Mirror.rb blues
I am coming back with the same problem already mentioned by me on another thread:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=127&t=1833
Since nobody came to my rescue and the problem persists I am here asking again for help.objects do get mirroed but never as expected. the attached pict shows the original box, the reference line, the spot where the mirrored copy was expected to be and the spot it actually landed.
any thoughts as to why mirror.rb is behaving like that?
regards.
edson
Edson,
You know that mirror.rb uses one, two, or three points to define the reflection, right?
Your example behaves as I would expect--and as I have just verified by experiment--when you enter a single point, just about at the intersection of the reference line and the red axis. If you wish the mirror image to appear below the ground plane but on the same side of the red axis you would need two points on the refernce line. If you want the mirror image to appear directly across the reference line and above the ground plane, you would need three points, two on the reference line and one above it.
You never mentioned how many points you're using. So how many?
-Gully
[Gully Foyle]
Edson,
See attached jpg
Mirror Script - definitely one of the most useful Scripts around.
(Thank you TIG).
Usage:
Yes, you can use 1,2 or 3 points.
My Top Tip would be, always use 3 points.
(certainly until you get used to it).
That way results are more predictable.
Just imagine where you would have to place a real mirror to get the desired result you want.
Then go and click on 3 corners of that Mirror and Voila, geometry is perfectly mirrored.
You don't need to actually draw the mirror as I've shown in the example !!! - just click the 3 points.
Hope this helpsHoward L'
Edson,
-Gully
hi gully,
thanks for the help. yes, i knew that but must confess I had not understood it well and mixed everything up. i was trying to mirror the box by entering two points and pressing return. i never entered that third point. now i realize i was reproducing a procedure that would work in another application.
as it happens with many scripts, the usage explanation at the beginning of mirror.rb is not very clear (or so it seemed to me). they way you explained it is very clear, though, and i could make it work exactly as you described it.
thanks again.
best wishes.
edson
Edson,
Usage:
hey, howard
wonderfully clear explanation. your mirror analogy is just perfect. thanks a lot.
regards.
edson
did you try the Render Plus Mirror tool? It works the way you expect.
edit; nevermind,I forgot you were on a mac, just came to me.
thanks, anyway.
edson
I say thank you for the drawing
humanticnc -
Thank you Howard. I am just starting to use ruby scripts and was playing with the mirror.rb last night and getting some pretty strange results. Your pic explains it all. "A picture is worth a thousand words" Thanks from the snowy south.
Is there a hope for this script to have a toolbar button sometime?
I am using it more and more and find myself hunting for the button too often.Thanks.
So much to do and so little time...
I have a shortcut key that mirrors selections... even quicker than a button ? (M=move but say ctrl+M=Mirror ?)
ctrl+M? wouldn't that = copy?
try this one.
simple but works
Delete for clarifying
@burkhard said:
try this one.
simple but works
And I thought Frank Wiesener, and then I did all of the hard work in the last three years developing "Mirror.rb" for you all to use freely.........
http://suwiki.org/suwiki/index.php?title=Mirror_%28plugin%29
[but link to old forum is now defunct.]
http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Mirror_31.rbI know it doesn't have a (c) para or an 'acknowledge who done this' para at the start, BUT let's be nice - it's certainly got little that's wholly "Burkhard's"...
I fully acknowledge Frank's earlier input in my updates, at least you could acknowledge others work that's been included in yours - which quite frankly lifts whole lumps of code direct - you even have my ###v3.1 rem tags in yours...Let's stay friends about this... but...
No.
Pressing M and then Ctrl would Move+Copy IF you have M set to Move, but pressing ctrl + M together doesn't (at least not in the Pro version). I only used that key combination as an example !!! You can use any non-reserved key combo: shift+M, alt+M, ctrl+shift+alt+`, shift+spacebar etc etc... the list is only as restricted as your imagination... -
edson
Hi Edson,
Glad to see that you figured the procedure out with
the help of the great team we have here.I totally agree with you when you say that many of the
Ruby Scripts brief explanations are not always clear.I have mentioned this possible oversight before. The
ones that are accompanied with a short video, no matter
how complex become clear, whereas even simple Rubies
with just a couple of lines of text can sometimes stump
us initially.I think this is an area of SketchUcation that we non
programmers can help out with i.e. producing procedural
videos !Just a thought !
Mike
Appologize for fasten but uncompleted help. Be sure, it is not my script
For those who downloaded the mirrorbutton:Open the mirror.rb ( mirror.rb.txt ) and set at the top following.
(If you like you can change everthing to mirror_31b by renaming in all three files.)
Or wait till it was done by supporters.#----------------------------------------------------------------------------------
Description : Mirrors Selection at Point, Line or Plane
Author : Originally by Frank Wiesner
BUT NOTE from v2.6 it's been TIG tweaked and rewritten...###
Usage : 1. Make Selection (Any Entites allowed)###
2. Select 'Mirror Selection' from Plugins Menu
or from Context Menu or your ShortCut Key
3. If here's no Selection then dialog informs
4. Pick a Point and RETURN to Mirror at the Point
5. Pick a Second Point and RETURN to Mirror at the Line
6. Pick a Third Point to Mirror at the Plane
7. Final Option is Erase Original ?
If Yes then Highlighting of Selection passes to Copies
(Note: Erase is undo-able separately from the Mirroring)
Type : Script
History:
3.1 21 Feb 2007 ### TIG make_unique tries to avoid rare bugsplats.
3.0 05 Aug 2006 ### TIG Ending rewritten to avoid rare bugsplats.
2.9 03 Aug 2006 ### TIG Start:commit loops to avoid rare bugsplats.
2.8 26 July 2006 ### TIG re-tweaked - Rewritten to be MUCH simpler.
Mirroring of ANY Entity Selection works properly.
2.7 23 July 2006 ### TIG tweaked - Rewritten generally.
Now processes Multiple selections of Groups and/or
Components, but warns if any 'loose' (UnGrouped)
Faces in Selection as they might lose any RePostioned
Texture data, interfere etc.
2.6 22 July 2006 ### TIG tweaked - Context menu added IF ONE group/compo.
Warns about selection IF NOT ONE group/compo.
Materials now preserved in mirrored copy BUT you will
need to group selection to preserve material positioning
- although this is define-able it is not find-able from
the orignal face info !
Final option to Erase of Original Group/Compo.
2.5 (8.Jul.2oo5) - bugfix: faces with holes reduce now to a single face
- major code rewrite (dropped @clondedObject hash, heavy
use of groups during construction,...
- more redundant constructions, but seems to be more robust
- WARNING: POLYGONS DO NOT WORK VERY WELL
2.4 (5.Jul.2oo5) - all unnecessary edges created by the add_faces_from_mesh()
method are erased! faces with holes mirror now perfectly.
2.3 (4.Jul.2oo5) - fixed "mirror at plane" error
2.2 (2.Jul.2oo5) - works in group editting mode
- prevents picking of identical points
2.1 (1.Jul.2oo5) - fixed "undo group" bug
- code cleanup
2.0 (30.Jun.2oo5) - new tool-like interface
1.4 (29.Jun.2oo5) - arc bug fixed
- code simplified (clone_selection() removed)
1.3 (24.Jun.2oo5) - can handle faces with holes in it (although more edges
are drawn than nessesary)
- correct orientation of mirrored faces
- supports arcs (at least works for circles), curves and groups
1.2 (20.Jun.2oo5) - axis and origin selection algorithm does not rely on tool tips any more.
1.1 (19.Jun.2oo5) - fix coplanar point bug
- better tooltips
- supports mirror at lines (edges, axis, construction lines)
- mirror-at-plane code simplified
1.o (10.Jun.2oo5) - first version
Hacked by Burkhard for toolbar functionality
regards Burkhard
Thanks Burkhard... I had had a bad day... It's at the very least polite to acknowledge the work of others in the headers of the script's text when you are using their code or ideas...
It would have perhaps been easier to leave my original script alone and then link in you new toolbar/extension parts separately to that ?
It was a quick reaction without thinking about.
You can do what you want...I'm not a coder, just hacking. It is the only way I know to make a toolbar.
Apologize my unwise
If there are some problems more, feel free to contact me via pm or mail ( you got my mail time ago)
It is easier for me to communicate and clarify an issue.cu Burkhard
