    Modlumi - Easy 3D modelling
    392 Posts 9 Posters 60.2k Views 9 Watching
      I believe there is a little bug somewhere! πŸ˜‰
      There is just the last faces who are yet in place! πŸ™‚
      I have verified in hide them ! πŸ˜‰
      Very cool that you have keept original " */ " of the copy functions !
        @ Ntx Dave
        Just Left DoubleClick for have the drawing of the Rectangle, then write 1,2 for a rectangle or 2,2 for a square Enter ! etc.. πŸ˜‰
        Or Just Press R , Left Click and Drag for see the Blue Rect , write 2,2, Enter for a square etc...
        It's quasi the same than SketchUp! πŸ˜‰
        ntxdaveN 1 Reply Last reply
          You have not: Inverse Selection ?
          There is no Snap in 3D Space of the second click of the Arc Circle ?
          • ntxdaveN
            ntxdave @pilou
            @pilou OK, I finally got it to work; I am having some user problems but will continue to learn how to use the tool.
            I would like to have some more options for entering the information when in the drawing mode.\
            Press F1...thank me later
            • pixelcruncherP
              pixelcruncher Extension Creator @pilou
              I have verified in hide them ! ;)f
              @pilou You were right; that was a bug! Sweeping a face along the bar's own path now cuts a clean tunnel: the far end opens up instead of keeping that last face in place.
              A sweep that stops inside the solid still gives you a recess. Can you try it again on your model? Keep those bugs flowing. I'm drinking from the firehose.
              Cheers!
              Thomas
              ntxdaveN 1 Reply Last reply πŸ‘
              • ntxdaveN
                ntxdave @pixelcruncher
                @pixelcruncher How the heck do you draw something like this. I am currently feeling really stupid and am not doing well. The object in the model looks kind of neat but I cannot understand how you drew it.
                • ntxdaveN
                  ntxdave
                  How the heck do you draw something like this? So far, I am not doing very well when trying to draw objects that are not all that complicated. Is there some place I can go to learn how to use the drawing tools better?
                  • pixelcruncherP
                    pixelcruncher Extension Creator @ntxdave
                    Not really; you are on the bleeding edge with us. This software doesn't have documentation yet πŸ™‚ But a lot of your SketchUp skills should translate over. Note that it's all still very alpha, lots of bugs to bite you. But many eyes make all the bugs shallow.
                      Before you post i have verified on a more simple one ... that was a repetive bug! πŸ˜‰
                      Here modified by hands!
                      So I must return to your last version! πŸ™‚
                      • pixelcruncherP
                        @pilou, what are you using for those renders? They look cool.
                          I use only Gemini free there is maybe a little limit of number images by day but sufficient for me... in case of overpass i use this terrific free one ( 95 % of functions have Free Access : Vizcom ! )
                          https://vizcom.com/ You can make in free 1,2,4,8 k images!
                          A must and Online so for my very old Latop (more than 12 years old) that is paradise! πŸ™‚
                          I will go test your new opus! πŸ™‚
                          • pixelcruncherP
                            We have invert selection now.
                            Snapping for the arc tool should work now:
                              Ah you are speedy! πŸ™‚
                              Seems no more bug inside Sweep now! πŸ˜‰
                              • ntxdaveN
                                ntxdave
                                How do you draw something like this in Modlumi?
                                  Can you put a number of version or something similar on the top of the Net version ?
                                  Like this user can see if it uses a new version or not! πŸ™‚
                                  Excellent for the new functions! πŸ™‚
                                  • pixelcruncherP
                                    Yea, we have this but it's probably not that user friendly:
                                    I will add a better versioning scheme.
                                      Not hyper friendly indeed! πŸ™‚
                                      @ ntxdave
                                      ModLumi = SketchUp lite for the moment ... so you draw exactely like before!
                                      Here i just erased by Hand some faces because i had no time! πŸ™‚
                                      But result images will be the same! πŸ˜‰ Because today AI help you! πŸ˜‰
                                        @pixelcruncher
                                        What is Redo if existing?
                                        Found!!! CTRL + Y ! πŸ™‚
                                        So I can make my little video! πŸ™‚
                                        @ntxdave
                                        No more simple use the Sweep and Offset Functions as usual! πŸ˜‰
                                        As you see Ai will add thickness itself on the final render! πŸ™‚
                                        https://community.sketchucation.com/post/1622428
                                        So you can make now furnitures in a wink!
                                          Version b7010dd πŸ™‚
                                          Always a bug of Snap 3D with Arc Circle!
                                          There is a vertical segment on the middle ot the diagonal of the top face rectangle!
                                          Will be the same if the rectangle was drawn on the ground!
                                            Some little regressions in Sweep! (or my little mine πŸ™‚
                                            Little asks πŸ™‚
                                            Functions Copy, Rotate + " *, / " oK... but...Scale + " * / " ?
                                            "Sweep" OK but... Sweep + Scale ?
                                            • 19
                                            • 20
                                            • 2 / 20
