    Modelling a tramway
    595 Posts 43 Posters 449.4k Views 40 Watching
    • jo-keJ
      jo-ke @L i am
      @L-i-am it is just the simple Nano Banana on gemini.
      i used that prompt:
      "Photographic image of the interior of a tram in 1975, traveling through the vineyards between Ellerstadt and Gönnheim, smoking passengers, conductor with money changer and uniform checking tickets, keep geometrie, bright sunny day at fall"
      http://www.zz7.de
      • jo-keJ
        jo-ke
        new render of a project of 2022
        http://www.zz7.de
        Reply Quote 2
        • jo-keJ
          jo-ke
          http://www.zz7.de
          • jo-keJ
            jo-ke
            http://www.zz7.de
            Reply Quote 3
              Eureka, I think you have it...
              • jo-keJ
                jo-ke
                http://www.zz7.de
                • jo-keJ
                  jo-ke
                  I started to model that tramway for a 3D Print.
                  Meshyscan in foreground
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    3D Model is finished:
                    this is how the finished model should look like....
                    http://www.zz7.de
                    Reply Quote 2
                      Killer result
                      • jo-keJ
                        jo-ke
                        is there a Pugin to draw rails along path?
                        http://www.zz7.de
                          ProfileBuillder would be a good option.
                          Or CurviLoft
                          CurviLoft to make profiles follow a curve in SketchUp
                          • jo-keJ
                            jo-ke
                            I am using profile builder 1 but there is no option for rails
                            http://www.zz7.de
                              I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
                              Using ProfileBuilder 3 in SketchUp to draw train rails
                              • jo-keJ
                                jo-ke
                                I need a path in the middle and two rails (special profile) left and right, to follow the path.
                                http://www.zz7.de
                                • jo-keJ
                                  jo-ke
                                  next project
                                  photo:
                                  SU:
                                  Render:
                                  http://www.zz7.de
                                  Reply Quote 2
                                    Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
                                      Rich O Brien Moderator @jo-ke
                                      With Curviloft the profiles can be offset from the path...
                                      Profile offset from Path using CurviLoft
                                      That does mean you need to do each side as a separate operation.
                                      Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
                                      TIG's Extrusion Tools would do it too similar to CurviLofts approach.
                                      • jo-keJ
                                        jo-ke
                                        the newer version of profile builder seems to be a good tool.
                                        Is it possible to insert an own profile?
                                        http://www.zz7.de
                                        • jo-keJ
                                          jo-ke
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            http://www.zz7.de
                                            Reply Quote 3
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
