    Modlumi - Easy 3D modelling
    350 Posts 9 Posters 43.5k Views 8 Watching
      Curioussly 0.16
      At start...
      Very difficult to draw Line, Circle, Poly! Must numerous Clicks, Double Clicks...
      Only rectangle!
      As like program was not at full swing! πŸ™‚
      Edit : Today that works fine!
      Big requests : Circle, Poly with 3D Snap on something existing! (like for arc circle or rectangle) !
      Perpendicular Snap 3D, 2D
      Push Pull Tapered
        Animation with sound πŸ™‚ Just speedy test of free Flow / Google (5 animations / day ) Infinite number of images but 3 minutes to see them! πŸ™‚
        Spaceships_hovering_above_moon_s…_20261014112602.mp4
        • pixelcruncherP
          Modlumi 0.17 is out
          Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.16 on Windows, it will offer you the update.
          New features
          • Dimension your model with the new Dimension tool. Click two points, or anywhere along an edge to measure it whole, then move the pointer to offset the dimension line and click, or type the offset. The label shows the length in the model's units. A dimension follows its geometry: move or scale the vertices it measures and it stretches along, in the same undo step. Select a dimension to replace its text in Properties, where <> stands for the length, as in Width <>. The user guide shows how: https://modlumi.com/docs/user-guide/annotating/
          • Label your model with the new Text tool. Click a point, an edge or a face and click again to place a label with a leader. It starts as the point's coordinates, the edge's length or the face's area, and typing right away replaces it. Click empty space for screen text that stays put on the screen while you orbit. Labels and dimensions are saved with the model and show in Save to Image.
          • Add 3D text as geometry with Edit β†’ Add 3D Text… Type the text, the letter height and how deep to extrude it, or 0 for flat faces, then click where it goes. The letters arrive as a solid component that you can paint, move and edit like anything you draw.
          Improvements
          • Scripts and plugins can add and read text labels and dimensions. Entities.addText, addScreenText and addDimension create them, and the Text and LinearDimension classes expose their points, offsets and text: https://modlumi.com/docs/guides/model-and-entities/#text-and-dimensions
          Fixes
          • Extrude and Offset snap to guide points and guide lines. The extrusion or offset ignored guides, so you couldn't stop it at a guide placed with Measure. Thanks @pilou for the report!
          • Pasting only guides shows them under the pointer. A copy of guides alone had nothing to preview, so Paste placed them away from where you clicked.
          Full release notes: https://modlumi.com/docs/release-notes/
          Thanks for the reports. Keep them coming!
          ntxdaveN 1 Reply Last reply
          • KrassK
            Krass
            thanks, it would be great to add bevel last value memory
            Krass
            • ntxdaveN
              ntxdave @pixelcruncher
              @pixelcruncher Once again, I am having a problem trying to install the update on my Windows 11 laptop. I keep getting a download that says it download file instead of being an exe file.
              Press F1...thank me later
                You forget to say that we can Rotate Dimensions! πŸ™‚
                1 Reply Last reply πŸ‘
                  Ok the lack of3D space Snap (Circle, Poly) in empty space can becan be resolved by create some Group(s) or Component(s) before!
                  • pixelcruncherP
                    pixelcruncher Extension Creator @ntxdave
                    @ntxdave Can you provide some screenshots or error messages? Something to go by?
                    Cheers,
                    Thomas
                    • pixelcruncherP
                      Modlumi 0.18 is out
                      Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.17 on Windows, it will offer you the update.
                      Improvements
                      • Annotate bug report screenshots in green. Green joins red, yellow and blue as an ink color in Report a Bug or Send Feedback.
                      Fixes
                      • Level names and other plugin labels no longer show through dialogs and panels. Labels that plugins draw in the view, such as the level names and heights from Levels, were drawn on top of every window, so they cut across the Levels panel and any dialog open over the view.
                        We can't recall the 3D Text "box" for edit an yet existing 3D Text ?
                        (Change the text for example )
                        • pixelcruncherP
                          Soon @pilou you shall be able to edit text!
                          Reply Quote -1
                            Excellent! πŸ™‚
                            • ntxdaveN
                              @pixelcruncher will you also be able to select the font?
                                Request : Push Pull multiple! πŸ™‚
                                • KrassK
                                  Krass
                                  kitchen made with Modlumi Kitchenmaker, imported in Sketchup, rendered with Rayscaper, character Gemini/Maginfic upscale
                                  The issue with KitcheMaker is that it doesn't generate components. This means a lot of extra work whenever you want to change things like glass-front cabinet models or handles...
                                  Krass
                                    Yep that is groups, but seems to me there is a plugin by Thomthom 2(?) who transform Groups in Components !
                                    PS Version of IngeTrazo KitchenMaker for SU 2017 is on the French Section!
                                    (following my image of cameras' horn)
                                    Of course the Plugin .rbz for SU 2017 is in French but...
                                      Yes it was ThomThom !
                                      You select all your separated groups say 10 , launch the plugin Groups to Components
                                      You will have 10 Components !
                                      Of course don't know the compatibily of this plugin with version of today but...you can Install SU 2017! πŸ˜‰
                                      Tested in SU 2017 That works fine! πŸ™‚
                                      Groups2Component.zip!
                                      • pixelcruncherP
                                        pixelcruncher Extension Creator @pilou
                                        @pilou I think I might add this as a plugin.
                                        • pixelcruncherP
                                          @Krass Very impressive! I will look at creating components instead of groups.
                                          • pixelcruncherP
                                            A heads-up from my side.
                                            I will be open-sourcing modlumi. My initial thinking was to build it into a commercial application like Rayscaper with a fixed license. But with all the SketchUp competitors popping up (IngeTrazo, Hew3D, etc.), not to mention all the crazy stuff from Adobe clones, I don't think that makes sense anymore. I think open-sourcing it lets more people enjoy it and actually helps its development by building a growing community around Modlumi.
                                            My plan is to offer it for free as open source, but build enterprise and AI features and add a subscription model on top that might entice paying customers (similar to what these guys are doing: https://getartcraft.com/). If you don't care for that, that's okay; the software is free to use without these features.
                                            I will need a couple of days to scrub some PII from the source code, then I will open-source it on GitHub.
                                            Any thoughts? For me, it's also a new experiment in navigating software development in this brave new world. But I feel the old ways of doing things are dead.
                                            1 Reply Last reply β™₯
                                            • 11
                                            • 12
                                            • 17
                                            • 18
                                            • 10 / 18
