    Modlumi - Easy 3D modelling
    392 Posts 9 Posters 60.2k Views 9 Watching
    • ntxdaveN
      ntxdave
      How the heck do you draw something like this? So far, I am not doing very well when trying to draw objects that are not all that complicated. Is there some place I can go to learn how to use the drawing tools better?
      Press F1...thank me later
      • pixelcruncherP
        pixelcruncher Extension Creator @ntxdave
        @ntxdave said:
        @pixelcruncher How the heck do you draw something like this. I am currently feeling really stupid and am not doing well. The object in the model looks kind of neat but I cannot understand how you drew it.
        Not really; you are on the bleeding edge with us. This software doesn't have documentation yet ๐Ÿ™‚ But a lot of your SketchUp skills should translate over. Note that it's all still very alpha, lots of bugs to bite you. But many eyes make all the bugs shallow.
          Before you post i have verified on a more simple one ... that was a repetive bug! ๐Ÿ˜‰
          Here modified by hands!
          So I must return to your last version! ๐Ÿ™‚
          • pixelcruncherP
            @pilou, what are you using for those renders? They look cool.
              I use only Gemini free there is maybe a little limit of number images by day but sufficient for me... in case of overpass i use this terrific free one ( 95 % of functions have Free Access : Vizcom ! )
              https://vizcom.com/ You can make in free 1,2,4,8 k images!
              A must and Online so for my very old Latop (more than 12 years old) that is paradise! ๐Ÿ™‚
              I will go test your new opus! ๐Ÿ™‚
              • pixelcruncherP
                pixelcruncher Extension Creator @pilou
                @pilou said:
                You have not: Inverse Selection ?
                There is no Snap in 3D Space of the second click of the Arc Circle ?
                We have invert selection now.
                Snapping for the arc tool should work now:
                  Ah you are speedy! ๐Ÿ™‚
                  Seems no more bug inside Sweep now! ๐Ÿ˜‰
                  • ntxdaveN
                    ntxdave
                    How do you draw something like this in Modlumi?
                      Can you put a number of version or something similar on the top of the Net version ?
                      Like this user can see if it uses a new version or not! ๐Ÿ™‚
                      Excellent for the new functions! ๐Ÿ™‚
                      • pixelcruncherP
                        Yea, we have this but it's probably not that user friendly:
                        I will add a better versioning scheme.
                          Not hyper friendly indeed! ๐Ÿ™‚
                          @ ntxdave
                          ModLumi = SketchUp lite for the moment ... so you draw exactely like before!
                          Here i just erased by Hand some faces because i had no time! ๐Ÿ™‚
                          But result images will be the same! ๐Ÿ˜‰ Because today AI help you! ๐Ÿ˜‰
                            @pixelcruncher
                            What is Redo if existing?
                            Found!!! CTRL + Y ! ๐Ÿ™‚
                            So I can make my little video! ๐Ÿ™‚
                            @ntxdave
                            No more simple use the Sweep and Offset Functions as usual! ๐Ÿ˜‰
                            As you see Ai will add thickness itself on the final render! ๐Ÿ™‚
                            https://community.sketchucation.com/post/1622428
                            So you can make now furnitures in a wink!
                              Version b7010dd ๐Ÿ™‚
                              Always a bug of Snap 3D with Arc Circle!
                              There is a vertical segment on the middle ot the diagonal of the top face rectangle!
                              Will be the same if the rectangle was drawn on the ground!
                                Some little regressions in Sweep! (or my little mine ๐Ÿ™‚
                                Little asks ๐Ÿ™‚
                                Functions Copy, Rotate + " *, / " oK... but...Scale + " * / " ?
                                "Sweep" OK but... Sweep + Scale ?
                                  We can't name a curve ? If I make a group it can't be selected for make a sweep! (?)
                                  So the best solution is put the path out of the future structure for an easy selection! ๐Ÿ™‚
                                  ntxdaveN 1 Reply Last reply
                                  • pixelcruncherP
                                    Merci pilou de faire connaรฎtre ModLumi et de partager tes crรฉations ! Continue ร  me signaler les bugs que tu rencontres, รงa mโ€™aide beaucoup ร  amรฉliorer lโ€™application ๐Ÿ™‚
                                    AI translated.
                                    Cheers,
                                    Thomas
                                    • pixelcruncherP
                                      Modlumi 0.3 is now live at https://modlumi.com/app/, with a ton of fixes and improvements, many of them based on your feedback in this thread. Thanks for all the reports and suggestions!
                                      Full release notes: https://modlumi.com/docs/release-notes/
                                      If you run into anything, use Report a Bug or Send Feedback in the app or reply here.
                                      • ntxdaveN
                                        ntxdave @pilou
                                        Couple of questions:
                                        • How did you draw this model?
                                        • How did you render this model?
                                        I do not see the ability render with the type of materials in your model. As an example, how did you make something look like it is metalic. The only thing I am seeing in the materials is colors and no ability to add any shin or roughtness.
                                        • ntxdaveN
                                          ntxdave @pixelcruncher
                                          @pixelcruncher said:
                                          IN the release notes, I saw this:
                                          See a readable release number in the browserโ€™s menu bar. Makes it easier to check whether the latest release is loaded. Original forum report
                                          When I look in the upper right part of the browser's menu bar, I keep am seeing 0.4 ๐Ÿ™‚
                                          • pixelcruncherP
                                            @ntxdave Life's fast on the bleeding edge, I just released a new version ๐Ÿ˜‰
                                            • 19
                                            • 20
                                            • 2 / 20
