    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 121.7k Views 48 Watching
    • KrassK
      Krass
      I got help modifying the .rb code and achieved what I wanted: the ability to adjust brush strength and radius using keyboard shortcuts. A pop-up appears when I click, displaying the current value. However, I do need to adjust the radius "step" size depending on whether I'm working on a large scale—like for terrain—or doing fine detail work, such as on a face.
      Combined with the Mesh Tools plugin, I now have a free kit that’s on par with Artisan (or close to it!).
      1 Reply Last reply 👍
      • KrassK
        Krass
        yes, I think the good way would be to propose him the modified version, if he agrees, let him publish this or let us do it. For now, yes we are two users of this custom Sculpt tools.
        • KrassK
          Krass
          sorry for my "froggy" english, I didn't use a translator (french to english)
          Didier BurD 1 Reply Last reply
          • Didier BurD
            Didier Bur @Krass
            @Krass
            I use SculptTools to adjust the shape of AI-generated medieval characters. The problem is that the UV coordinates are lost as soon as the shape is modified. Preserving these coordinates would be a significant improvement.
            DB
            • KrassK
              Krass
              Hello, that usual, I think the best way tu recover your mapping after modifying geometry is to select only the ugly faces and project your material with Fredo6 thrupaint
              • KrassK
                Krass
                but I think you won't be able to do this with AI generted UV
                • KrassK
                  Krass
                  One solution is to repair the damaged areas—like applying patches—using new material created from a screenshot of the figure taken before the modifications, and then applying it in "projected" mode using Thrupaint.
                  KrassK 1 Reply Last reply
                  • KrassK
                    Krass @Krass
                    • KrassK
                      Krass
                      This post is deleted!
                      • KrassK
                        Krass
                        no ! the best solution is to use SketchUV plugin!
                        SketchUp_ZBpNK5VUlK.mp4
                          If it's a single 'image' can you make its textured material 'projected', and then save it to another face of the same orientation. Can you then adjust the original surface - after which you use the eyedropper to select the projected texture from the temporary face, and reapply that onto the modified original surface ? hereby keeping the UVs ?
                          • KrassK
                            Krass
                            That may be, but I don't see a faster, more effective, and free solution than the one I showed in the video above (the second one).
                              Your video arrived as I was posting - just consider it an alternative approach...
                              • Didier BurD
                                Didier Bur @Krass
                                @Krass
                                Waoow ! Excellent !
                                Thanks for the trick (SketchUV)
                                DB
                                • 11
                                • 11 / 11
