    2.3k Posts 515 Posters 2.5m Views 520 Watching
    • alexpacio2013A
      alexpacio2013 @Rich O Brien
      @Rich-O-Brien I have 1 computer but on one I installed the SketchUp version 2024 2025 2026 and to do the tests I installed the licenses several times. The 2024 version is clean and has no other plugins specifically for testing. I had the same problems so it is not a conflict with other things.
        That's still a single device.
        What do you see at https://sketchucation.com/webshop/my-licences.php ?
        Can you click the blue chevron and see occupied seats with a checkbox to release seats?
        • alexpacio2013A
          alexpacio2013
          Can you remove some activations from me?
            You can do it. Click checkbox and then release
              Unless you others frozen you didn't show?
              • alexpacio2013A
                alexpacio2013
                I have to release all the boxes with the square
                  Each is a device you activated on. So yes.
                  I can do it for you. Give me a few mins.
                  • alexpacio2013A
                    alexpacio2013
                    Grazie
                      https://sketchucation.com/webshop/my-licences.php should be clear now.
                      To activate and release in Sketchucation Tools you can open the Settings > Licenses and activate as needed
                      • alexpacio2013A
                        alexpacio2013
                        You're great now everything works Thanks
                          Enjoy the weekend Robo πŸ™‚
                          • alexpacio2013A
                            alexpacio2013
                            Thank you too
                            • F
                              fakhriaulia
                              Hello,
                              I've been installing the latest Sketchucation, and install Libfredo6, and FredoCorner. And I've put the license on it. After the installation, the toolbar shows up, but when I click on it, nothing happens. Can somebody help me
                              • fredo6F
                                Can you open the Ruby Console before launching FredoCorner
                                • F
                                  fakhriaulia
                                  I’ve been open the Ruby Console before launching FredoCorner, when I click the FredoCorner toolbar, this message appear from Ruby Console
                                  "build_config_commands'
                                  c:/users/win10/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1569:in `block in add_command'
                                    Use this method to select all output in the Ruby Console
                                    How to copy text from SketchUp Ruby Console
                                    • F
                                      fmokhtar
                                      Good evening, Fredo.
                                      I have a problem with a lost license of Thrupaint and Visushole. I installed them on my laptop, but after a while, the hard disk failed, so I had to replace it. I lost all the data and configurations. The licenses are still active, even though the installation no longer exists. Is there any way to reactivate them?
                                      Attached is a screenshot of the licenses. They were installed in 2025.
                                      Thank you.
                                      [Uploaded Images Lost to Server Upgrade Issue May 15th]
                                      • fredo6F
                                        Go to your My Licenses page at https://sketchucation.com/webshop/my-licences.php. You just need to sign in with your Sketchucation credentials.
                                        You'll be able to release the seats corresponding to your old PC configuration and to download the licenses for a new activation on your fresh PC configuration.
                                        F 1 Reply Last reply
                                        • L
                                          lcbbueno
                                          Comprei a licenΓ§a mas nΓ£o consigo usar o plugin Fredo Corner, como resolver?
                                          I bought the license but I can't use the Fredo Corner plugin, how to solve it?
                                          • C
                                            comlife7
                                            rbzνŒŒμΌμ„ μΈμŠ€ν†¨ν•΄λ„ μ•„μ΄μ½˜μ΄ 생기지 μ•ŠμŒ. νˆ΄λ°”μ—λ„ μ—†μŒ μŠ€μΌ€μΉ˜μ—… v2022μ‚¬μš©μ€‘. μ •ν’ˆ μ‚¬μš©μžμ΄κ³  λΌμ΄μ„ΌμŠ€λ„ κ°€μ§€κ³  있음
                                            No icon appears after installing the .rbz file, and it doesn't show up on the toolbar either. I am using SketchUp v2022. I am a legitimate user and hold a valid license.
                                            TIGT 1 Reply Last reply
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 115 / 116
