    Is SketchUp Now Open-Source? Trimble Won't Like This
    34 Posts 11 Posters 719 Views 12 Watching
    • ntxdaveN
      ntxdave
      I am trying to learn the tool but having problems. There are times (like say with the bevel tool) where I would like to be able to enter values for the tool or understand how to control the axis for something like the rotation tool. So far, it has been iffy. I wish that the panel on the right side of the screen would give you more options to enter values. But I have just started so I will keep messing around and try to learn things. If someone has suggestions about where to find more instructions, please let me know.
      It is off to a good start but as others have said, a long way to go. One of the first things, IMO, is to provide notes about how to use various tools. As an example, if you want to rotate an object you need an option of how to select which axis you want to use for the rotation. Yes, if you hover the object you are trying to rotate, you need to be able to kit a key that specifies which axis you want to rotate on. But again, the tool is very new so there will, I assume, be many updates to help with using the software.
      Press F1...thank me later
      • P
        I don't want to hijack this thread, but I also don't want to let the momentum go to waste. For the last couple of months, I've been chipping away at a simple, easy-to-use 3D modeling tool of my own (as a side project next to Rayscaper). It's still very rough around the edges, but I'd like to give people a sneak peek at what's coming and get early feedback on what I'm building. Like with Rayscaper, I love building it with the people who use it.
        Check out the first preview here: https://modlumi.com/ - Don't hesitate to leave feedback in the application!
        Thanks,
        Thomas
        jujuJ G 2 Replies Last reply
        Reply Quote 4
        • jujuJ
          juju @pixelcruncher
          @pixelcruncher You're welcome to start a new thread of your own, probably better so that all comments relating to the subject is contained in the same thread. πŸ˜€
            Things are getting interesting πŸ‘
            Reply Quote 4
            • KrassK
              Krass
              hello,
              pixelcruncher ! not bad ! I like the viewport. I like the selection color, the UI. Geometry is too dark. I could not import a light recent model but it is a good start
              Krass
              P 1 Reply Last reply
                rv1974
                Too bad that developers are trying to "reinvent the wheel" in their own ghetto. If only it was implemented as "a-la sketchup" mode inside Blender, it would be another level.
                • P
                  pixelcruncher Extension Creator @rv1974
                  @rv1974 We are waiting for a great mind, like yourself, to do that.
                  R 1 Reply Last reply
                  • G
                    Glenn at home
                    Good. Competition keeps products fresh and generally the consumer wins.
                    • G
                      Glenn at home @pixelcruncher
                      @pixelcruncher Looking good. I was able to draw out a structure very quickly.
                      Reply Quote 2
                        rv1974 @pixelcruncher
                        who knows, maybe in 3-5 years, with GPT Bougainvillea
                        • P
                          @Krass Do you mind sending me the model so I can have a look?
                          • KrassK
                            Krass
                            Yes I Will do it tomorrow late morning
                            Krass
                              The browser version is a bit limited memory wise but that is normal for the course from what I have seen out there.
                              • P
                                pixelcruncher Extension Creator @Mike Amos
                                @Mike-Amos Fair enough, I will have a desktop version available soon. I also have a limited browser version, so I can deploy fixes to users immediately, especially at this early stage. Releasing a new desktop version is always more hassle, and it requires users to upgrade.
                                • jujuJ
                                  juju
                                  So Trimble SketchUp went after IngeTrazo...
                                  • KrassK
                                    Krass
                                    Trimble's pettiness is unparalleled
                                    Krass
                                    • 2 / 2
