    Modlumi - Easy 3D modelling
    393 Posts 9 Posters 61.1k Views 9 Watching
      @ntxdave
      Is that more clear ?
      Here Arc Circle is a group! Like this you can select it first on the Ouliner!
      Draw directely the Offset on the polygon and make the Sweep will not work :the first face will be bad drawn!
      GIF_davenext.if
      The bad way... (for the moment! i suppose a little bug again πŸ™‚
      Reply Quote 2
        Reply Quote 2
          Request : a tool selection πŸ™‚
          If we want select only one face / 2 ... πŸ™‚ (Loop, ring selection...
            • KrassK
              Krass
              Hello Thomas,
              the bevel is great !
              But I still can't do multiple copies that make new faces
              Krass
              • KrassK
                Krass
                offset tool issue
                Krass
                  @krass
                  For help, you can post a fil .modl ! (Save as)
                  I believe that is not yet Multiple selections!
                  (you can select some faces but some functions will not work on them)
                  For your lat problem above you can try that (i have tested πŸ˜‰
                  Select that you want Offset
                  Inverse selection
                  Group (and hide if necessary)
                  Offset on your remake selection...
                  • KrassK
                    Krass
                    Pixelcruncher,
                    will you build a Rayscaper version for Modlumi?
                    Krass
                      I believe a bug! Of course the same in 3D! πŸ™‚
                      Maybe not a refresh ?
                        Cool fillets are positive or negative following edges/faces! Excellent!
                          You must make compoents, and component of components!
                          If not the direct Copy Move * will freeze or take minutes!
                          With components it's instant! πŸ™‚
                          • pixelcruncherP
                            @Krass Yes! But integrated directly into the software, not as a plugin. It's easier to have it directly in modlumi.
                            1 Reply Last reply πŸ‘
                              There's a part of me that's wants to know what @pilou types for his prompts.
                              But there's another part of me that says don't stare into the abyss
                              1 Reply Last reply πŸ˜‚
                              • pixelcruncherP
                                Thanks @pilou and @Krass for the reports and examples! Four fixes went into the code today:
                                Copies now create separate faces
                                Copying rectangular outlines onto an existing face now splits the surface into independently selectable regions.
                                Offset works on the copied regions
                                The related β€œaffected coplanar faces have overlapping interiors” error is fixed. Copied geometry now integrates with the surrounding surface, allowing Offset to work normally.
                                Sweeping an offset ring leaves both ends open
                                Offsetting the flat polygon first and sweeping the outer ring now produces the expected hollow shape, without blocking the starting opening.
                                Move copy arrays are much faster
                                An 11 Γ— 11 array of loose cylinders took 34.8 seconds before and 0.61 seconds after in our desktop test. Components remain useful, but loose geometry should no longer suffer that particular slowdown. Browser timings haven’t been measured yet.
                                Keep the bugs coming; I'll keep squashing!
                                Cheers!
                                Thomas
                                • majidM
                                  majid
                                  The improvement is really crazy! Thanks for sharing...
                                  • KrassK
                                    Krass
                                    great ! thanks
                                    Krass
                                      @rich-o-brien
                                      My prompt was! πŸ™‚ (not a big page turner! πŸ˜‰
                                      Effacer les axes et faire une image d'animacules sous-marin.
                                      for you...
                                      Erase the axes and create an image of underwater animals.
                                        Here i have tested an SKP import! (not made with SketchUp but SKP file)
                                        Request : can whe have a Drag & Drop of compatible files inside ModLumi ?
                                        And an automatic rescale of the import file ! Because here maybe one hundred too little! πŸ™‚
                                        Follow red not ModLumi !
                                        Red is not from ModLumi !
                                        ModLumi on the right but I don't gave the same chance to it !
                                        Not the same number of faces! πŸ™‚ (less that i can made : )
                                        But seems not a problem!
                                        From ModLumi πŸ™‚
                                          Bravo for the last reslease! πŸ™‚
                                          • KrassK
                                            Krass
                                            thanks,
                                            copying faces works well now !
                                            Krass
