    Rayscaper New Releases
    rayscaperrender
    813 Posts 14 Posters 382.0k Views 15 Watching
    • KrassK
      Krass
      Thanks! This extension looks quite comprehensive. But I still think you should have created a new thread for this extension rather than in this post dedicated to Rayscaper. From the beginning of your posts, I haven't found you very encouraging regarding the enormous amount of work done by Pixel Cruncher. What do you think?
      Krass
      A 1 Reply Last reply
      Reply Quote 2
        Alattab @Krass
        @Krass Okay, I’m sorry; I didn’t mean that. All I meant was to clarify the automatic material recognition feature.
        Reply Quote 2
        • pixelcruncherP
          No worries, folks, I appreciate suggestions and the love for Rayscaper! I've been working on a feature like this for a while, but I never finished it. I will launch it soon. But yes, Rayscaper will try to be smart about material names and will have user-configurable rules for matching them. I'm trying to make it so it doesn't get in your way; if you don't like it, you don't have to use it.
          1 Reply Last reply πŸ‘
            Alattab
            Please don’t be upset; all I want is to support RayScaper so that it stays at the forefront and meets every need.
              Alattab
              Is it possible to turn a line or a series of connected lines into something that glows like a strip light?
              • KrassK
                Krass
                The only way is to use an emissive material. Any small, thin face will work or line converted to tube. But you need a face to apply the material on. You can convert your lines instantly into tubes with Lines to tube function from JHS power bar extensions bundle
                Krass
                • pixelcruncherP
                  Hey, Rayscaper users!
                  Rayscaper 1.0.1 is available. You can get it via:
                  • The SketchUcation store.
                  • Direct download: Rayscaper_Win_1.0.1.rbz.
                  I recommend upgrading to the latest version.
                  Auto Setup: Your First Render Looks Right
                  A SketchUp material is a color and maybe a texture: it doesn't say that a surface is glass, polished brass or a mirror. The name often does. When you render a model for the first time, Rayscaper now reads the names of its materials and sets them up: "Window Glass" becomes Glass, "Brass" becomes polished Metal and "Antique Mirror" a mirror. It reads names in several languages.
                  A banner tells you what it changed. Tools > Auto Setup Materials... shows every guess: point at a material to see where it is in the render, and correct or revert what doesn't look right. Guesses it isn't sure of stay suggestions for you to apply.
                  Lighting for an Interior or an Exterior
                  Auto Setup also asks whether your model is an interior or an exterior, and sets the exposure, light bounces, bloom and sky for it. An interior without lights gets an offer to add one.
                  Material Rules
                  Do you name your materials your own way, like M_GL_* for glass or "Verre"? Tell Auto Setup what your names mean with material rules. Your rules come before its own guesses and apply to every model.
                  See Auto Setup in the manual. If you set up your own materials, you can turn it off there in one click.
                  Auto Setup is still a bit experimental: it can guess wrong, and it doesn't know every way people name their materials yet. Your feedback is much appreciated! If it set up a material wrong or missed one, or the lighting doesn't suit your scene, please reply here with the material names (or the model, if you can share it).
                  What Changed?
                  • Add Auto Setup: when you open a model without Rayscaper settings, Rayscaper sets up its materials from their names. A banner says what it changed, and Tools > Auto Setup Materials... lets you review, correct or revert every guess.
                  • Add the lighting of Auto Setup: choose interior or exterior, and it sets the exposure, bounces, bloom and sky for that kind of scene.
                  • Add material rules to Auto Setup: tell it what your own material names mean. Your rules come before its own guesses.
                  • Animate the field of view between SketchUp scenes in Render Animation, so a zoom between scenes and Two-Point Perspective scenes render as SketchUp shows them. Animations whose scenes have different fields of view now render differently than before.
                  • Fix auto exposure blowing out renders with a transparent background.
                  Full release notes: rayscaper.com/manual/release-notes
                  Help Me Build the Community πŸ‘
                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                  Follow me on X.
                  Happy Rendering!
                  Thomas
                  A 2 Replies Last reply
                  • KrassK
                    Krass
                    Hello Thomas,
                    Thank you. I’d like to know if the "round corner" feature is difficult to develop for your program. I’m referring to that "fake" round corner effect, which generates rounded edges where there weren't any before?
                    Krass
                      Alattab @Krass
                      @Krass Thank you for what you mentioned regarding rounded edges; I often favored using them in Thea Render. it is related to matrial
                        Alattab @pixelcruncher
                        @pixelcruncher It seems that, in the end, you will arrive at something unconquerable.
                          Alattab @Krass
                          @Krass I see that your smile is even broader than mine regarding the new update; would it bother you if I offered another suggestion?
                          • KrassK
                            Krass
                            no, of course not
                            Krass
                            A 1 Reply Last reply πŸ‘
                              Alattab @Krass
                              @Krass Thank you
                                sashapepperspray
                                I have a question about licensing (now that you are out of beta), I bought a license a while ago, until when do I get free updates?
                                  Alattab
                                  I would like to see an option added to change the sky color and use raster images png , jpg, ..... image as background for color enviroment or in postprocessing menu , as well as a dedicated UV menu for Rayscaper.
                                  Reply Quote 2
                                    @pixelcruncher
                                    This is fantastic; it looks like there might be some strong competition for the ambient occlusion rendering engine.
                                    • pixelcruncherP
                                      pixelcruncher Extension Creator @sashapepperspray
                                      @sashapepperspray
                                      What I'm releasing currently and in the near future will still be available to you with your existing license.
                                      I will announce the plan for the 2.0 release soon and provide more clarity about the upgrade plan. If there are critical bugs or issues in 1.0, I will still make new builds available for 1.0 license holders.
                                      Cheers,
                                      Thomas
                                      Reply Quote -1
                                      • pixelcruncherP
                                        @alattab - Can you clarify " UV menu for Rayscaper."? Is this for individual image textures, because you can already edit their UVs under the image texture settings. But I presume this is something else?
                                        Also panning works currently with CTRL + Mouse Drag. Was that not clear, or you think there's value in having an explicit button to enable the pan tool?
                                        • pixelcruncherP
                                          Rayscaper 1.0.2 is available. You can get it via:
                                          • Direct download: Rayscaper_Win_1.0.2.rbz.
                                          Glass Presets
                                          The Glass material now has presets for the kinds of glass you model most: Clear, Window Pane, Lightly Frosted, Frosted, Crystal, Acrylic, Water, Diamond and Anti-Reflective. Pick one and Rayscaper sets the index of refraction, the roughness and Thin for you, and keeps your color. Window Pane is for windows modelled as a single face, Frosted for shower screens and privacy glass, Crystal for wine glasses. See Glass Material.
                                          Glass presets
                                          Viewport Background
                                          Post Processing has a new Viewport Background section: pick a photo (PNG or JPEG) and Rayscaper shows it behind a transparent render, so you can see your design on the site photo or a backplate while you work. It's only shown in the viewport, so the renders you save stay transparent for your own compositing, and changing it doesn't restart the render. Turn on Transparent in the Environment section to see it, the section offers a button for that, and Match Render to Image when the photo has a different aspect ratio than your render. See Post Processing.
                                          Viewport Background
                                          What Changed?
                                          • Add presets to the Glass material: Clear, Window Pane, Lightly Frosted, Frosted, Crystal, Acrylic, Water, Diamond and Anti-Reflective. A preset sets the IOR, roughness and Thin, and keeps your color.
                                          • Add a Viewport Background to Post Processing: show a photo behind a transparent render to see it composited over a backplate. It's only shown in the viewport, so saved renders stay transparent.
                                          • Fix the GPU denoiser running out of memory, and renders failing, on PCs with two NVIDIA GPUs.
                                          Follow me on X.
                                          Happy Rendering!
                                          Thomas
                                            Alattab
                                            an example
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 36 / 41
