    Modlumi - Easy 3D modelling
    392 Posts 9 Posters 60.2k Views 9 Watching
    • ntxdaveN
      ntxdave
      How do you draw something like this in Modlumi?
      Press F1...thank me later
        Can you put a number of version or something similar on the top of the Net version ?
        Like this user can see if it uses a new version or not! ๐Ÿ™‚
        Excellent for the new functions! ๐Ÿ™‚
        • pixelcruncherP
          Yea, we have this but it's probably not that user friendly:
          I will add a better versioning scheme.
            Not hyper friendly indeed! ๐Ÿ™‚
            @ ntxdave
            ModLumi = SketchUp lite for the moment ... so you draw exactely like before!
            Here i just erased by Hand some faces because i had no time! ๐Ÿ™‚
            But result images will be the same! ๐Ÿ˜‰ Because today AI help you! ๐Ÿ˜‰
              @pixelcruncher
              What is Redo if existing?
              Found!!! CTRL + Y ! ๐Ÿ™‚
              So I can make my little video! ๐Ÿ™‚
              @ntxdave
              No more simple use the Sweep and Offset Functions as usual! ๐Ÿ˜‰
              As you see Ai will add thickness itself on the final render! ๐Ÿ™‚
              https://community.sketchucation.com/post/1622428
              So you can make now furnitures in a wink!
                Version b7010dd ๐Ÿ™‚
                Always a bug of Snap 3D with Arc Circle!
                There is a vertical segment on the middle ot the diagonal of the top face rectangle!
                Will be the same if the rectangle was drawn on the ground!
                  Some little regressions in Sweep! (or my little mine ๐Ÿ™‚
                  Little asks ๐Ÿ™‚
                  Functions Copy, Rotate + " *, / " oK... but...Scale + " * / " ?
                  "Sweep" OK but... Sweep + Scale ?
                    We can't name a curve ? If I make a group it can't be selected for make a sweep! (?)
                    So the best solution is put the path out of the future structure for an easy selection! ๐Ÿ™‚
                    ntxdaveN 1 Reply Last reply
                    • pixelcruncherP
                      Merci pilou de faire connaรฎtre ModLumi et de partager tes crรฉations ! Continue ร  me signaler les bugs que tu rencontres, รงa mโ€™aide beaucoup ร  amรฉliorer lโ€™application ๐Ÿ™‚
                      AI translated.
                      Cheers,
                      Thomas
                      • pixelcruncherP
                        Modlumi 0.3 is now live at https://modlumi.com/app/, with a ton of fixes and improvements, many of them based on your feedback in this thread. Thanks for all the reports and suggestions!
                        Full release notes: https://modlumi.com/docs/release-notes/
                        If you run into anything, use Report a Bug or Send Feedback in the app or reply here.
                        • ntxdaveN
                          ntxdave @pilou
                          Couple of questions:
                          • How did you draw this model?
                          • How did you render this model?
                          I do not see the ability render with the type of materials in your model. As an example, how did you make something look like it is metalic. The only thing I am seeing in the materials is colors and no ability to add any shin or roughtness.
                          • ntxdaveN
                            ntxdave @pixelcruncher
                            @pixelcruncher said:
                            IN the release notes, I saw this:
                            See a readable release number in the browserโ€™s menu bar. Makes it easier to check whether the latest release is loaded. Original forum report
                            When I look in the upper right part of the browser's menu bar, I keep am seeing 0.4 ๐Ÿ™‚
                            • pixelcruncherP
                              @ntxdave Life's fast on the bleeding edge, I just released a new version ๐Ÿ˜‰
                              • ntxdaveN
                                But I thought it was 0.3, not 0.4!
                                Pilou has been showing some really neat stuff in his posts but I do not understand how it is accomplishing some of it. In particular, how is he applying the textures he has been showing?
                                • pixelcruncherP
                                  @ntxdave Those renders were not made by modlumi. He created the model in modlumi, and then used other software to render it.
                                  • pixelcruncherP
                                    Just released a new version (v0.6). This one has fillet/chamfer/bevel support. This feature is still experimental and may change. Feedback welcome!
                                    • ntxdaveN
                                      ntxdave
                                      OK,
                                      1. How do I update to the latest version or is it automatic when you run the app?
                                      2. How do you control/enter the infor for the bevel options?
                                      Never mind, you can delete this message. I just went back to the app and now see that it updated automatically.
                                        @ntxdave How did you draw this model?
                                        Draw any closed section
                                        Draw an Arc CIrcle
                                        Use the Sweep Section
                                        (put the arc circle out of the Structure resultant like this you can reuse it for following!
                                        Draw an internal Offset on one of face extremity
                                        Use again the Sweep Function with this Offset!
                                        (same the furniture above)
                                        ""How did you render this model?"
                                        I make a screen Snapshot (but you can use the Save Image Function of ModLumi ! ;ยฐ
                                        Then send it to free Gemini where you can make any thing you want! https://gemini.google.com/app
                                        Very simple prompts! (en franรงais ! ๐Ÿ˜‰
                                        • effacer les axes, et mettre des personnages dans ces couloirs
                                        • mettre de la couleurs sur la structure .
                                        So In English! ๐Ÿ™‚ the 2 Prompts were..
                                        • erase the axes and place figures in these corridors
                                        • add color to the structure
                                          What do want more simple ? ๐Ÿ™‚
                                        If you have some problem I can make another gif animation! ๐Ÿ˜‰
                                        In fact modeling is quasi the same than inside SKetchUp !
                                        E 1 Reply Last reply โ™ฅ
                                          @pixelcruncher
                                          Excellent seems you have resolved the Bug of 3D Snap Arc Circle ! Bravo!
                                          Your Bevel, Fillet, Chamfer functions are a killer one!
                                          Working from the first time! ๐Ÿ™‚
                                            Searching defaults ๐Ÿ™‚
                                            Reply Quote 2
                                            • 19
                                            • 20
                                            • 2 / 20
