    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 593 Posters 13.7m Views 595 Watching
    • E
      epetit91
      All was OK before the last Fredo6_!LibFredo6 update !!!
      • E
        epetit91
        When I run "Check for Updates" for LibFredo6-Configuration, nothing happens.
        • E
          epetit91
          SketchUcation toolset installed : 5.0.8
          Extensions : Fredo6_Curviloft, Fredo6_FredoTools, Fredo6_JointPushPull, Fredo6_RoundCorner
          When I run, nothing happens (no dialogs errors).
          All license are OK
          When I run the Ruby Console and execute the Corner plugin, for example, this is what I get :
          Error: #<NoMethodError: undefined method plugin_list' for Traductor::Scanning:Class> /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles/data6.rb:20:in launch_action'
          /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:81:in launch_action'
          /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:96:in block in startup' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:in call'
          /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:in command_invoke' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in block (2 levels) in build_config_commands'
          /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:in call' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:in block in add_command'
          SketchUp:1:in `call'
          • B
            Bublifuk21
            Hi, I have a problem. I would like to add Fredoscale plugin, which works with LibFredo6 15.9 or higher. My latest LibFredo6 is 15.8 and all your plugins works perfectly. After installation the newest 16.2 version, no one plugins works. I see icons, they have a color, but do not works. What should I do to fix it? Thank you very much.
              @epetit91
              You are on a MAC ?
              Does the error msg's folder exist:
              If so what are its contents ?
              E 2 Replies Last reply
              • B
                Bublifuk21
                No, I have standard Windows 7 Ultimate. All Fredo plugins works well with LibFredo 15.8. But Fredo Scale works only with LibFredo 15.9 or higher. So I downloaded the newest LibFredo 16.2 and everything stop to work. I see icons, but they are inactive. One picture is with installed libFredo 15.8 and function plugins, another one is with LiFredo 16.2 I can see also FredoScale icons, but no plugin is working
                  @bublifuk21
                  That OS question wasn't directed to you.
                  But your super-old Windows version installation is likely to cause issues - I'm surprised it's worked well up to now...
                  @fredo6 will undoubtedly have some to add...
                  • fredo6F
                    When you have issues with the installation of LibFredo6, can you report the utput of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support
                    This just tells what is your configuration in terms of version installed, Sketchup version, platform, etc...
                    Otherwise, it is very difficult to help.
                    • E
                      epetit91 @TIG
                      Yes, I am on Mac (MacOS 10.12.6)
                      I have been using Fredo plugins since 2022 and have never encountered a single problem. This issue only appeared after the latest update to FredoLib.
                      TThe contents of the /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles: folder is as follow :
                      drwxr-xr-x 6 eric staff 204 30 sep 08:07 .
                      drwxr-xr-x 10 eric staff 340 30 sep 09:01 ..
                      drwxr-xr-x 2 eric staff 68 29 sep 21:11 Images
                      drwxr-xr-x 2 eric staff 68 29 sep 21:11 LibFredo6_Textures
                      drwxr-xr-x 27 eric staff 918 30 sep 08:57 Traces
                      -rw-r--r-- 1 eric staff 3988 30 sep 08:57 data6.rb
                        @fredo ?
                        • E
                          epetit91 @TIG
                          @TIG If this can help you, here you will find the data6.rb from the /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles folder
                          data6.rb
                          • E
                            epetit91 @TIG
                            @TIG I restored LibFredo 15.8e, and everything is working perfectly again. The problem definitely stems from the latest version, 16.
                            • E
                              epetit91 @TIG
                              @TIG To summarize: everything works perfectly up to version 16.1a.
                              With version 16.1g, SketchUp crashes.
                              With version 16.2a/b, no plugins work.
                              Dave RD 1 Reply Last reply
                                @fredo6 ??
                                  Dave R @epetit91
                                  @epetit91 it might be that since you are still using SketchUp 2017 you'll need to stop updating.
                                  • fredo6F
                                    Again, please report the output of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support. Otherwise, there is no way to make any diagnostics.
                                    • B
                                      Bublifuk21
                                      It also does not work with 16.1. version. Here is my report:
                                      Fredo6 Plugins Information on 2026-10-01 14:52:46 +0200
                                      • Platform: x64-mingw32 - Ruby: 2.2.4
                                      • Sketchup: 17.2.2555
                                      • LibFredo6: v16.1g
                                      • LibFredo6 G6 Binary loaded
                                      • LibFredo6 E6 Binary NOT loaded
                                      • Sketchucation Tools: 5.0.8
                                      • SCFLicense: v7.5a - 80
                                      • Fredo6 Plugins
                                        Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
                                        FredoScale v3.7c
                                        JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
                                        RoundCorner v3.3a - licensed FULL: 263401 - HE1772082497.0K
                                        Signature File: 2026-02-26 06:08:17 +0100
                                        Curviloft: 2026-02-26 06:08:26 +0100
                                        JointPushPull: 2026-02-26 10:15:01 +0100
                                        RoundCorner: 2026-03-02 12:08:45 +0100
                                      fredo6F 1 Reply Last reply
                                      • E
                                        epetit91
                                        With version 16.1g, SketchUp crashes whenever I launch any Fredo command.
                                        With version 16.2a/b, nothing happens, regardless of which Fredo command I run.
                                        The latest version of LibFredo6 that works without issues :
                                        Fredo6 Plugins Information on 2026-10-01 18:34:24 +0200
                                        • Platform: x86_64-darwin14 - Ruby: 2.2.4
                                        • Sketchup: 17.3.116
                                        • LibFredo6: v16.1a
                                        • LibFredo6 Binary loaded
                                        • SCFLicense: v7.5a - 72
                                        • Fredo6 Plugins
                                          Curviloft v2.0a - licensed FULL: 96723 - DX1670440412.0J
                                          FredoTools v4.5c
                                          JointPushPull v4.9a - licensed FULL: 187883 - DX1670440412.0J
                                          RoundCorner v3.4a - licensed FULL: 106080 - DX1670440412.0J
                                          Signature File: 2022-12-07 20:13:32 +0100
                                          Curviloft: 2026-09-30 07:52:46 +0200
                                          JointPushPull: 2026-09-30 07:53:08 +0200
                                          RoundCorner: 2026-09-30 07:53:25 +0200
                                        • fredo6F
                                          fredo6 @Bublifuk21
                                          @Bublifuk21
                                          How do you install LibFredo6 (Sketcucation Tools, Extension Manager, manual unzip)?
                                          It seems that the main ruby file (Fredo6_!LibFredo6.rb) is not updated.
                                          Could go to the Plugins directory, erase Fredo6_!LibFredo6.rb and the folder Fredo6_!LibFredo6, and then reinstall LibFredo6 v16.2b to have a clean installation.
                                          B 1 Reply Last reply
                                          • B
                                            Bublifuk21 @fredo6
                                            @fredo6
                                            I installed it via Extension manager. I try to erase it from Plugins, download it again, install via Extension Manager, but nothing changed.
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 113 / 116
