    [Obsolete] Joint Push Pull
    45 Posts 27 Posters 12.9k Views 27 Watching
    • EdsonE Offline
      Edson
      hi fredo,
      fantastic! what can i say that the others have not said? anyway, just want to thank you once more for a great script which will be of great usefulness to all of us.
      and congratulations on your generosity.
      regards,
      http://www.mahfuz.arq.br
        Gjenio
        @daniel s said:
        I still can´t believe this! It works great with high poly models and makes brillants results. Incredible to make this inside SketchUp.
        1655 faces in 160 seconds 😄 😄
        Daniel S
        Hey Daniel how did you do that chair? With soap skin and bubble?
        • CadFatherC Offline
          CadFather
          Wo... (didn't even finish the word playing with Didier's component spray that something else comes up!) ...oW
          thanks Fredo
          (now i just need a dialog box to automate english weather control and embed that in SU)..
          • boofredlayB Offline
            boofredlay
            This is very generous, thank you.
            • fredo6F Offline
              @greyhead said:
              Fantastic, enjoyed playing with it. Now I need to find a place to use it.
              Thanks, Bob
              PS Confirming bellwells image earlier, if you use Joint push-pull on non-contiguous faces of an polygon block then the side of the extrusions have a mix of angles, some are rectilinear (as from the Vector extrusion) some are aligned to the center of the block.
              GreyHead
              Thanks for appreciation.
              Regarding the non contiguous faces, what you get is normal, because it depends on what you want to achieve. If you wish the borders to be perfectly normal, you must select NO in the option "Extent influence to non-selected neighbors", as explained in the Tutorial, in section 1.7, p.12. Otherwise, the macro compute the direction as if you would also extrude the neighbouring face. Unless I missed something....
              • urgenU Offline
                urgen
                Very good script 👍 , but in SU5 unfortunately does not work ... 😢
                --pupil forever...------
                • fredo6F Offline
                  Can you try this version. It may be slower however!
                  Supposed to work in Sketchup 5 too
                    GreyHead
                    Fredo, I do think that there is something here that is not consistent with "as if you would also extrude the neighbouring face." See this diagram (plan view of an extruded dodecagon). Notice that the two end extrusions of the five contiguous faces are different. (I did these both on the same dodecagon for simplicity but I get the same result if I do them on separate objects so I don't think there is interference between them.)
                    Scratching my head here but I don't see an obvious pattern.
                    Bob
                    Contiguous and non-contiguous face extrusions
                    • ton baetenT Offline
                      ton baeten
                      Fredo,
                      I can just add to the rest: you have created a very nice and very usefull ruby. Thank you very much for sharing this with us. I am not an architect but a productdesigner and do a lot with double-curved shapes and surfaces in SU (6-pro), on a mac.
                      Today, after carefully reading your tutorial (which also is a nice piece of work), I have taken quite some time to play with your ruby and I have tested it with all kind of shapes and surfaces.
                      First: I am more impressed than I thought I would be. As long as you start with a clean surface, your ruby works without any problem at all. I really went to limits and over. Going over fysical limits creates impossible and unexpected shapes, but your ruby never stopped working.
                      Second: I can reassure you, your ruby performes without any hesitation on (my) mac.
                      Third: In your tutorial you mention your ruby might still be a bit slow. To my opinion, your ruby performs oke. Yes, if you start with curves, arcs, ellipses divided in 360 or more segments and create surfaces with 100,000's of edges,faces, instances your ruby needs time. But not more than others. As we all as pro-users know, such's details aren't necessary to create nice shapes in SU.
                      Fouth: as all tools, also your ruby has its own limits. But, in the 3D-world it is impossible to create a tool that thinks for us. Your ruby is a very usefull tool, makes quite some SU actions easier and much faster to perform. Together with existing SU functionalities (standard and rubies) it enhances the possibilities of my preferred piece of 3D software: SketchUp
                      By the way:
                      The number of powerfull and usefull ruby's is increasing rapidly and we have seen some promesing developments almost ready to become available to all of us. If they would all be packed together in nice way, we would already have a nice and powerfull new SU 7 pro. Looking at my SU screen, compaired to beginning 2007, I look at something quite different (and I feel happy about it).
                      Thanks to you all !!
                      I start thinking we are making life difficult for all those folks in Boulder, working on a really new SU 7.
                      What can we expect from them that will really surprice us. Of course, there are still more than enough wishes and expectations, but I am getting more and more curious.
                      Again, Fredo, also you have contributed to my new SU screen.
                      Many thanks to you and all other great ruby-artist to make this possible.
                      greetings,
                      Ton
                        CadFather
                        not sure what's happening but on my pc JPP seems to have clashed with beziers, either some icons disappear altogether, or the curves cannot be drawn. - i have noticed this before a couple of times while working on the rubymenus thus think the weakness might have more to do with beziers than jpp
                        EDIT: or it may be me of course!
                          bellwells
                          Fredo6,
                          Your new script works in SU5 Thank you, thank you!!!
                          A couple of minor spelling comments (I have already made these changes in my system.):
                          1. Shouldn't "Extent influence to non-selected neighbors" read "Extend....?
                          2. "Custom Plan..." should read "Custom Plane..."
                          Edit: I hope you don't mind that I made the above changes to your script on my system.
                          Ron
                          • urgenU Offline
                            urgen
                            ...Unfortunately I have former problems... 😕
                            • fredo6F Offline
                              Bob
                              [attachment=2:2u7nlb8r]<!-- ia2 -->push-pull.png<!-- ia2 -->[/attachment:2u7nlb8r]
                              This abnormal behavior is actually almost 'normal'.
                              Because the polygon has 12 segments, the angle between the normals of 2 contiguous edges is exactly 30 degree, which is the default value of the Angle of Influence. So depending on the rounding up, some outside faces do influence, some others do not.
                              You should change the value of the Angle of influence to either 29 Degree (to have strict perpendicular borders) or to 31 degrees, to have them all radial.
                              Angle of influence = 29 degree
                              Angle of Influence = 31 degree
                                GreyHead
                                Ahhhhh . . . thank you. Bob
                                • fredo6F Offline
                                  Could you turn on the Ruby Console and see what it says (or does not say)
                                  • urgenU Offline
                                    urgen
                                    ..Ruby console...
                                      bellwells
                                      urgen,
                                      I had the exact same problem until I downloaded Fredo6's SU5 script. Are you sure you've installed the right script?
                                      Ron
                                      • fredo6F Offline
                                        I am not sure it is an interference with JPP, but there were a few bugs in Bezierspline regarding inference, and in some situation it could create the impossibility to position the starting point at the origin.
                                        I made some fixes, and also incorporate the Portuguese translation (many thanks to Edson). Didier just published the new version of Bezierspline on his site today.
                                          CadFather
                                          Many Thanks Fredo - will check it out
                                          • urgenU Offline
                                            urgen
                                            Hi all! script works in SU5.0.260.and no works in SU5.0.232. 😲 I have eliminated this problem (instal SU5.0.260) 😍
                                            thanks all for support., I understand this now...many-many-many thanks to Fredo6 ! 👍
                                            • 2 / 3
