Modlumi - Easy 3D modelling
Curioussly 0.16
At start...
Very difficult to draw Line, Circle, Poly! Must numerous Clicks, Double Clicks...
Only rectangle!As like program was not at full swing!
Edit : Today that works fine!Big requests : Circle, Poly with 3D Snap on something existing! (like for arc circle or rectangle) !
Perpendicular Snap 3D, 2D
Push Pull Tapered -
Animation with sound
Just speedy test of free Flow / Google (5 animations / day ) Infinite number of images but 3 minutes to see them!
Spaceships_hovering_above_moon_sโฆ_20261014112602.mp4
Modlumi 0.17 is out
Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.16 on Windows, it will offer you the update.
New features
- Dimension your model with the new Dimension tool. Click two points, or anywhere along an edge to measure it whole, then move the pointer to offset the dimension line and click, or type the offset. The label shows the length in the model's units. A dimension follows its geometry: move or scale the vertices it measures and it stretches along, in the same undo step. Select a dimension to replace its text in Properties, where
<>stands for the length, as inWidth <>. The user guide shows how: https://modlumi.com/docs/user-guide/annotating/
- Label your model with the new Text tool. Click a point, an edge or a face and click again to place a label with a leader. It starts as the point's coordinates, the edge's length or the face's area, and typing right away replaces it. Click empty space for screen text that stays put on the screen while you orbit. Labels and dimensions are saved with the model and show in Save to Image.
- Add 3D text as geometry with Edit โ Add 3D Textโฆ Type the text, the letter height and how deep to extrude it, or 0 for flat faces, then click where it goes. The letters arrive as a solid component that you can paint, move and edit like anything you draw.
Improvements
- Scripts and plugins can add and read text labels and dimensions. Entities.addText, addScreenText and addDimension create them, and the Text and LinearDimension classes expose their points, offsets and text: https://modlumi.com/docs/guides/model-and-entities/#text-and-dimensions
Fixes
Extrude and Offset snap to guide points and guide lines. The extrusion or offset ignored guides, so you couldn't stop it at a guide placed with Measure. Thanks @pilou for the report!
Pasting only guides shows them under the pointer. A copy of guides alone had nothing to preview, so Paste placed them away from where you clicked.
Full release notes: https://modlumi.com/docs/release-notes/
Thanks for the reports. Keep them coming!
thanks, it would be great to add bevel last value memory
@pixelcruncher Once again, I am having a problem trying to install the update on my Windows 11 laptop. I keep getting a download that says it download file instead of being an exe file.
You forget to say that we can Rotate Dimensions!
Ok the lack of3D space Snap (Circle, Poly) in empty space can becan be resolved by create some Group(s) or Component(s) before!
@ntxdave Can you provide some screenshots or error messages? Something to go by?
Cheers,
Thomas -
Modlumi 0.18 is out
Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.17 on Windows, it will offer you the update.
Improvements
- Annotate bug report screenshots in green. Green joins red, yellow and blue as an ink color in Report a Bug or Send Feedback.
Fixes
- Level names and other plugin labels no longer show through dialogs and panels. Labels that plugins draw in the view, such as the level names and heights from Levels, were drawn on top of every window, so they cut across the Levels panel and any dialog open over the view.
We can't recall the 3D Text "box" for edit an yet existing 3D Text ?
(Change the text for example )
Soon @pilou you shall be able to edit text!
Excellent!
@pixelcruncher will you also be able to select the font?
With your input, this post could be even better ๐
