[Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
I don't particularly use D5 Render LiveSync, but just wanted to note that I had to remove it for this plugin to function.
Could you tell me what is the name of the main folder of the D5 extension. I don't have it.
Then I can exclude it from LOTT.
NEW RELEASE: LordOfTheToolbars v3.0a - 21 Apr 26
Requirements
- LibFredo6: v15.9b or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 3.0a is a maintenance release including:
- Bug fixing
- Future compatibility
Home Page of LordOfTheToolbars for information and Download.
It is not able to run on my SketchUp 2025. (And SketchUp 2026 won't run on my machine for some reason…)
@JanSteinman
Did you upgrade LibFredo6 to v15.9b? -
Yes.
@fredo6 What do I need to do to get out of Sketchucation jail?
Moderators are holding my postings for FOUR DAYS before putting them up here!
When you pay money for a product, I consider this lousy service! I know developers are busy, and I'd be quite forgiving, but demanding FOUR DAYS before a developer can even see my answer to their question is insane!
Hallo, bei mir werden nur einige Iconleisten im Sketchup-Native Commands angezeigt, obwohl ich viel mehr habe. Auch bei Fredo wird nur die LOTT-Tollbar angzeigt, obwohl ich FredoScale gekauft und instaliert habe (Sketchup 24) Wie kann ich das ändern ? Gruss Joiner
Hello, I only show some icon bars in the Sketchup-Native Commands, although I have a lot more. Also with Fredo only the LOTT-Tollbar is displayed, although I bought and installed FredoScale (Sketchup 24) How can I change that ? Greeting Joiner -
Sorry, nach mehreren Starts von Sketchup war plötzlich soweit alles in Ordnung. Schönen Tag noch.
Sorry, after several starts of Sketchup, suddenly everything was fine. Good day yet. -
Isn't Lord Of The Toolbars free??
I don't know what you mean by Sketchucation 'jail'. And as Panixia said, LOTT is free.
Anyway, the trouble might be in the habitat_site_context.rb script, as shown in the Sketchup startup error box..
Did you get an error with the previous version of LOTT and this script installed?
Bug Report: SU2026 / Fatal crash on startup with D5 Render LiveSync (
Errno::EISDIR)Hi Fredo,
The last update doesn't fix the D5 issue. Either way, we can only use one of them (LOTT or D5 Render). So now my entire workflow is blocked, and so is the workflow of other D5 and LOTT users. We really need a QUICK fix for this, please.
I am reporting a fatal initialization crash occurring on SketchUp 2026.1.2 when using the latest D5 Render LiveSync plugin alongside Lord of the Toolbars (v3.0a) and LibFredo6 (v15.9c).
The Master Toolbar (yellow wheels) becomes completely unresponsive, and all custom toolbars disappear from the screen.
The Ruby Console highlights an unhandled directory scanning error in
lordofthetoolbarsmanager.rbeinside theghost_command_registermethod. It appears the script tries to open a sub-directory as a file, throwing anErrno::EISDIRexception.The main folder causing the issue is
d5_converter, located at:
%AppData%\Roaming\SketchUp\SketchUp 2026\SketchUp\Plugins\d5_converterExact stack trace:
#<Errno::EISDIR: Is a directory @ rb_sysopen - c:/users/[username]/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter> C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2290:in `initialize' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2290:in `open' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2290:in `copy_file' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:1088:in `copy_file' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:887:in `block in cp' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2481:in `block in fu_each_src_dest' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2497:in `fu_each_src_dest0' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2479:in `fu_each_src_dest' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:886:in `cp' c:/users/[username]/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:733:in `ghost_command_register' c:/users/[username]/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:1361:in `command_register'Temporary Workaround found:
Renaming thed5_converterfolder to_d5_converterallows LOTT to load correctly, but it completely breaks the D5 LiveSync connection. Downgrading D5 LiveSync to v1.6 also works.It seems a simple check to skip directories (like
File.directory?) during theghost_command_registerfile loop would prevent this crash.Thank you for your work!
Hi Fredo. This critical compatibility issue has been documented for several months. It entirely blocks the workflow between LOTT and D5 Render for all users. An urgent patch is required to restore basic functionality. Please prioritize this fix.
Can you try LordOfTheToolbars v3.0b, just published.
I don't have D5 installed and I don't really understand why it creates problems with LOTT.
Thank you but this fix still doesn't work. You can have D5 for free at https://www.d5render.com/download
To understand and reproduce the issue:
- Install the free D5 LiveSync plugin for SketchUp.
- It generates a folder named
d5_converterinside the SketchUp Plugins directory. - Start SketchUp.
- LOTT scans the Plugins directory, encounters the
d5_converterfolder, and attempts to open it as a file. - This triggers the fatal
Errno::EISDIRexception inlordofthetoolbarsmanager.rbe(ghost_command_register).
The script requires a bypass condition (e.g.,
next if File.directory?(path)) when reading the plugin directory contents.- D5 Render : https://www.d5render.com/download
- D5 LiveSync for SketchUp : https://www.d5render.com/livesync/sketchup
Can you try with LOTT v3.0c.
@fredo6 Thank you, the fix works perfectly.
Regarding future development, LOTT requires two long-overdue updates to maintain full compatibility with the current workflow:
- Integration of new native tools: Several recent SketchUp tools are currently missing from the LOTT catalog and must be added.
- Iconography update: The UI icons need to be refreshed to align with the current SketchUp environment.
Again, thank you!
Hello @fredo6
I am using SU 2026 26.2.243 64-bit on Windows 10 Pro with LOTT 3.0c
I am trying to create a Personal Command for a Menu item, but when I start this process, no choices display in the Menu section of the window. Even when I try to search for a menu item, no choices display. The Menu portion of the window is blank.
Is this a known bug? -
Menus Commands are no longer available on Windows since SU2023. This is due to a change of UI framewrok (Qt) in Sketchup.
@fredo6 you have had to repeat this numerous times in this thread but since new responders don't seem to read it, perhaps they would see it if you put it in the first few lines of the original post?
