    Rayscaper New Releases
    rayscaperrender
    814 Posts 14 Posters 384.4k Views 15 Watching
    • KrassK
      Krass
      Hello Thomas,
      Thank you. Iโ€™d like to know if the "round corner" feature is difficult to develop for your program. Iโ€™m referring to that "fake" round corner effect, which generates rounded edges where there weren't any before?
      Krass
      A 2 Replies Last reply
        Alattab @Krass
        @Krass Thank you for what you mentioned regarding rounded edges; I often favored using them in Thea Render. it is related to matrial
          Alattab @pixelcruncher
          @pixelcruncher It seems that, in the end, you will arrive at something unconquerable.
            Alattab @Krass
            @Krass I see that your smile is even broader than mine regarding the new update; would it bother you if I offered another suggestion?
            • KrassK
              Krass
              no, of course not
              Krass
              A 1 Reply Last reply ๐Ÿ‘
                Alattab @Krass
                @Krass Thank you
                  sashapepperspray
                  I have a question about licensing (now that you are out of beta), I bought a license a while ago, until when do I get free updates?
                    Alattab
                    I would like to see an option added to change the sky color and use raster images png , jpg, ..... image as background for color enviroment or in postprocessing menu , as well as a dedicated UV menu for Rayscaper.
                    Reply Quote 2
                      @pixelcruncher
                      This is fantastic; it looks like there might be some strong competition for the ambient occlusion rendering engine.
                      • pixelcruncherP
                        pixelcruncher Extension Creator @sashapepperspray
                        @sashapepperspray
                        What I'm releasing currently and in the near future will still be available to you with your existing license.
                        I will announce the plan for the 2.0 release soon and provide more clarity about the upgrade plan. If there are critical bugs or issues in 1.0, I will still make new builds available for 1.0 license holders.
                        Cheers,
                        Thomas
                        Reply Quote -1
                        • pixelcruncherP
                          @alattab - Can you clarify " UV menu for Rayscaper."? Is this for individual image textures, because you can already edit their UVs under the image texture settings. But I presume this is something else?
                          Also panning works currently with CTRL + Mouse Drag. Was that not clear, or you think there's value in having an explicit button to enable the pan tool?
                          • pixelcruncherP
                            Hey, Rayscaper users!
                            Rayscaper 1.0.2 is available. You can get it via:
                            • The SketchUcation store.
                            • Direct download: Rayscaper_Win_1.0.2.rbz.
                            I recommend upgrading to the latest version.
                            Glass Presets
                            The Glass material now has presets for the kinds of glass you model most: Clear, Window Pane, Lightly Frosted, Frosted, Crystal, Acrylic, Water, Diamond and Anti-Reflective. Pick one and Rayscaper sets the index of refraction, the roughness and Thin for you, and keeps your color. Window Pane is for windows modelled as a single face, Frosted for shower screens and privacy glass, Crystal for wine glasses. See Glass Material.
                            Glass presets
                            Viewport Background
                            Post Processing has a new Viewport Background section: pick a photo (PNG or JPEG) and Rayscaper shows it behind a transparent render, so you can see your design on the site photo or a backplate while you work. It's only shown in the viewport, so the renders you save stay transparent for your own compositing, and changing it doesn't restart the render. Turn on Transparent in the Environment section to see it, the section offers a button for that, and Match Render to Image when the photo has a different aspect ratio than your render. See Post Processing.
                            Viewport Background
                            What Changed?
                            • Add presets to the Glass material: Clear, Window Pane, Lightly Frosted, Frosted, Crystal, Acrylic, Water, Diamond and Anti-Reflective. A preset sets the IOR, roughness and Thin, and keeps your color.
                            • Add a Viewport Background to Post Processing: show a photo behind a transparent render to see it composited over a backplate. It's only shown in the viewport, so saved renders stay transparent.
                            • Fix the GPU denoiser running out of memory, and renders failing, on PCs with two NVIDIA GPUs.
                            Full release notes: rayscaper.com/manual/release-notes
                            Help Me Build the Community ๐Ÿ‘
                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                            Follow me on X.
                            Happy Rendering!
                            Thomas
                              Alattab
                              an example
                                @pixelcruncher SUPER
                                • pixelcruncherP
                                  pixelcruncher Extension Creator @Alattab
                                  @Alattab Thanks for the example. I'm still not sure what you're missing, because Rayscaper already does some of these things in the settings of an image texture:
                                  • Place as a box: set Mapping to Tri-Planar under Texture Projection. It projects the image from three sides and ignores the UVs from SketchUp, so it works well on imported models without good UVs.
                                  • Turn the texture, scale, move: the Transformation settings (Scale, Translation, Rotation) of every image texture.
                                  • All images of a material at once: the Texture Mappingโ€ฆ button at the top of the material editor moves the color, roughness and normal maps together.
                                  They're all explained here: https://rayscaper.com/manual/textures/#texture-projection-uv-or-tri-planar
                                  Would you like more mapping types there, for example cylinder or sphere mapping, or one picture fitted to each face? Or do you mean a menu in SketchUp itself that changes the SketchUp UVs, like the extension in your screenshot? Those are two different features, so it helps me to know which one you'd use..
                                  A majidM 2 Replies Last reply
                                    @pixelcruncher Yes, as you mentioned, we need to be able to edit the texture within the SketchUp viewport ; I would also like to see various options added for how the texture is projected .
                                    • KrassK
                                      Krass
                                      are you talking about texture mapping?
                                      Krass
                                      • KrassK
                                        Krass
                                        all this features are available with free plugin SketchUv. And best : Thrupaint by Fredo6
                                        Krass
                                          Alattab
                                          I think it's a good idea to have the Tracking SketchUp Sun box be able to check out the Rayscaper view window without resorting to it.
                                            Alattab
                                            it is good to add color picker to pick color from render screen
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 37 / 41
