!!!
                                A couple of minor spelling comments (I have already made these changes in my system.):
                                1. Shouldn't "Extent influence to non-selected neighbors" read "Extend....?
                                2. "Custom Plan..." should read "Custom Plane..."
                                Edit: I hope you don't mind that I made the above changes to your script on my system.
                                Ron
                                • urgenU Offline
                                  urgen
                                  ...Unfortunately I have former problems... 😕
                                  • fredo6F Offline
                                    Bob
                                    [attachment=2:2u7nlb8r]<!-- ia2 -->push-pull.png<!-- ia2 -->[/attachment:2u7nlb8r]
                                    This abnormal behavior is actually almost 'normal'.
                                    Because the polygon has 12 segments, the angle between the normals of 2 contiguous edges is exactly 30 degree, which is the default value of the Angle of Influence. So depending on the rounding up, some outside faces do influence, some others do not.
                                    You should change the value of the Angle of influence to either 29 Degree (to have strict perpendicular borders) or to 31 degrees, to have them all radial.
                                    Angle of influence = 29 degree
                                    Angle of Influence = 31 degree
                                      GreyHead
                                      Ahhhhh . . . thank you. Bob
                                      • fredo6F Offline
                                        Could you turn on the Ruby Console and see what it says (or does not say)
                                        • urgenU Offline
                                          urgen
                                          ..Ruby console...
                                            bellwells
                                            urgen,
                                            I had the exact same problem until I downloaded Fredo6's SU5 script. Are you sure you've installed the right script?
                                            Ron
                                            • 2 / 3
