    Modlumi - Easy 3D modelling
    392 Posts 9 Posters 60.2k Views 9 Watching
    • pixelcruncherP
      Thanks! Can you try this again? This should be fixed now:
      sweep-fix-demo.mp4
      Keep those bugs flowing!
        That is perfect ! Works in closed or not total path!
        Even Section profil is not perpendicular to something!
        And not on the path!
        Very cool function!
        1 Reply Last reply πŸ˜†
        Reply Quote 3
        • ntxdaveN
          ntxdave
          OK guys, I am feeling really stupid. I have tried the browser version, but I am not getting things right. How do I create a rectangle and give it the size? I tried to enter the dimensions, but it did not work. What am I not understanding?.
          Press F1...thank me later
            I believe there is a little bug somewhere! πŸ˜‰
            There is just the last faces who are yet in place! πŸ™‚
            I have verified in hide them ! πŸ˜‰
            Very cool that you have keept original " */ " of the copy functions !
              @ Ntx Dave
              Just Left DoubleClick for have the drawing of the Rectangle, then write 1,2 for a rectangle or 2,2 for a square Enter ! etc.. πŸ˜‰
              Or Just Press R , Left Click and Drag for see the Blue Rect , write 2,2, Enter for a square etc...
              It's quasi the same than SketchUp! πŸ˜‰
              ntxdaveN 1 Reply Last reply
                You have not: Inverse Selection ?
                There is no Snap in 3D Space of the second click of the Arc Circle ?
                • ntxdaveN
                  ntxdave @pilou
                  @pilou OK, I finally got it to work; I am having some user problems but will continue to learn how to use the tool.
                  I would like to have some more options for entering the information when in the drawing mode.\
                  • pixelcruncherP
                    pixelcruncher Extension Creator @pilou
                    I have verified in hide them ! ;)f
                    @pilou You were right; that was a bug! Sweeping a face along the bar's own path now cuts a clean tunnel: the far end opens up instead of keeping that last face in place.
                    A sweep that stops inside the solid still gives you a recess. Can you try it again on your model? Keep those bugs flowing. I'm drinking from the firehose.
                    Cheers!
                    Thomas
                    ntxdaveN 1 Reply Last reply πŸ‘
                    • ntxdaveN
                      ntxdave @pixelcruncher
                      @pixelcruncher How the heck do you draw something like this. I am currently feeling really stupid and am not doing well. The object in the model looks kind of neat but I cannot understand how you drew it.
                      • ntxdaveN
                        ntxdave
                        How the heck do you draw something like this? So far, I am not doing very well when trying to draw objects that are not all that complicated. Is there some place I can go to learn how to use the drawing tools better?
                        • pixelcruncherP
                          pixelcruncher Extension Creator @ntxdave
                          Not really; you are on the bleeding edge with us. This software doesn't have documentation yet πŸ™‚ But a lot of your SketchUp skills should translate over. Note that it's all still very alpha, lots of bugs to bite you. But many eyes make all the bugs shallow.
                            Before you post i have verified on a more simple one ... that was a repetive bug! πŸ˜‰
                            Here modified by hands!
                            So I must return to your last version! πŸ™‚
                            • pixelcruncherP
                              @pilou, what are you using for those renders? They look cool.
                                I use only Gemini free there is maybe a little limit of number images by day but sufficient for me... in case of overpass i use this terrific free one ( 95 % of functions have Free Access : Vizcom ! )
                                https://vizcom.com/ You can make in free 1,2,4,8 k images!
                                A must and Online so for my very old Latop (more than 12 years old) that is paradise! πŸ™‚
                                I will go test your new opus! πŸ™‚
                                • pixelcruncherP
                                  We have invert selection now.
                                  Snapping for the arc tool should work now:
                                    Ah you are speedy! πŸ™‚
                                    Seems no more bug inside Sweep now! πŸ˜‰
                                    • ntxdaveN
                                      ntxdave
                                      How do you draw something like this in Modlumi?
                                        Can you put a number of version or something similar on the top of the Net version ?
                                        Like this user can see if it uses a new version or not! πŸ™‚
                                        Excellent for the new functions! πŸ™‚
                                        • pixelcruncherP
                                          Yea, we have this but it's probably not that user friendly:
                                          I will add a better versioning scheme.
                                            Not hyper friendly indeed! πŸ™‚
                                            @ ntxdave
                                            ModLumi = SketchUp lite for the moment ... so you draw exactely like before!
                                            Here i just erased by Hand some faces because i had no time! πŸ™‚
                                            But result images will be the same! πŸ˜‰ Because today AI help you! πŸ˜‰
                                            • 19
                                            • 20
                                            • 2 / 20
