    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 112.3k Views 48 Watching
    • KrassK
      Krass
      sorry for my "froggy" english, I didn't use a translator (french to english)
      Didier BurD 1 Reply Last reply
      • Didier BurD
        Didier Bur @Krass
        @Krass
        I use SculptTools to adjust the shape of AI-generated medieval characters. The problem is that the UV coordinates are lost as soon as the shape is modified. Preserving these coordinates would be a significant improvement.
        DB
        • KrassK
          Krass
          Hello, that usual, I think the best way tu recover your mapping after modifying geometry is to select only the ugly faces and project your material with Fredo6 thrupaint
          • KrassK
            Krass
            but I think you won't be able to do this with AI generted UV
            • KrassK
              Krass
              One solution is to repair the damaged areas—like applying patches—using new material created from a screenshot of the figure taken before the modifications, and then applying it in "projected" mode using Thrupaint.
              KrassK 1 Reply Last reply
              • KrassK
                Krass @Krass
                • KrassK
                  Krass
                  This post is deleted!
                  • KrassK
                    Krass
                    no ! the best solution is to use SketchUV plugin!
                    SketchUp_ZBpNK5VUlK.mp4
                      If it's a single 'image' can you make its textured material 'projected', and then save it to another face of the same orientation. Can you then adjust the original surface - after which you use the eyedropper to select the projected texture from the temporary face, and reapply that onto the modified original surface ? hereby keeping the UVs ?
                      • KrassK
                        Krass
                        That may be, but I don't see a faster, more effective, and free solution than the one I showed in the video above (the second one).
                          Your video arrived as I was posting - just consider it an alternative approach...
                          • Didier BurD
                            Didier Bur @Krass
                            @Krass
                            Waoow ! Excellent !
                            Thanks for the trick (SketchUV)
                            DB
                            • 11
                            • 11 / 11
