    Mirror.rb blues
    19 Posts 11 Posters 6.8k Views 11 Watching
    • EdsonE Offline
      Edson
      Edson,
      Usage:
      Yes, you can use 1,2 or 3 points.
      My Top Tip would be, always use 3 points.
      That way results are more predictable.
      Just imagine where you would have to place a real mirror to get the desired result you want.
      Then go and click on 3 corners of that Mirror and Voila, geometry is perfectly mirrored.
      You don't need to actually draw the mirror as I've shown in the example !!! - just click the 3 points.
      Hope this helps
      Howard L'
      hey, howard
      wonderfully clear explanation. your mirror analogy is just perfect. thanks a lot.
      regards.
      edson
      http://www.mahfuz.arq.br
        rhankc
        did you try the Render Plus Mirror tool? It works the way you expect.
        edit; nevermind,I forgot you were on a mac, just came to me.
        Hank
        • EdsonE Offline
          Edson
          thanks, anyway.
          edson
          • H Offline
            humanticnc
            I say thank you for the drawing
            humanticnc πŸ’­
              Bill Wilson
              Thank you Howard. I am just starting to use ruby scripts and was playing with the mirror.rb last night and getting some pretty strange results. Your pic explains it all. "A picture is worth a thousand words" Thanks from the snowy south. πŸ˜„
              • boofredlayB Offline
                boofredlay
                Is there a hope for this script to have a toolbar button sometime?
                I am using it more and more and find myself hunting for the button too often.
                Thanks.
                • TIGT Online
                  Thanks.
                  So much to do and so little time...
                  I have a shortcut key that mirrors selections... even quicker than a button ? (M=move but say ctrl+M=Mirror ?)
                  • KrisidiousK Offline
                    Krisidious
                    ctrl+M? wouldn't that = copy?
                    By: Kristoff Rand
                    • BurkhardB Offline
                      Burkhard
                      try this one. πŸ˜‰ simple but works
                      Delete for clarifying
                      http://www.ia-plus.de
                      • TIGT Online
                        And I thought Frank Wiesener, and then I did all of the hard work in the last three years developing "Mirror.rb" for you all to use freely.........
                        http://suwiki.org/suwiki/index.php?title=Mirror_%28plugin%29
                        [but link to old forum is now defunct.]
                        http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Mirror_31.rb
                        I know it doesn't have a (c) para or an 'acknowledge who done this' para at the start, BUT let's be nice - it's certainly got little that's wholly "Burkhard's"...
                        I fully acknowledge Frank's earlier input in my updates, at least you could acknowledge others work that's been included in yours - which quite frankly lifts whole lumps of code direct - you even have my ###v3.1 rem tags in yours...
                        Let's stay friends about this... but...
                        • TIGT Online
                          No.
                          Pressing M and then Ctrl would Move+Copy IF you have M set to Move, but pressing ctrl + M together doesn't (at least not in the Pro version). I only used that key combination as an example !!! You can use any non-reserved key combo: shift+M, alt+M, ctrl+shift+alt+`, shift+spacebar etc etc... the list is only as restricted as your imagination...
                          • Mike LuceyM Offline
                            Mike Lucey
                            as it happens with many scripts, the usage explanation at the beginning of mirror.rb is not very clear (or so it seemed to me). they way you explained it is very clear, though, and i could make it work exactly as you described it.
                            edson
                            Hi Edson,
                            Glad to see that you figured the procedure out with
                            the help of the great team we have here.
                            I totally agree with you when you say that many of the
                            Ruby Scripts brief explanations are not always clear.
                            I have mentioned this possible oversight before. The
                            ones that are accompanied with a short video, no matter
                            how complex become clear, whereas even simple Rubies
                            with just a couple of lines of text can sometimes stump
                            us initially.
                            I think this is an area of SketchUcation that we non
                            programmers can help out with i.e. producing procedural
                            videos !
                            Just a thought !
                            Mike
                            • BurkhardB Offline
                              Burkhard
                              Appologize for fasten but uncompleted help. Be sure, it is not my script πŸ˜’
                              For those who downloaded the mirrorbutton:
                              Open the mirror.rb ( mirror.rb.txt ) and set at the top following.
                              (If you like you can change everthing to mirror_31b by renaming in all three files.)
                              Or wait till it was done by supporters.
                              Description : Mirrors Selection at Point, Line or Plane
                              Author : Originally by Frank Wiesner
                              BUT NOTE from v2.6 it's been TIG tweaked and rewritten...###
                              Usage : 1. Make Selection (Any Entites allowed)###
                              2. Select 'Mirror Selection' from Plugins Menu
                              or from Context Menu or your ShortCut Key
                              3. If here's no Selection then dialog informs
                              4. Pick a Point and RETURN to Mirror at the Point
                              5. Pick a Second Point and RETURN to Mirror at the Line
                              6. Pick a Third Point to Mirror at the Plane
                              7. Final Option is Erase Original ?
                              If Yes then Highlighting of Selection passes to Copies
                              (Note: Erase is undo-able separately from the Mirroring)
                              Type : Script
                              History:
                              3.1 21 Feb 2007 ### TIG make_unique tries to avoid rare bugsplats.
                              3.0 05 Aug 2006 ### TIG Ending rewritten to avoid rare bugsplats.
                              2.9 03 Aug 2006 ### TIG Start:commit loops to avoid rare bugsplats.
                              2.8 26 July 2006 ### TIG re-tweaked - Rewritten to be MUCH simpler.
                              Mirroring of ANY Entity Selection works properly.
                              2.7 23 July 2006 ### TIG tweaked - Rewritten generally.
                              Now processes Multiple selections of Groups and/or
                              Components, but warns if any 'loose' (UnGrouped)
                              Faces in Selection as they might lose any RePostioned
                              Texture data, interfere etc.
                              2.6 22 July 2006 ### TIG tweaked - Context menu added IF ONE group/compo.
                              Warns about selection IF NOT ONE group/compo.
                              Materials now preserved in mirrored copy BUT you will
                              need to group selection to preserve material positioning
                              - although this is define-able it is not find-able from
                              the orignal face info !
                              Final option to Erase of Original Group/Compo.
                              2.5 (8.Jul.2oo5) - bugfix: faces with holes reduce now to a single face
                              - major code rewrite (dropped @clondedObject hash, heavy
                              use of groups during construction,...
                              - more redundant constructions, but seems to be more robust
                              - WARNING: POLYGONS DO NOT WORK VERY WELL
                              2.4 (5.Jul.2oo5) - all unnecessary edges created by the add_faces_from_mesh()
                              method are erased! faces with holes mirror now perfectly.
                              2.3 (4.Jul.2oo5) - fixed "mirror at plane" error
                              2.2 (2.Jul.2oo5) - works in group editting mode
                              - prevents picking of identical points
                              2.1 (1.Jul.2oo5) - fixed "undo group" bug
                              - code cleanup
                              2.0 (30.Jun.2oo5) - new tool-like interface
                              1.4 (29.Jun.2oo5) - arc bug fixed
                              - code simplified (clone_selection() removed)
                              1.3 (24.Jun.2oo5) - can handle faces with holes in it (although more edges
                              are drawn than nessesary)
                              - correct orientation of mirrored faces
                              - supports arcs (at least works for circles), curves and groups
                              1.2 (20.Jun.2oo5) - axis and origin selection algorithm does not rely on tool tips any more.
                              1.1 (19.Jun.2oo5) - fix coplanar point bug
                              - better tooltips
                              - supports mirror at lines (edges, axis, construction lines)
                              - mirror-at-plane code simplified
                              1.o (10.Jun.2oo5) - first version
                              Hacked by Burkhard for toolbar functionality
                              regards Burkhard
                              • TIGT Online
                                Thanks Burkhard... I had had a bad day... It's at the very least polite to acknowledge the work of others in the headers of the script's text when you are using their code or ideas...
                                It would have perhaps been easier to leave my original script alone and then link in you new toolbar/extension parts separately to that ?
                                • BurkhardB Offline
                                  Burkhard
                                  It was a quick reaction without thinking about.
                                  You can do what you want...I'm not a coder, just hacking. It is the only way I know to make a toolbar.
                                  Apologize my unwise
                                  If there are some problems more, feel free to contact me via pm or mail ( you got my mail time ago)
                                  It is easier for me to communicate and clarify an issue.
                                  cu Burkhard
