    Animator: Parametric Animation plugin - Discussion
    229 Posts 56 Posters 130.7k Views 55 Watching
    • samuel_tS
      samuel_t
      @dawrightau said:
      NB for any other frustrated sketchup users wanting to export models from Sketchup tp blender for any reason try the 3ds export. It has worked best for me.
      You should try this combo:
      1. Export to glTF from SketchUp with SketchUp glTF Exporter extension.
        Plus, if you want to export PBR materials from SketchUp: Get my plugin on this sketchUcation thread.
      2. Import glTF into Blender with glTF Blender Importer add-on.
      • W
        whiterabbit
        Can you point me to a thread if it exists of how to slow down a camera move (view to view ) I can implement it fine with the movement of objects but cant seem to figure out the camera part. It also seems to work for the beginning view but not for the end view?
        Thanks as always.
        • fredo6F
          I guess you refer to the fade out property of camera elements (i.e. transition to next camera), which can be parameterized with Easing.
          The best is to refer to the Tutorial thread, for instance, this one, video 4.
          • W
            whiterabbit
            I think I figured it out. I thought you had to assign a curve to the beginning view and then a curve to the end view. Seems that an "s" curve only on the front view accelerates and then decelerates from one view to the other.
            • G
              GameOfBoxes
              Hi Fredo,
              Hope this thread is still somewhat active. I made a post over in Extensions looking for help.
              Let me know what you think!
              https://sketchucation.com/forums/viewtopic.php?f=80&t=70288&e=0
              • fredo6F
                @gameofboxes said:
                Hi Fredo,
                This is difficult to do with Animator, and more something to construct with MSPhysics(by Anton S), as you just need to define some hinge constraints between the 3 objects.
                In some particular cases, like yours, you can simulate it with Animator, as illustrated with the video below
                  moderatelyfunky
                  Thanks for your amazing work, Fredo. I'm just trying to learn how to use Animator.
                  I'm confused about why the clip sequencer will reposition clips after I've placed them. It seems to have some built-in logic that wants to move a clip from one track to another and I can't figure out how to override it so that I can lay them out the way I want.
                  In the picture I've attached, I had all the movements in one track and the scaling in another. When I saved, Animator shuffled the Scaling and Movements.
                  Is there a switch I can flip, or can you explain the logic behind the automatic rearranging?
                  • fredo6F
                    Currently the re-arrangement is automatic, that is the track on which clip elements are put. Usually, cameras are on the first tracks.
                    I am thinking of letting freedom to the user in a next version however.
                      moderatelyfunky
                      Thanks for the reply. I wouldn't care, but it's having an impact on the end result. With the scaling reshuffled by Animator, the second path movement starts in a slightly different location.
                      • fredo6F
                        Normally, the re-ordering of tracks does not change the start time and duration of the clip elements.
                        Do you observe something different?
                          moderatelyfunky
                          I created a simple scene to confirm and found that the point of contact stays put when the path remains where I placed it, but when saving rearranges the clips the point of contact is no longer connected to the corner I specified and scaling expands the corner away from the curve.
                          I couldn't consistently reproduce it, but with this example the tracks stayed put after closing and reopening the SketchUp file.
                          I've attached the file.
                          If you have any advice I'd appreciated it.
                          Joe
                          SketchUp Pro 2020
                          20.0.363 64-bit
                          Animator 2.6a - 12 Jan 20
                          ClipSeq_AfterAddingScaling.skp
                          • fredo6F
                            I assume you want the corner to stay along the path.
                            If so, then your scaling should be done from the opposite corner handle.
                            Here is the file corrected
                            ClipSeq_AfterAddingScaling - right handle.skp
                              moderatelyfunky
                              Thanks for taking the time to answer such a dumb question! I'm starting to get comfortable with Animator and loving it. Thanks again!
                              • C
                                carlurcia
                                I´m having a problem with Animator after not using it for months. I used to put "tracking cameras" for following objects and trying to smooth the transition between the "sketch up cameras". But everything works well except de "tracking cameras" which block the Animator and don´t allow you to continue with the video.
                                Sketch up 2020
                                Animator_v3.2a
                                LibFredo6_v11.6a
                                SketchFXEx-3.0.2
                                AmbientOcclusionEx-2.8.0
                                Thank you very much for any suggestions
                                • fredo6F
                                  @carlurcia said:
                                  Could you post or PM me the model so that I have a look.
                                  Many thanks
                                  • KrassK
                                    Krass
                                    Hello,
                                    I’ve got a decent handle on Animator now (thanks again!). However, I’m not quite sure how to proceed with my current project: I’ve started this little animation, but I want to animate both VU meters in parallel. I’m wondering how best to go about this.
                                    For this animation, I created a small rectangle that I scale up to gradually cover the indicator lights.
                                    I need a way to copy and paste this animation so I can position it over the VU meter on the right. Is it possible to copy this rectangle—along with its grouped animation properties? Or, alternatively, can I create a copy and then apply the settings from the first animation to it?
                                    I do see an option to clone the clip...
                                    Thanks for your suggestions!
                                    SketchUp_tnY7qsbzu9.mp4
                                    I have just paid for my license
                                    I am also looking for a way to repeat this animation throughout the entire duration of the main clip, without having to copy and paste this short clip multiple times...
                                    Krass
                                    • KrassK
                                      Krass
                                      Hello,
                                      I found the solution by taking a closer look at the user manual.
                                      It’s perfect and couldn’t be simpler. Thanks again for this brilliant program!
                                      animation.mp4
                                      Simply select two objects to which the same animation will be applied when creating a new movement.
                                      Krass
                                      • KrassK
                                        Krass
                                        le souci est que je n'arrive pas à répéter cette série de mouvements pour les vu mètre que j'ai convertie en clip. Si j'affecte -1 à a valeur de répétition, (forever) il ne joue qu'une seule fois. Si je place d'autres copies du clip l'une après l'autre, les copies ne jouent pas.
                                        Krass
                                        • fredo6F
                                          Difficile d'aider sans voir le fichier.
                                          La repetition suppose que le clip a une duree definie
                                          • KrassK
                                            Krass
                                            Bonsoir,
                                            veux tu le fichier?
                                            Krass
                                            • 11
                                            • 12
                                            • 11 / 12
