    2.3k Posts 515 Posters 2.8m Views 520 Watching
    • alexpacio2013A
      alexpacio2013
      Grazie
        https://sketchucation.com/webshop/my-licences.php should be clear now.
        To activate and release in Sketchucation Tools you can open the Settings > Licenses and activate as needed
        • alexpacio2013A
          alexpacio2013
          You're great now everything works Thanks
            Enjoy the weekend Robo ๐Ÿ™‚
            • alexpacio2013A
              alexpacio2013
              Thank you too
              • F
                fakhriaulia
                Hello,
                I've been installing the latest Sketchucation, and install Libfredo6, and FredoCorner. And I've put the license on it. After the installation, the toolbar shows up, but when I click on it, nothing happens. Can somebody help me
                • fredo6F
                  Can you open the Ruby Console before launching FredoCorner
                  • F
                    fakhriaulia
                    Iโ€™ve been open the Ruby Console before launching FredoCorner, when I click the FredoCorner toolbar, this message appear from Ruby Console
                    "build_config_commands'
                    c:/users/win10/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1569:in `block in add_command'
                      Use this method to select all output in the Ruby Console
                      How to copy text from SketchUp Ruby Console
                      • F
                        fmokhtar
                        Good evening, Fredo.
                        I have a problem with a lost license of Thrupaint and Visushole. I installed them on my laptop, but after a while, the hard disk failed, so I had to replace it. I lost all the data and configurations. The licenses are still active, even though the installation no longer exists. Is there any way to reactivate them?
                        Attached is a screenshot of the licenses. They were installed in 2025.
                        Thank you.
                        [Uploaded Images Lost to Server Upgrade Issue May 15th]
                        • fredo6F
                          Go to your My Licenses page at https://sketchucation.com/webshop/my-licences.php. You just need to sign in with your Sketchucation credentials.
                          You'll be able to release the seats corresponding to your old PC configuration and to download the licenses for a new activation on your fresh PC configuration.
                          F 1 Reply Last reply
                          • L
                            lcbbueno
                            Comprei a licenรงa mas nรฃo consigo usar o plugin Fredo Corner, como resolver?
                            I bought the license but I can't use the Fredo Corner plugin, how to solve it?
                            • C
                              comlife7
                              rbzํŒŒ์ผ์„ ์ธ์Šคํ†จํ•ด๋„ ์•„์ด์ฝ˜์ด ์ƒ๊ธฐ์ง€ ์•Š์Œ. ํˆด๋ฐ”์—๋„ ์—†์Œ ์Šค์ผ€์น˜์—… v2022์‚ฌ์šฉ์ค‘. ์ •ํ’ˆ ์‚ฌ์šฉ์ž์ด๊ณ  ๋ผ์ด์„ผ์Šค๋„ ๊ฐ€์ง€๊ณ  ์žˆ์Œ
                              No icon appears after installing the .rbz file, and it doesn't show up on the toolbar either. I am using SketchUp v2022. I am a legitimate user and hold a valid license.
                              TIGT 1 Reply Last reply
                                TIG Moderator @comlife7
                                Which exact extension are you referring to ?
                                If it's a Fredo6 extension, then look under the Tools menu.
                                Remember that you need LibFredo6 installed as well - because this supports Fredoo6's extensions.
                                And you need the latest version of the SketchUcation tools installed, as that manages the licenses.
                                After installing these extensions restart SketchUp to sync everything...
                                • C
                                  clr03 Newcomers
                                  When I want to use curviloft it doesn't work because it says that my liscense has expired but I have never used or installed curviloft before. I don't want to pay for something that has a 30 day free trial and I never had my 30 days. In the picture is what happens when I want to try and use this extension.
                                    Are you using the latest version of both Curviloft and Libfredo?
                                    That may be the reason you are prompted. Otherwise you may have simply forgotten you installed at some point.
                                    • F
                                      fmokhtar @fredo6
                                      @fredo6
                                      Hi Fredo,
                                      Thank you for your previous reply.
                                      Before writing back to you, I followed the instructions and tried to release/reset the licenses in order to identify which ones were still linked to my broken computer configuration.
                                      Most of the relevant activations were made in 2025, when I bought ThruPaint and installed SketchUp 2025. The activation dates shown in the license store match the period when I installed everything on my previous system configuration.
                                      The issue is that some licenses now appear to be linked to an obsolete hardware/OS configuration. I had to reinstall the operating system and all programs from scratch on a new hard drive, so the hardware ID seems to have changed.
                                      As you can see in the screenshot pasted below, the listed seats still refer to the old configuration, and I do not see any option available to release those seats myself from the license store.
                                      Would you be able to help me with this, or advise me who I should contact at SketchUcation to have these old seats released/reset?
                                      I am always grateful for the excellent work you do.
                                      Best regards,
                                      Farid Mokhtar Noriega
                                      • X
                                        xmedia2018
                                        "Hello, I purchased the license for the Fredo6 Animator plugin on July 29, 2026, and it has not been activated yet. I made my payment through PayPal using my Visa debit card. What do I need to do?"
                                          dduschenes
                                          HI there, I purchased a license for RoundCorner, but whenever I try to activate it, it doesnยดt show in the licenses files box - as if I didnยดt have it. How should I proceed?
                                            Rich O Brien Moderator @dduschenes
                                            You are probably running outdated extensions.
                                            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                            Send us an email on support@sketchucation.com
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 115 / 116
