    Modelling a tramway
    594 Posts 43 Posters 425.3k Views 40 Watching
    • L
      what AI tool are you using?
      jo-keJ 1 Reply Last reply
      • jo-keJ
        jo-ke @L i am
        @L-i-am it is just the simple Nano Banana on gemini.
        i used that prompt:
        "Photographic image of the interior of a tram in 1975, traveling through the vineyards between Ellerstadt and Gönnheim, smoking passengers, conductor with money changer and uniform checking tickets, keep geometrie, bright sunny day at fall"
        http://www.zz7.de
        • jo-keJ
          jo-ke
          new render of a project of 2022
          http://www.zz7.de
          Reply Quote 2
          • jo-keJ
            jo-ke
            http://www.zz7.de
            • jo-keJ
              jo-ke
              http://www.zz7.de
              Reply Quote 3
                Eureka, I think you have it...
                • jo-keJ
                  jo-ke
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    I started to model that tramway for a 3D Print.
                    Meshyscan in foreground
                    http://www.zz7.de
                    • jo-keJ
                      jo-ke
                      3D Model is finished:
                      this is how the finished model should look like....
                      http://www.zz7.de
                      Reply Quote 2
                        Killer result
                        • jo-keJ
                          jo-ke
                          is there a Pugin to draw rails along path?
                          http://www.zz7.de
                            ProfileBuillder would be a good option.
                            Or CurviLoft
                            CurviLoft to make profiles follow a curve in SketchUp
                            • jo-keJ
                              jo-ke
                              I am using profile builder 1 but there is no option for rails
                              http://www.zz7.de
                                I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
                                Using ProfileBuilder 3 in SketchUp to draw train rails
                                • jo-keJ
                                  jo-ke
                                  I need a path in the middle and two rails (special profile) left and right, to follow the path.
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    next project
                                    photo:
                                    SU:
                                    Render:
                                    http://www.zz7.de
                                    Reply Quote 2
                                      Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
                                        Rich O Brien Moderator @jo-ke
                                        With Curviloft the profiles can be offset from the path...
                                        Profile offset from Path using CurviLoft
                                        That does mean you need to do each side as a separate operation.
                                        Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
                                        TIG's Extrusion Tools would do it too similar to CurviLofts approach.
                                        • jo-keJ
                                          jo-ke
                                          the newer version of profile builder seems to be a good tool.
                                          Is it possible to insert an own profile?
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            http://www.zz7.de
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
