    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 121.7k Views 48 Watching
    • Didier BurD
      Didier Bur @Krass
      @Krass
      I use SculptTools to adjust the shape of AI-generated medieval characters. The problem is that the UV coordinates are lost as soon as the shape is modified. Preserving these coordinates would be a significant improvement.
      DB
      • KrassK
        Krass
        Hello, that usual, I think the best way tu recover your mapping after modifying geometry is to select only the ugly faces and project your material with Fredo6 thrupaint
        • KrassK
          Krass
          but I think you won't be able to do this with AI generted UV
          • KrassK
            Krass
            One solution is to repair the damaged areas—like applying patches—using new material created from a screenshot of the figure taken before the modifications, and then applying it in "projected" mode using Thrupaint.
            KrassK 1 Reply Last reply
            • KrassK
              Krass @Krass
              • KrassK
                Krass
                This post is deleted!
                • KrassK
                  Krass
                  no ! the best solution is to use SketchUV plugin!
                  SketchUp_ZBpNK5VUlK.mp4
                  Didier BurD 1 Reply Last reply
                    If it's a single 'image' can you make its textured material 'projected', and then save it to another face of the same orientation. Can you then adjust the original surface - after which you use the eyedropper to select the projected texture from the temporary face, and reapply that onto the modified original surface ? hereby keeping the UVs ?
                    • KrassK
                      Krass
                      That may be, but I don't see a faster, more effective, and free solution than the one I showed in the video above (the second one).
                        Your video arrived as I was posting - just consider it an alternative approach...
                        • Didier BurD
                          Didier Bur @Krass
                          @Krass
                          Waoow ! Excellent !
                          Thanks for the trick (SketchUV)
                          DB
                          • 11
                          • 11 / 11
