    Modlumi - Easy 3D modelling
    289 Posts 9 Posters 25.6k Views 7 Watching
    • KrassK
      Krass
      Pixelcruncher,
      will you build a Rayscaper version for Modlumi?
      Krass
        I believe a bug! Of course the same in 3D! ๐Ÿ™‚
        Maybe not a refresh ?
          Cool fillets are positive or negative following edges/faces! Excellent!
            You must make compoents, and component of components!
            If not the direct Copy Move * will freeze or take minutes!
            With components it's instant! ๐Ÿ™‚
            • pixelcruncherP
              @Krass Yes! But integrated directly into the software, not as a plugin. It's easier to have it directly in modlumi.
              1 Reply Last reply ๐Ÿ‘
                There's a part of me that's wants to know what @pilou types for his prompts.
                But there's another part of me that says don't stare into the abyss
                1 Reply Last reply ๐Ÿ˜‚
                • pixelcruncherP
                  Thanks @pilou and @Krass for the reports and examples! Four fixes went into the code today:
                  Copies now create separate faces
                  Copying rectangular outlines onto an existing face now splits the surface into independently selectable regions.
                  Offset works on the copied regions
                  The related โ€œaffected coplanar faces have overlapping interiorsโ€ error is fixed. Copied geometry now integrates with the surrounding surface, allowing Offset to work normally.
                  Sweeping an offset ring leaves both ends open
                  Offsetting the flat polygon first and sweeping the outer ring now produces the expected hollow shape, without blocking the starting opening.
                  Move copy arrays are much faster
                  An 11 ร— 11 array of loose cylinders took 34.8 seconds before and 0.61 seconds after in our desktop test. Components remain useful, but loose geometry should no longer suffer that particular slowdown. Browser timings havenโ€™t been measured yet.
                  Keep the bugs coming; I'll keep squashing!
                  Cheers!
                  Thomas
                  • majidM
                    majid
                    The improvement is really crazy! Thanks for sharing...
                    • KrassK
                      Krass
                      great ! thanks
                      Krass
                        @rich-o-brien
                        My prompt was! ๐Ÿ™‚ (not a big page turner! ๐Ÿ˜‰
                        Effacer les axes et faire une image d'animacules sous-marin.
                        for you...
                        Erase the axes and create an image of underwater animals.
                          Here i have tested an SKP import! (not made with SketchUp but SKP file)
                          Request : can whe have a Drag & Drop of compatible files inside ModLumi ?
                          And an automatic rescale of the import file ! Because here maybe one hundred too little! ๐Ÿ™‚
                          Follow red not ModLumi !
                          Red is not from ModLumi !
                          ModLumi on the right but I don't gave the same chance to it !
                          Not the same number of faces! ๐Ÿ™‚ (less that i can made : )
                          But seems not a problem!
                          From ModLumi ๐Ÿ™‚
                            Bravo for the last reslease! ๐Ÿ™‚
                            • KrassK
                              Krass
                              thanks,
                              copying faces works well now !
                              Krass
                              • pixelcruncherP
                                New in Modlumi: copy arrays with progressive scaling
                                You can now combine Move or Rotate with Copy and scaling to create progressively smaller or larger copies.
                                The GIFs show two examples:
                                Move + Copy: enter x6 80% to create six copies, each 80% of the previous size. The spacing scales too.
                                Rotate + Copy: make a first copy at 30ยฐ, then enter x12 90% to create twelve copies that shrink around the same pivot, forming a spiral.
                                Tap Ctrl while using Move or Rotate to enable Copy, place the first copy, then type the count and scale and press Enter.
                                Curious to see what youโ€™ll build with it!
                                • KrassK
                                  Krass
                                  perfect!
                                  Krass
                                    Very cool and absolutely necessary! Bravo! (special copy)
                                    With that, infinite space geometry is open!
                                    You have a very reactive productivity! ๐Ÿ™‚
                                    Now Boolean! ๐Ÿ™‚ If seems not yet integrated when you compose 2 volumes! ๐Ÿ™‚ (or more)
                                    This works but Not if we draw the true diagonal at the start!!! (Bug ? )
                                    (or maybe because i select also the behind little vertical edge of the second box by error?
                                    Edit : in fact not works : the Push here is only an erase!
                                      For me there is always a bug! ๐Ÿ˜‰ V 09... (Push or Pull)
                                      1 Reply Last reply ๐Ÿ˜
                                        Request : some center functions of a selection... ๐Ÿ™‚
                                        And what about Points ?
                                        • KrassK
                                          Krass
                                          Do you know merory copy plugin? It would be perfect have this function
                                          Krass
                                          • pixelcruncherP
                                            pixelcruncher Extension Creator @pilou
                                            @pilou Thanks for testing this! I tried to reproduce it, but couldn't break it yet.
                                            Could you post the .modl file (File โ†’ Save As) or a GIF of the true diagonal case where it goes wrong? Then I can chase it down.
                                            Booleans are on the list too.
                                            Cheers!
                                            Thomas
                                            • 14
                                            • 15
                                            • 4 / 15
