    Modelling a tramway
    595 Posts 43 Posters 449.3k Views 40 Watching
    • jo-keJ
      jo-ke
      http://www.zz7.de
      • jo-keJ
        jo-ke
        http://www.zz7.de
        Reply Quote 3
          Eureka, I think you have it...
          • jo-keJ
            jo-ke
            http://www.zz7.de
            • jo-keJ
              jo-ke
              I started to model that tramway for a 3D Print.
              Meshyscan in foreground
              http://www.zz7.de
              • jo-keJ
                jo-ke
                3D Model is finished:
                this is how the finished model should look like....
                http://www.zz7.de
                Reply Quote 2
                  Killer result
                  • jo-keJ
                    jo-ke
                    is there a Pugin to draw rails along path?
                    http://www.zz7.de
                      ProfileBuillder would be a good option.
                      Or CurviLoft
                      CurviLoft to make profiles follow a curve in SketchUp
                      • jo-keJ
                        jo-ke
                        I am using profile builder 1 but there is no option for rails
                        http://www.zz7.de
                          I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
                          Using ProfileBuilder 3 in SketchUp to draw train rails
                          • jo-keJ
                            jo-ke
                            I need a path in the middle and two rails (special profile) left and right, to follow the path.
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              next project
                              photo:
                              SU:
                              Render:
                              http://www.zz7.de
                              Reply Quote 2
                                Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
                                  Rich O Brien Moderator @jo-ke
                                  With Curviloft the profiles can be offset from the path...
                                  Profile offset from Path using CurviLoft
                                  That does mean you need to do each side as a separate operation.
                                  Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
                                  TIG's Extrusion Tools would do it too similar to CurviLofts approach.
                                  • jo-keJ
                                    jo-ke
                                    the newer version of profile builder seems to be a good tool.
                                    Is it possible to insert an own profile?
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      http://www.zz7.de
                                      • jo-keJ
                                        jo-ke
                                        http://www.zz7.de
                                        Reply Quote 3
                                          Wunderbar.
                                            Sorry, I missed your query.
                                            Yes, you can create a library of custom profiles.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
