    Modlumi - Easy 3D modelling
    408 Posts 9 Posters 71.1k Views 9 Watching
      You forget to say that we can Rotate Dimensions! ๐Ÿ™‚
      1 Reply Last reply ๐Ÿ‘
        Ok the lack of3D space Snap (Circle, Poly) in empty space can becan be resolved by create some Group(s) or Component(s) before!
        • pixelcruncherP
          pixelcruncher Extension Creator @ntxdave
          @ntxdave Can you provide some screenshots or error messages? Something to go by?
          Cheers,
          Thomas
          • pixelcruncherP
            Modlumi 0.18 is out
            Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.17 on Windows, it will offer you the update.
            Improvements
            • Annotate bug report screenshots in green. Green joins red, yellow and blue as an ink color in Report a Bug or Send Feedback.
            Fixes
            • Level names and other plugin labels no longer show through dialogs and panels. Labels that plugins draw in the view, such as the level names and heights from Levels, were drawn on top of every window, so they cut across the Levels panel and any dialog open over the view.
            Full release notes: https://modlumi.com/docs/release-notes/
            Thanks for the reports. Keep them coming!
              We can't recall the 3D Text "box" for edit an yet existing 3D Text ?
              (Change the text for example )
              • pixelcruncherP
                Soon @pilou you shall be able to edit text!
                ntxdaveN 1 Reply Last reply
                Reply Quote -1
                  Excellent! ๐Ÿ™‚
                  • ntxdaveN
                    ntxdave @pixelcruncher
                    @pixelcruncher will you also be able to select the font?
                    Press F1...thank me later
                      Request : Push Pull multiple! ๐Ÿ™‚
                      • KrassK
                        Krass
                        kitchen made with Modlumi Kitchenmaker, imported in Sketchup, rendered with Rayscaper, character Gemini/Maginfic upscale
                        The issue with KitcheMaker is that it doesn't generate components. This means a lot of extra work whenever you want to change things like glass-front cabinet models or handles...
                        Krass
                          Yep that is groups, but seems to me there is a plugin by Thomthom 2(?) who transform Groups in Components !
                          PS Version of IngeTrazo KitchenMaker for SU 2017 is on the French Section!
                          (following my image of cameras' horn)
                          Of course the Plugin .rbz for SU 2017 is in French but...
                            Yes it was ThomThom !
                            You select all your separated groups say 10 , launch the plugin Groups to Components
                            You will have 10 Components !
                            Of course don't know the compatibily of this plugin with version of today but...you can Install SU 2017! ๐Ÿ˜‰
                            Tested in SU 2017 That works fine! ๐Ÿ™‚
                            Groups2Component.zip!
                            • pixelcruncherP
                              pixelcruncher Extension Creator @pilou
                              @pilou I think I might add this as a plugin.
                              • pixelcruncherP
                                @Krass Very impressive! I will look at creating components instead of groups.
                                • pixelcruncherP
                                  A heads-up from my side.
                                  I will be open-sourcing modlumi. My initial thinking was to build it into a commercial application like Rayscaper with a fixed license. But with all the SketchUp competitors popping up (IngeTrazo, Hew3D, etc.), not to mention all the crazy stuff from Adobe clones, I don't think that makes sense anymore. I think open-sourcing it lets more people enjoy it and actually helps its development by building a growing community around Modlumi.
                                  My plan is to offer it for free as open source, but build enterprise and AI features and add a subscription model on top that might entice paying customers (similar to what these guys are doing: https://getartcraft.com/). If you don't care for that, that's okay; the software is free to use without these features.
                                  I will need a couple of days to scrub some PII from the source code, then I will open-source it on GitHub.
                                  Any thoughts? For me, it's also a new experiment in navigating software development in this brave new world. But I feel the old ways of doing things are dead.
                                  1 Reply Last reply โ™ฅ
                                  • KrassK
                                    Krass
                                    I think youโ€™re right.
                                    On the other hand, I truly believe that Rayscaper fits in perfectly; as a V-Ray user, I know I can replace it with Rayscaper for essential tasksโ€”itโ€™s much more user-friendly.
                                    Iโ€™m planning to try using the Rayscaper Scatter feature as a "fur" toolโ€”for things like rugs, for instance. Other options tend to make V-Ray (or other path-tracing programs) feel clunky and cumbersome.
                                    What really frustrates me is seeing how interior design and decoration training programs expect decorators to master V-Ray. I often end up with clients who need to complete their training using this "over-complicated mess" of a program, and they reach out to me for helpโ€”so Iโ€™m forced to use V-Ray to get the job done!
                                    Krass
                                    • pixelcruncherP
                                      Rayscaper will stay commercial. The model is a bit different there. Also, people who don't wanna really want to pay for SketchUp are also not gonna pay for Rayscaper. Different user groups.
                                      • KrassK
                                        Krass
                                        Certainly.
                                        The principle of subscription-based payments for software is a fairly recent development and represents an abuse by major monopolies in the IT sector.
                                        Krass
                                          Seems Open Soursing the modeling part is a reasonable solution! ๐Ÿ™‚
                                          For the moment your are the best against the growing number of free others! ๐Ÿ™‚
                                          1 Reply Last reply ๐Ÿ’ช
                                          • pixelcruncherP
                                            I am simply the best ๐Ÿ™‚
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
