    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
    • V
      VD20 @fredo6
      @fredo6 Ok, thanks for replying.
        awadrummer
        Hi Fredo, per your request here is the post about the conflict I was having between D5 Renderer and LordOfTheToolbars.
        Error: Is a directory @ rb_sysopen - .../plugins/d5_converter
        The Cause:
        LordOfTheToolbars was scanning all plugins to build its toolbar menu. When it encountered the d5_converter folder, it tried to open it as a file to read/copy it, but it's a directory, not a file. This happened in the ghost_command_register function.
        The Analysis:
        The D5 Converter structure is standard (a .rb loader file + a subfolder with extension code)
        Nothing weird about D5's structure
        LordOfTheToolbars wasn't properly checking if something is a directory before trying to open/copy it
        Summary:
        The extension causing the conflict is LordOfTheToolbars. It's failing when scanning the plugins folder because it tries to open the d5_converter directory as if it were a file (using rb_sysopen), triggering the "Is a directory" error. The fix would be adding a directory check before attempting to open/copy files in the ghost_command_register function.
        1 Reply Last reply 👍
        • V
          VD20
          I am having an issue with conflict between D5 render live sync plugin.
          When the live sync version was D5_LiveSync_Sketchup_usa_1.6.1.0020, there was no issue.
          After i update it to D5_LiveSync_Sketchup_usa_1.7.0.0001.
          The LOTT vignette strip stopped loading.
          I am forced to roll back to older 1.6 version to get the LOTT to load properly.
          Kindly look into this issue if possible.
          Regards..
          O 1 Reply Last reply
          • G
            gabe05
            My LOTT broke today. I wanted to add a new extension to my toolbars, and when I clicked on the Master Toolbar Manager button, my vignette stripe disappeared and all my custom toolbars got F'd. Its doubling every button in my custom toolbars, even new toolbars I make, sometimes not even using the correct icon. (They only appear doubled on the toolbar itself and not in the manager.) The stipe is gone, but all my palettes are still available in the Favorites Manager, and I can open them manually. Restarting SketchUp resets the toolbars, but if I open the manager it screws them up again. Can't get the stripe to come back at all. Reinstalling the extension didn't help. v2.9c with sketchup 2018
            • O
              optimaforever @VD20
              @VD20
              I already reported this error earlier.
              • O
                optimaforever
                May we expect a fix for this issue between D5 render livesync and LOTT?
                panixiaP 1 Reply Last reply
                • panixiaP
                  panixia @optimaforever
                  @optimaforever man, check your n inbox đź‘»
                    MarissaW
                    For some reason while trying to set up my toolbars, my V-Ray tool sets do not show up in the Master Toolbar Manager. It seems like almost everything except that shows up.
                    Is there something specific I need to do to get it to show?
                    Using SketchUp 2026, version 26.0.429
                    Thank you!
                    fredo6F 1 Reply Last reply
                    • fredo6F
                      fredo6 @MarissaW
                      @MarissaW said:
                      Thank you!
                      Nothing you can do. I had to remove VRay from the list of icons because VRay does something to precisely avoid indirect calls (liek LOTT does).
                        dlannetts
                        I don't particularly use D5 Render LiveSync, but just wanted to note that I had to remove it for this plugin to function.
                        • fredo6F
                          fredo6 @dlannetts
                          @dlannetts
                          Could you tell me what is the name of the main folder of the D5 extension. I don't have it.
                          Then I can exclude it from LOTT.
                          • fredo6F
                            NEW RELEASE: LordOfTheToolbars v3.0a - 21 Apr 26
                            Requirements
                            • LibFredo6: v15.9b or above
                            LordOfTheToolbars 3.0a is a maintenance release including:
                            • Bug fixing
                            • Future compatibility
                            Home Page of LordOfTheToolbars for information and Download.
                            Main post of this LordOfTheToolbars thread.
                              JanSteinman Newcomers
                              It is not able to run on my SketchUp 2025. (And SketchUp 2026 won't run on my machine for some reason…)
                              • fredo6F
                                fredo6 @JanSteinman
                                @JanSteinman
                                Did you upgrade LibFredo6 to v15.9b?
                                J 1 Reply Last reply
                                  Yes.
                                    JanSteinman Newcomers @fredo6
                                    @fredo6 What do I need to do to get out of Sketchucation jail?
                                    Moderators are holding my postings for FOUR DAYS before putting them up here!
                                    When you pay money for a product, I consider this lousy service! I know developers are busy, and I'd be quite forgiving, but demanding FOUR DAYS before a developer can even see my answer to their question is insane!
                                    panixiaP 1 Reply Last reply 👎
                                      joiner
                                      Hallo, bei mir werden nur einige Iconleisten im Sketchup-Native Commands angezeigt, obwohl ich viel mehr habe. Auch bei Fredo wird nur die LOTT-Tollbar angzeigt, obwohl ich FredoScale gekauft und instaliert habe (Sketchup 24) Wie kann ich das ändern ? Gruss Joiner
                                      Hello, I only show some icon bars in the Sketchup-Native Commands, although I have a lot more. Also with Fredo only the LOTT-Tollbar is displayed, although I bought and installed FredoScale (Sketchup 24) How can I change that ? Greeting Joiner
                                        joiner
                                        Sorry, nach mehreren Starts von Sketchup war plötzlich soweit alles in Ordnung. Schönen Tag noch.
                                        Sorry, after several starts of Sketchup, suddenly everything was fine. Good day yet.
                                        • panixiaP
                                          panixia @JanSteinman
                                          Isn't Lord Of The Toolbars free??
                                          • fredo6F
                                            I don't know what you mean by Sketchucation 'jail'. And as Panixia said, LOTT is free.
                                            Anyway, the trouble might be in the habitat_site_context.rb script, as shown in the Sketchup startup error box..
                                            Did you get an error with the previous version of LOTT and this script installed?
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 25 / 28
