Rayscaper New Releases
If other users could take a look—I find it a bit sluggish. :
https://jskup.fr/wp-content/uploads/2026/11/testnet.png -
@Krass I like the render! What do you mean by sluggish? The performance of Rayscaper or something about the render?
I mean not sharp enough.
But I offen render in 2 or 4k... may be that's the point? -
Yes, 4K is much better—it’s truly the ideal solution when combined with the denoiser, as even after just 2 minutes, you get a much sharper image that’s close to the final result. It does take longer, of course, but you can also choose to stop the render after 5 minutes, by which point you already have an excellent preview image.
4k render reduced to 1080 p. Suits me
any thing new
Thanks! This extension looks quite comprehensive. But I still think you should have created a new thread for this extension rather than in this post dedicated to Rayscaper. From the beginning of your posts, I haven't found you very encouraging regarding the enormous amount of work done by Pixel Cruncher. What do you think?
@Krass Okay, I’m sorry; I didn’t mean that. All I meant was to clarify the automatic material recognition feature.
No worries, folks, I appreciate suggestions and the love for Rayscaper! I've been working on a feature like this for a while, but I never finished it. I will launch it soon. But yes, Rayscaper will try to be smart about material names and will have user-configurable rules for matching them. I'm trying to make it so it doesn't get in your way; if you don't like it, you don't have to use it.
Please don’t be upset; all I want is to support RayScaper so that it stays at the forefront and meets every need.
Is it possible to turn a line or a series of connected lines into something that glows like a strip light?
The only way is to use an emissive material. Any small, thin face will work or line converted to tube. But you need a face to apply the material on. You can convert your lines instantly into tubes with Lines to tube function from JHS power bar extensions bundle
Hey, Rayscaper users!
Rayscaper 1.0.1 is available. You can get it via:
- The SketchUcation store.
- Direct download: Rayscaper_Win_1.0.1.rbz.
I recommend upgrading to the latest version.
Auto Setup: Your First Render Looks Right
A SketchUp material is a color and maybe a texture: it doesn't say that a surface is glass, polished brass or a mirror. The name often does. When you render a model for the first time, Rayscaper now reads the names of its materials and sets them up: "Window Glass" becomes Glass, "Brass" becomes polished Metal and "Antique Mirror" a mirror. It reads names in several languages.
A banner tells you what it changed. Tools > Auto Setup Materials... shows every guess: point at a material to see where it is in the render, and correct or revert what doesn't look right. Guesses it isn't sure of stay suggestions for you to apply.
Lighting for an Interior or an Exterior
Auto Setup also asks whether your model is an interior or an exterior, and sets the exposure, light bounces, bloom and sky for it. An interior without lights gets an offer to add one.
Material Rules
Do you name your materials your own way, like
M_GL_*for glass or "Verre"? Tell Auto Setup what your names mean with material rules. Your rules come before its own guesses and apply to every model.
See Auto Setup in the manual. If you set up your own materials, you can turn it off there in one click.
Auto Setup is still a bit experimental: it can guess wrong, and it doesn't know every way people name their materials yet. Your feedback is much appreciated! If it set up a material wrong or missed one, or the lighting doesn't suit your scene, please reply here with the material names (or the model, if you can share it).
What Changed?
- Add Auto Setup: when you open a model without Rayscaper settings, Rayscaper sets up its materials from their names. A banner says what it changed, and Tools > Auto Setup Materials... lets you review, correct or revert every guess.
- Add the lighting of Auto Setup: choose interior or exterior, and it sets the exposure, bounces, bloom and sky for that kind of scene.
- Add material rules to Auto Setup: tell it what your own material names mean. Your rules come before its own guesses.
- Animate the field of view between SketchUp scenes in Render Animation, so a zoom between scenes and Two-Point Perspective scenes render as SketchUp shows them. Animations whose scenes have different fields of view now render differently than before.
- Fix auto exposure blowing out renders with a transparent background.
Full release notes: rayscaper.com/manual/release-notes
Help Me Build the Community
If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
Follow me on X.
Happy Rendering!
Thomas -
Hello Thomas,
Thank you. I’d like to know if the "round corner" feature is difficult to develop for your program. I’m referring to that "fake" round corner effect, which generates rounded edges where there weren't any before? -
@Krass Thank you for what you mentioned regarding rounded edges; I often favored using them in Thea Render. it is related to matrial
@pixelcruncher It seems that, in the end, you will arrive at something unconquerable.
@Krass I see that your smile is even broader than mine regarding the new update; would it bother you if I offered another suggestion?
no, of course not
@Krass Thank you
I have a question about licensing (now that you are out of beta), I bought a license a while ago, until when do I get free updates?
