    Rayscaper New Releases
    rayscaperrender
    814 Posts 14 Posters 384.4k Views 15 Watching
    • pixelcruncherP
      @Krass I like the render! What do you mean by sluggish? The performance of Rayscaper or something about the render?
      • KrassK
        Krass
        I mean not sharp enough.
        But I offen render in 2 or 4k... may be that's the point?
        Krass
        • KrassK
          Krass
          Yes, 4K is much better—it’s truly the ideal solution when combined with the denoiser, as even after just 2 minutes, you get a much sharper image that’s close to the final result. It does take longer, of course, but you can also choose to stop the render after 5 minutes, by which point you already have an excellent preview image.
          Krass
          • KrassK
            Krass
            4k render reduced to 1080 p. Suits me
            Krass
            Reply Quote 3
              Alattab
              any thing new
              • KrassK
                Krass
                Thanks! This extension looks quite comprehensive. But I still think you should have created a new thread for this extension rather than in this post dedicated to Rayscaper. From the beginning of your posts, I haven't found you very encouraging regarding the enormous amount of work done by Pixel Cruncher. What do you think?
                Krass
                A 1 Reply Last reply
                Reply Quote 2
                  Alattab @Krass
                  @Krass Okay, I’m sorry; I didn’t mean that. All I meant was to clarify the automatic material recognition feature.
                  Reply Quote 2
                  • pixelcruncherP
                    No worries, folks, I appreciate suggestions and the love for Rayscaper! I've been working on a feature like this for a while, but I never finished it. I will launch it soon. But yes, Rayscaper will try to be smart about material names and will have user-configurable rules for matching them. I'm trying to make it so it doesn't get in your way; if you don't like it, you don't have to use it.
                    1 Reply Last reply 👍
                      Alattab
                      Please don’t be upset; all I want is to support RayScaper so that it stays at the forefront and meets every need.
                        Alattab
                        Is it possible to turn a line or a series of connected lines into something that glows like a strip light?
                        • KrassK
                          Krass
                          The only way is to use an emissive material. Any small, thin face will work or line converted to tube. But you need a face to apply the material on. You can convert your lines instantly into tubes with Lines to tube function from JHS power bar extensions bundle
                          Krass
                          • pixelcruncherP
                            Hey, Rayscaper users!
                            Rayscaper 1.0.1 is available. You can get it via:
                            • The SketchUcation store.
                            • Direct download: Rayscaper_Win_1.0.1.rbz.
                            I recommend upgrading to the latest version.
                            Auto Setup: Your First Render Looks Right
                            A SketchUp material is a color and maybe a texture: it doesn't say that a surface is glass, polished brass or a mirror. The name often does. When you render a model for the first time, Rayscaper now reads the names of its materials and sets them up: "Window Glass" becomes Glass, "Brass" becomes polished Metal and "Antique Mirror" a mirror. It reads names in several languages.
                            A banner tells you what it changed. Tools > Auto Setup Materials... shows every guess: point at a material to see where it is in the render, and correct or revert what doesn't look right. Guesses it isn't sure of stay suggestions for you to apply.
                            Lighting for an Interior or an Exterior
                            Auto Setup also asks whether your model is an interior or an exterior, and sets the exposure, light bounces, bloom and sky for it. An interior without lights gets an offer to add one.
                            Material Rules
                            Do you name your materials your own way, like M_GL_* for glass or "Verre"? Tell Auto Setup what your names mean with material rules. Your rules come before its own guesses and apply to every model.
                            See Auto Setup in the manual. If you set up your own materials, you can turn it off there in one click.
                            Auto Setup is still a bit experimental: it can guess wrong, and it doesn't know every way people name their materials yet. Your feedback is much appreciated! If it set up a material wrong or missed one, or the lighting doesn't suit your scene, please reply here with the material names (or the model, if you can share it).
                            What Changed?
                            • Add Auto Setup: when you open a model without Rayscaper settings, Rayscaper sets up its materials from their names. A banner says what it changed, and Tools > Auto Setup Materials... lets you review, correct or revert every guess.
                            • Add the lighting of Auto Setup: choose interior or exterior, and it sets the exposure, bounces, bloom and sky for that kind of scene.
                            • Add material rules to Auto Setup: tell it what your own material names mean. Your rules come before its own guesses.
                            • Animate the field of view between SketchUp scenes in Render Animation, so a zoom between scenes and Two-Point Perspective scenes render as SketchUp shows them. Animations whose scenes have different fields of view now render differently than before.
                            • Fix auto exposure blowing out renders with a transparent background.
                            Full release notes: rayscaper.com/manual/release-notes
                            Help Me Build the Community 👍
                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                            Follow me on X.
                            Happy Rendering!
                            Thomas
                            A 2 Replies Last reply
                            • KrassK
                              Krass
                              Hello Thomas,
                              Thank you. I’d like to know if the "round corner" feature is difficult to develop for your program. I’m referring to that "fake" round corner effect, which generates rounded edges where there weren't any before?
                              Krass
                                Alattab @Krass
                                @Krass Thank you for what you mentioned regarding rounded edges; I often favored using them in Thea Render. it is related to matrial
                                  Alattab @pixelcruncher
                                  @pixelcruncher It seems that, in the end, you will arrive at something unconquerable.
                                    Alattab @Krass
                                    @Krass I see that your smile is even broader than mine regarding the new update; would it bother you if I offered another suggestion?
                                    • KrassK
                                      Krass
                                      no, of course not
                                      Krass
                                      A 1 Reply Last reply 👍
                                        Alattab @Krass
                                        @Krass Thank you
                                          sashapepperspray
                                          I have a question about licensing (now that you are out of beta), I bought a license a while ago, until when do I get free updates?
                                            Alattab
                                            I would like to see an option added to change the sky color and use raster images png , jpg, ..... image as background for color enviroment or in postprocessing menu , as well as a dedicated UV menu for Rayscaper.
                                            Reply Quote 2
