    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 112.3k Views 48 Watching
      TIG Moderator @Krass
      @Krass
      You are reading and asking on a 13 year old thread...
      I think this tool is no longer under development.
      there might be other newer similar tools around ?
      • KrassK
        Krass
        Thanks,
        if somone knows about a better free tool like this.... Anyway its very good and works on SU 2024. iS it open source so that we can modify it?
          The tool is actually 17 years since it was written. It stuck at v1.0 and never advanced. The author did add a 'copyright' notice into the start of the main code RB files. There is an email address for him there too. I suspect that he is no longer interested in it. If you were to 'tweak' some files purely for your own use [without publishing them with his permission] I'd think that's probably OK... But please note that the Ruby coding is the files is 'archaic' and might not work on newer SketchUp versions - and it's poorly formed without modules/classes etc and uses the now much frowned upon $ global variables... So use [and edit] with caution...
          • KrassK
            Krass
            I got help modifying the .rb code and achieved what I wanted: the ability to adjust brush strength and radius using keyboard shortcuts. A pop-up appears when I click, displaying the current value. However, I do need to adjust the radius "step" size depending on whether I'm working on a large scale—like for terrain—or doing fine detail work, such as on a face.
            Combined with the Mesh Tools plugin, I now have a free kit that’s on par with Artisan (or close to it!).
            1 Reply Last reply 👍
            • KrassK
              Krass
              yes, I think the good way would be to propose him the modified version, if he agrees, let him publish this or let us do it. For now, yes we are two users of this custom Sculpt tools.
              • KrassK
                Krass
                sorry for my "froggy" english, I didn't use a translator (french to english)
                Didier BurD 1 Reply Last reply
                • Didier BurD
                  Didier Bur @Krass
                  @Krass
                  I use SculptTools to adjust the shape of AI-generated medieval characters. The problem is that the UV coordinates are lost as soon as the shape is modified. Preserving these coordinates would be a significant improvement.
                  DB
                  • KrassK
                    Krass
                    Hello, that usual, I think the best way tu recover your mapping after modifying geometry is to select only the ugly faces and project your material with Fredo6 thrupaint
                    • KrassK
                      Krass
                      but I think you won't be able to do this with AI generted UV
                      • KrassK
                        Krass
                        One solution is to repair the damaged areas—like applying patches—using new material created from a screenshot of the figure taken before the modifications, and then applying it in "projected" mode using Thrupaint.
                        KrassK 1 Reply Last reply
                        • KrassK
                          Krass @Krass
                          • KrassK
                            Krass
                            This post is deleted!
                            • KrassK
                              Krass
                              no ! the best solution is to use SketchUV plugin!
                              SketchUp_ZBpNK5VUlK.mp4
                                If it's a single 'image' can you make its textured material 'projected', and then save it to another face of the same orientation. Can you then adjust the original surface - after which you use the eyedropper to select the projected texture from the temporary face, and reapply that onto the modified original surface ? hereby keeping the UVs ?
                                • KrassK
                                  Krass
                                  That may be, but I don't see a faster, more effective, and free solution than the one I showed in the video above (the second one).
                                    Your video arrived as I was posting - just consider it an alternative approach...
                                    • Didier BurD
                                      Didier Bur @Krass
                                      @Krass
                                      Waoow ! Excellent !
                                      Thanks for the trick (SketchUV)
                                      DB
                                      • 11
                                      • 10 / 11
